Question about Yahoo Messenger
I am unable to change who is singed on messenger even after I sign on the wrong name appears
  • 182 Answers
The problem is because of the session cookies and it can be solved easily by you all you got to do is follow the following simple steps and incase you face a problem reply back to me
Click the "Start" button on the bottom left corner of your windows screen..then click on "RUN"
If you dont see the "Run" box simply click on Simply type "run" in the start search box (if you are using windows vista or windows 7)
when you get the Run box ..type in "inetcpl.cpl"
Internet options will appear on your screen... click on "Delete" on the next window click check all the check boxes(probably 7) and click on Delete
This should solve the problem....else if you face any problem performing the above steps
Dowload the following software it would do the cleanup for you
http://tinyurl.com/messengercleanup
click on the above link and download the software...click on run to run the software
once the software is there on the screen (should not take more then 1 or 2 mins) click on Select all and then click "empty selected"
Once done...open the messenger and sign in with your id...the problem is solved
Posted on Sep 10, 2010
I appear offline in yahoo messenger even If I am online
Yahoo! Messenger gives you the option to make your status appear "online", "busy" or "offline." If you want to appear online all the time you must set the messenger to do so, especially if you changed it to a different setting at any point.
1.Sign On
In order to set your instant messenger to "online" you must sign in to your account. You should use your Yahoo! email address and password to sign in to the account. If you want the program to sign you in automatically, you must check these options on the initial sign in box.
2. Settings
Click your name at the top of the "friends" list and change your setting to "available." Available means you are online at your computer and ready to chat.
3. Changes
No changes are made to your status unless you sign off (which you will then appear offline) or if you physically change your setting. It does not change every time you sign off.
I hope you find it very helpful. Thanks
Aug 25, 2011 | CTX Ez Book 700 Notebook
Everytime I sign into my Hotmail, my msn sign's me in via web. I do not mind that I can have this wonderful accessibility, however I do not want to be singed into my msn EVERYTIME I want to just check my...
My suggestion and it worked for me. Go ahead and pull up your MSN like you are going to log into it. It will ask you save username, password and log in automatically. Make sure the log in automatically is disabled. This should help clear up your issues. It had cleared up mine. Also as far as your hotmail account, bring up your options of that and just double check your setup there may be a few things checked that do not need to be.
Feb 04, 2011 | Computers & Internet
Yahoo messenger stops after i sign in
Usually, if wrong password but connection is ok, it will prompt you that you have the wrong password. This shows that your messenger connected to the server OK.
If it stop singing in, this shows some kind of connection problem, it means messenger couldn't connect to yahoo server or get any response
This could either be your computer setting or yahoo server.
if you're using any kind of firewall, make sure your firewall allows messenger to go online
if you never had this problem and it just happened, and you never change anything on your PC, then its Yahoo server issues
lately I have some problem with yahoo connection. my messenger just disconnected.
Jan 21, 2011 | Yahoo Messenger
My yahoo messenger sing out autometically and
Dear Sir,
plz folow this step,
make sure your firewall settings are disabled or changed to allow messenger...........then click on <messenger> before sign in then click on <connections and preferences> there you have to mark an option <use no proxy> and thats all........if dont work then remove that messenger through control panel and add/remove programs and download through the add below.
www.freecreed.com
Thanks For Your Time,
Apr 24, 2010 | Yahoo Messenger
Something is wrong with my e-mail. Its not working even though I'm putting the right thing. What do I do?
check your password and try without the @yahoo.com sometimes the name and password work fine. also, make sure you are using the proper mail you singed up with.
Dec 21, 2009 | Yahoo Messenger
I cant sign in plss help me if i sing in there
The best attempt to unlock your ID is, try to login not by yahoo messenger, but by mail of yahoo which has a same user name and password that been locked. Sometime, this step worked, but make sure after your login to yahoo mail and success, you have to change your password with new password, and then you can login to yahoo messenger with new password that you just been created.
If you try to send a complain to the contact of yahoo messenger, It will useless. Yahoo doesn’t care what happen to your if you go locked.
To protect your ID or to prevent Lock ID, you must have a strong password. I will suggest you to not chat with your primary email in yahoo messenger. Sometime yahoo makes a prohibition to some of ID. This mean your ID can be banned by yahoo and your ID never be join to yahoo messenger or yahoo email again.
To create a strong password you must use all character who listed in your keyboard. Such as uppercase, number, and symbol. You must be create password which have not less 8 character or more.
Here I give you an example a strong password: H4rP3 ^&* (with 3 space on it). To make a better password work well, you have to change your password frequently: 3 week or 3 month, depending how strong and important your password i
Oct 12, 2009 | Yahoo Messenger
Can not sign-in to yahoo messenger
Yahoo Messenger is subject to many security flaws. Sign into your yahoo email first, and then try to sign into messenger.
Apr 15, 2009 | E-Machines eMachines Desktop PC
Abosamr52
Hello
- It seems like somebody has hacked into your hotmail account and changed your password so you are unable to sign in.
- If messenger is tellling you: WRONG USER NAME OR PASSWORD it is that. - Otherwise try uninstalling and reinstalling msn messenger and see how it goes. - A good way to check if the password is WRONG (therefore changed) is go to www.hotmail.com and insider there put in your email and password (the ones you think are the good ones and see if it is telling you that the password is incorrect.
Failing to sign in is another thing. To check if it is a problem at your home on your computer use www.meebo.com and try sign in there. If you are able to sign in then the reinstall of msn messenger should solve your problem.
One last thing if you installed a firewall make sure that msn messenger is added as an exception in the allow programs as you will keep encountering this problem.
Jan 07, 2009 | Microsoft Windows Live Messanger
Error code 810003c1
Hello
I hope that i was able to answer your query unfortunately i dont have arabic fonts installed
Best Regards
Jan 06, 2009 | Microsoft Windows Live Messanger
Yahoo messenger sing in problum in 9.0 version
I'm unable to access my ym, plz halp me..........
Nov 16, 2008 | Yahoo Messenger
Yahoo Messenger Logo
14 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
