Question about Electrolux 23 in. ESI602X Built-in Dishwasher
I have a electrolux EIDW6105 dishwasher,since new,after a load of dishes are done,by the end of the day,the inside of the dishwasher smells so bad,like rotting food,it is almost unbearable to smell.I had a service tech come and check it out,he said the washer was not installed correctly,was not level,I made the change,same problem,then he said I would need to use DISHWASHER MAGIC once a week,same resault,then he called electrolux tech support and they told him that it was nomal and I should run the washer in the rinse cycle EVERYDAY to eliminate the oder.really?.....I dont remember ever doing this with my $300.00 GE UNIT.
Macmarkus
  • 2605 Answers
SOURCE: How do I get the Electrolux dishwasher to dry the dishes?
Hello, I've got a suggestion and at first it may sound like I'm pulling it out of my...left field. I'll tell you the what and then I'll explain why. Try this, take a rag or paper towel and soak it with "rinse aid" AKA, "jet dry" and apply it to the top of the tub and to a lesser degree the sides as well. I suggest this to all my customer's with new dishwasher's. Now the why...all dishwasher's require assistance to dry your dishes, some more than other's. Hence the need for an additive such as jet dry, it is simply a wetting agent which help's the water run off the dishes and as a result they dry better. So why put it on the tub ? Glad you asked. The reason is exactly the same, on older dishwasher's that have had many year's of use the tub has already built up some wetting agent on the tub just by normal and continued use, the new obviously has not. The only jet dry the new one has is the added amount in the dispenser. Over a short time of regular use the unit would start to dry better on it's own, this just speed's up the process. By adding the jet dry to the tub you create a seathing action allowing water to run off before & during the dry cycle as to not have water in the form of condensation dripping back onto the dishes when the cycle is complete, which leaves you with dry dishes as opposed to wet dishes. Make sense ? I hope so, it really work's. Hope you found this helpful. If so please rate the info you received frome jere at "fixya" today and good luck. Let me know if I can assist you further. I hope you didn't find this too difficult to read, I had to use my iphone, it's the only internet connection I have at the moment. Macmarkus :)
Posted on Jan 07, 2010
  • 4348 Answers
SOURCE: I'm having a problem with
Check the drain system, that means all filters, the pump, and the drain hose. Kinks happen easily.
Posted on Sep 19, 2010
heatman101
  • 43501 Answers
SOURCE: I'm having a problem with a cloudy film on all of
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if the heating element goesbad then that also can mess things up bad... So I would buy new spray arms, and also check out theheating element to make sure it is working... Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 21, 2010
  • 3247 Answers
SOURCE: this dishwasher (Eidw6105gs1) smells terrible
Looks like you have an Electrolux dishwasher.
Is there a garbage disposal unit in the sink? Do you run it often if it is there. Try to run it first before starting the dishwasher.
The spots on glass could be more to do with insufficient rinse aid. Check the rinse aid content or setting.
Try to run the dishwasher with a Finish dishwasher cleaning kit as recommended on the instructions on the kit.
Finally if all that does not help, you will have to open the hoses at the bottom of the dishwasher and look for food particles stuck in pump etc. The assembly diagram is available at this site.
You can view the user manual at this site if you do not have one. In particular check page 21.
Hope all this helps.
Posted on Feb 12, 2011
  • 114 Answers
SOURCE: Hi there, I have an ESL424 Electrolux dishwasher
first thing is to ensure the top spray arm is turning freely. make sure nothing is blocking it, for example one of them dishwasher fresheners.
also check the holes on both spray arms to ensure they not blocked up, also if you can remove the spray arms and clean them out, also clean out the filter.
i also always susjest putting the upper basket on the highest setting as high plates etc. in the bottom basket can stop spray arm turning
after checking all of the above, put the spray arms in the 12 o clock posistion and turn the dishwasher on, when it starts washing open the door to see if they have moved.
also always use a good quality diswasher tablet, cheaper ones dont always give good wash results.
Posted on Jun 25, 2011
My dishwasher is left quite wet inside after washing dishes. Is this unusual, especially for an expensive Viking dishwasher that is brand new?
make sure you have selected the heated dry option. for the smell, add a 1/2 cup of white vinegar to wash cycle.
Jun 21, 2015 | Viking Dishwashers
Dishes still wet upon end of cycle
Check if the heater is working. This can be done by checking if the dishwasher has steam and dishes are warm when cycle is complete. Also check if the Rinse aid has not finished. Make sure the Rinse aid dosage is not at too low.
Jul 31, 2014 | Electrolux Dishwashers
ICON DISHWASHER
Check and make sure the Air Dry button is not engaged. Check the clean out at the bottom. When you push the top rack in insure it is hitting the opening in the back. Finally purchase some Lemi Shine Machine cleaner for the smell, it's likely you have a some stuff lurking in the screens causing the smell, this made my Icon dishwasher work like new.
Apr 07, 2014 | Electrolux Frigidaire Professional Series...
Kenmore dishwasher leaving a lot of water on door, bottom, wall and dishes! it STINKS!
The pump could be leaking. The drain could be plugged - hence the smell. Taking a look underneath could reveal what needs to be fixed. I don't have an answer for why dishes are still wet even after a hot wash and heated dry but perhaps it is related to the other problem
Oct 22, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Would the stainless steel make the inside of the dishwasher smell awful when half full of dirty dishes after only 2 days? I noticed under the screen on bottom of tub that not all the water completely...
stainless steel will not smell or rust that why its used,the cause of the smell is twofold 1 dirty dishes should not be left unwashed in the machine to long a bectearia starts to grow within a couple of hours and starts the smell process,2the filter system at the bottom of the machine should be checked everyday [heavy user]light use every [2/3 days],the screen at the bottom of the machine is the filters,some models do leave some water in the bottom.adrian,,,,,
Aug 12, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
When we open dishwasher theres standing water in the drain area and it smells bad this is after washing aload dishs look clean but inside stinks
After you run a load of dishes put 1cup of CLR or vinegar (white) and run a quick wash.no dishes,after running dishes clean out spray arm and clean strainer,use a rinse agent like finish, and spray off dishes before loading.About 35yrs. ago I use to be a dishwasher as one of my first job's and if you did'nt spray the dishes and scrap them off before loading,the dishes would not come out clean,And after each shift the dish washer would be cleaned out.
Aug 04, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishes are not drying
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jul 12, 2010 | Electrolux 23 in. ESL6114 Built-in...
I have a electrolux eidw6105 all lights are flashing and the led panel has the wash pump light on what does this mean
very important! the machine must be perfectly level or slightly tilted higher in the front . If not the leak detector function will engage and the machine will not operate. Try raising the adjustable feet behind the kick plate.The machie may reset without removing it.
May 11, 2010 | Electrolux EIDW6105GW 24 in. Built-in...
Bad smell
Try running washer empty with soap or tablet in the regular cup and baking soda in the secondary cup. After cycle is complete and somewhat dry inside leave slightly open to allow air circulation overnight. This should help.
Sep 15, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Electrolux 23 in. ESI602X Built-in Dishwasher Logo
145 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
