Question about Spectroniq PLTV3250 32 in. LCD TV
Power light not on ,have checked power cord it tv it is hot
  • 11,361 Answers
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Posted on Oct 15, 2010
Why does my sanyo tv ce32ld08b keep turning of
I assume the TV's out of warranty. Sounds like an intermittent connection. Make sure the AC power cord is not loose. Check the AC cord at the TV & wall. Next check for sensitivity to heat. Use a hair dryer. CAUTION- DON'T LET THE TV GET TOO HOT to touch with your bare finger. With the TV ON and working, warm up one small area at a time on the BACK side only. If you find a sensitive area, take it to a TV shop to check for a bad connection.
Mar 18, 2015 | Sanyo Televison & Video
Can your power cord be bad on a panasonic plasma tv to cause it to turn off and not start again and blow a fuse on pb
The main power regulator board will have some shorted component/s on it. Normally, these boards to plasma TVs are irreparable. Card base replacement should be done.
Jan 29, 2013 | Panasonic TH-C42HD18 42 in. Plasma TV
Wharfedale LCD2710HDAF no power to tv, checked cable and changed fuse a few times, new power lead? or is this a common problem?
Hi.
The power cord must be checked using a multimeter. The test is done reading impedance (ohms) between plug's prongs and contacts to TV power board.
If the power cord is OK and there is no power, then the problem is the power board inside the TV.
Regards.
Ginko.
Dec 04, 2011 | Televison & Video
The tv will not power on. Outlet is good. cord is good. Checked for electric on cord using meter.
Does the standby light come on at all or is it completely black?
Check to see if there is a fuse holder right where the power cord enters the back of the tv.
Good luck and keep us updated on your troubleshooting progress.
Jan 21, 2011 | Philips 19PFL3403D/27 19 in. LCD TV
When I turn the tv on it stays on for a few seconds, and then cuts off
is the power light or lamp light blinks? if its the lamp then replace it. your tv lamp model # XL-2400. check this link https://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=600259&searchOperation=modelSearch&searchText=KDFE42A10
or if its the power light that blinks then turn off tv for 5 mins. unplug power cord for 1 min. try plugging the power cord directly into working wall outlet. if same, tv needs service. visit eservice.sony.com website to check service option
Dec 24, 2010 | Sony KDF-E42A10 42 in. LCD Television
Does toshiba 27d46 have a reset button? my tv will not turn on and the led light is not on either. checked the power cord & outlets. help!!!
check for the blown FUSE after the power cord.Check standby power section for a defective component.
Apr 27, 2010 | Toshiba 27D46 27" TV
Missing power cord
HELLO AND NO YOUR AMP SUPPLY IS'NT THE RIGHT AMOUNT YOUR CORD ONLY SUPPLIES 2.5 AND YOUR T.V. CALLS FOR 5.2 IT'LL RUN YOUR T.V. BUT THE REASON IT WONT WORK IS BECAUSE YOUR T.V. WILL PULL 5.2 AMPS AND YOUR CORD IS ONLY RATED FOR 2.5 IN TIME THE CORD WILL BURN OUT OR GET HOT AND CAUSE A POSSABLE FIRE.
May 03, 2009 | Televison & Video
Red light brinking
Hi
Can you give the HOT voltage? this issue is by defective HOT section maybe you have leak or shorted capacitor.
Thanks!
Apr 12, 2009 | Daewoo DTQ-20U4SC 20" TV
Where can I purchase a new power supply for my TV?
simple and best option go to  www.radioshack.com websites for this power supply cord. they will provide you with the exact requirement. thanks.
Jan 05, 2009 | Televison & Video
Won't turn on
I bought two tvs and after about 3 months one of my tvs would not turn on; this tv was used more than the other one that is still working. I noticed that the power cord has a box that connects the two parts of the cords together, well the box gets very hot. I thought that the problem could be the power cord (may be it burned out) and not the tv. I switched power cords from the working tv to the nonworking tv and that sovled the problem.
Dec 17, 2007 | Proscan 19LA25Q 19 in. LCD Television
Spectroniq PLTV3250 32 in. LCD TV Logo
47 people viewed this question
Top Spectroniq Televison & Video Experts
Frank Zabroski
Frank Zabroski
Jayesh Panchal
Jayesh Panchal
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
