Question about GE Refrigerators
Freezer is not freezing food an ic forms in the inside of the refrigerator
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 10, 2010
Fridge freezing up
Set your Ref/Freezer per the following:
Refrigerators:
36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
You have to wait about 4 hours for everything to stabilize. If you are still having ice forming inside the freeezer then the rubber seal around the door is probably the problem. If they have a split, tear or crack, etc. it will let warm moist house air into the freezer and turn to ice as it cools. If this happens in the refrigerator it'll turn to water and collect in the bottom of the frig. New seals can cost around $60 per door.
If you pack too much food in the unit it may also cause freezing because the air needs to move around in there and food shouldn't block the vents in the back walls of the unit.
Hopefully this helps..
Nov 23, 2012 | Spartan Showcase Self Service Cigarette...
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
Freezer temp too low in ge profile topfreezer refrigerator. ice is forming but extremely slowly.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 03, 2011 | Refrigerators
Ice crystals are forming throughout my bottom freezer
heatman101
Feb 15, 2011 | Amana ABB1927DE Bottom Freezer...
Admiral ATF1910DRW refrigerator. The refrigerator
hi there,
there seems to be a technical error. call your repairman to have him take a look at the inside wiring before your food gets spoiled even more.
Jun 11, 2010 | Refrigerators
We have cracks forming in an 8 inch section of
you can use a hydraulic adhesive or Automotive door trim glue ( yellow) works great too these are made for extreem weather conditions ,
Aug 29, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Frost form inside the ice maker door in the freezer
Any time moisture freezes to something in the freezer it is two possible reasons that are most likely. The defrost system is defective, blocked or there is outside air being drawn into the freezer from a faulty seal or the ice maker door at the dispenser is sticking open. Keep an eye on these things and freezer temperatures and fresh food temperatures. Your refrigerator is complex and I have the service manual and willing to help you solve this. Thanks, and let me know, Sea Breeze
Jul 11, 2009 | Maytag MSD2650H Side by Side Refrigerator
Maytag msd2354arw refrigerator side is freezing food
the problem can be solved by turning the freezer setting to low, by which the problem will be solved. plz rate me.,,
Jun 27, 2009 | Hotpoint HSS25GDMWW Side by Side...
Fridge is freezing food
YOU HAVE A BAD THERMOSTAT,REPLACE,MAKE SURE DRAIN IS CLEAR TO,THANKS-MIKE
May 07, 2008 | Candy CPCA240FFK Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
