Question about Whirlpool GEW9250 Electric Dryer
I have a whirlpool model number gew9250pwo when i push the start button there is a click, then nothing happens at all...i have cleaned it, changed the thermal fuse, and the circuit board...any ideas?
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 10, 2010
I have a 6E code on my dryer and it wont start . When you press the start button it only got a click and nothing happens. The drive belt was broken when I looked inside could that be a problem it's a...
Looking at an other diy fix site (answer by Jake)
Its your door switch that's bad.
Here is the online repair manual for the Whirlpool Duet dryer:
http://www.applianceblog.com/manuals/Duetdry.pdf
Give it time to download. Page 4-6 tells you how to access it. You can print it out as well.
Here's another member that had the same error code and the door switch fixed it too:
http://www.applianceblog.com/mainfor...not-start.html
Here's the door switch for your model you can order:
Manufacturer's Number: 8283288
[img src="http://www.appliancepartspros.com/PartImage.aspx?imgid=Z3BqLjBfaHRfODgyMzgyOC9MUFcvc290b2hwdHJhcC8%3d" border="0" alt="">
Jake
Hope that helps Gerry
Sep 11, 2014 | Dryers
The model number of my Whirlpool dryer is LER4634JQ0. When I push the start button nothing happens. I have checked the fuses, the door latches and the plugs. I had been using the dryer on the day this...
Lift top up, it is hinged, and check if belt that is supposed to be around the drum and motor is broken. If it is broken it's a fairly easy fix.
Feb 23, 2011 | Whirlpool Dryers
When I push start nothing happens First it was
The symtom your describing is that of a worn or loose belt. There is a belt safety switch on the motor mount that is actuated by the travel of the idler arm. If the belt is worn stretched or broken the dryer will not start because the belt safety switch has actuated.
This is a matter of changing the dryer belt. In the process of the belt change check the drum felts front and rear for excessive wear, Worn drum felts / seals can losen the belt so the idler travels to tighten the loose belt and can cause the belt safety switch to be activated. .
BEFORE you go directly to the belt as the problem check the door switch. You should hear and audible CLICK as the door just opens or closes. No CLICK = no start. I.e bad door switch.
There are a few other possibilities but these are the 2 most common. If none of the above is related to your dryer or you need more assistance please respond with your dryers' make and model number.
Thanks for choosing FixYa.
Kelly
Sep 15, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool model KUDSO1FL not starting cleaning
I fixed the problem by hitting Hi-Scrub then Economy Dry in sequence four times in a row. All of the lights came on, I am assuming to reset it the program, then went off and the start button was highlighted. I then pressed cancel and then selected the program that I wanted to wash with and pressed start. It worked like a charm.
Jan 31, 2010 | Whirlpool Dishwashers
I have a whirlpool quiet cycle III that won't start
Check the whirlpool web site. There is a link to see if yours is affected, click that and answer a couple of questions then if will ask for the serial number and then the model number, which are located on the inside wall of the washer. When you submit these numbers it will tell you if yours is recalled which is probably the cause of your problems as well. Since mine was doing something similar and it is one of the washers on recall for a bad motor.
Jun 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Apr 02, 2009 | Whirlpool LGV4634JQ Gas Dryer
Dry cycle won't start
Commonproblems...blown house fuse, broken belt ( on some models )...door switch...*thermal fuse open (venting needs attention )...broken or burnt wire....timer....motor, in order from mostcommon to least common. * If you find a blown thermal fuse, always clean, change, adjust the ventingsystem and vent hood first, then it is often a good idea to replace the operatingthermostat at the same time. This is a picture of some modernthermal fuses.
Mar 28, 2009 | Whirlpool GEW9200L Electric Dryer
Whirlpool dryer has power, but drum won't spin
More likely does have a belt. Get me the model number and I will see if I can help you on this problem, Thanks, Sea Breeze
Mar 21, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
247 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
