Question about Nintendo Wii Console
My wii system lost its red color. when i play wii sports everything mostly everything is green. i tried fixing my tv settings but its not the tv. ive tried everything. does anyone have a different idea on how to fix it?
I have the same problem with my Wii. It's on everything, games, etc. Did you ever access the internet through your Wii. I do and I wondered if a virus hit it.
Posted on Dec 04, 2010
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
Why cant i get my wii console to work in color
Well it might either be the tv or the av cables that is causing the wii system to be in black grey and white then.
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Mar 06, 2012 | Nintendo Wii Console
Bought new componant cables for new tv and the wii will not play in color. tryed moving cables around still no luck the different combo's that i tried either switched every thing to all red or all blue!...
Make sure the colors line up.
Red-Red
Green-Green
Blue-blue
If the tv has a second componant input then test it in that input.
What model tv are you pluging it into?
Did the wii work on the old cable?
Jan 03, 2011 | Nintendo Wii Console
Color in tv is very green you cant tell what suppose to be what i was watching cartoons with kids and the animal that suppose to be red was black i tried adjusting color temp and every thing even resetting...
If your using a tuner for your TV channels and you are using component video cables make sure that the red cable is not plugged into the audio socket. red blue and green cables should all be plugged into the "component" input on the tv not audio.
Dec 27, 2010 | LG 42LC2D 42 in. LCD HDTV
How do I fix the color on my tv
In the steup menu there should be a setting called "HUE" try adjusting that. If that does not work, you may have lost "green drive" circuits in your TV.
If the menu windows have the right colors, try playing a DVD or a video on it. If they look good you may have a problem with channel tuner or antenna.
Jan 15, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Having trouble with the colors on my WIi, everything seems yellow and there is no red anywhere
I just wanted to add that I recently bought a WII and I have the exact same problem. I have a Samsung HD TV and I bought the additional HD cable that has the multiple jacks (i.e. green, blue etc.) I will post if I find a specific answer to the probem.
Dec 24, 2009 | Nintendo Wii Console
Wii menu and all sports in black and white; how do we get color?
You are probably plugged into the wrong RCA slot for your Wii's configuration. If your TV is an HDTV you need to either go to your Wii's settings and change the TV settings to HD or remove the Wii RCA (Red/Yellow/White) from the HD slot and put them in the standard input RCA slot. Red/Yellow/White insted of Red/Green/White.
Dec 21, 2009 | Nintendo Wii Console
No Color Picture
Are you using the Red/Green/Blue cables or are you using the Red/Yellow/White?
Also make sure you are matching the colors up correctly. If you find that you only have two of the three RYW, try hooking it up to another AV jack on the side or front of the new TV. If you are using the RGB, sometimes in low light settings, the blue and green are easily mixed up.
Another thing you might want to try is changing your settings on your tv for NTSC as it might be set up for PAL.
Dec 15, 2009 | Nintendo Wii Console
Red colors have turned green
You most likely have lost red lamp function. This can be caused by a number of issues. None are going to be an easy fix. You can isolate the problem quickly if you are a tech, by doing a red/green gun driver board swap. Pretty much the only thing you can try to do yourself, is take the front panel off the TV, then adjust the color bias knobs usually located somewhere behind the panel. One will control the red, one for blue, and one for green. Mark them before you play with them, so you can return them to the factory settings if needed.
Nov 13, 2008 | Televison & Video
No color
Try to change the settings on your Wii to play in 480i or 1080p witchever your tv is.
It sounds like a easy system configuration adjustment. Check both your Tv settings and if your using HD on the Wii try using just R/g/b (red,green,blue) wires. I would belive that the settings on your wii or your tv arent correct, just play around with these settings with the wii hooked up and on.
GOOD LUCK let me know if their isnt anything more I can do. MORE DETAIL CAN HELP YOU OUT because their might be 1 small thing you didn't do and can cause this.
Sep 11, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
259 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
