Question about Procom QL300TYLA Heater
Can it be used without a blower? - Procom QL300TYLA Heater
  • Procom Master
  • 43,501 Answers
Yes, it just does not distribute the heat as well as with a blower...but it will still work just fine...
heatman101
Posted on Sep 10, 2010
2005 Hummer air not blowing through the vents? Rained through sunroof, changed blower motor, fuses, and disconnected battery to reset? Please help
Probably the blower motor control processor is bad , but without testing that would be just a guess . Do you know how to test automotive electrical circuits using a DVOM - digital volt meter ?
HVAC Blower Motor Circuit
Aug 19, 2017 | Hummer Cars & Trucks
New replacement Blower does not have a ground wire, existing blower does, will the new part work without a ground wire?
Are you talking about hvac blower motor? How many pins on the blower connector, should be two, one is voltage, the other is ground.
If the new blower pigtail has only one wire, maybe it grounds through the chassis? You could use a redundant jumper wire for ground if your worried. One end of the wire goes to blower motor mounting screw, make sure it is touching bare metal, the other end of wire goes to bare metal spot on chassis.
What is year--make--model of vehicle?
Nov 03, 2015 | Cars & Trucks
New Husqvarna 125B blower runs fine then stalls
Is the gas fresh or old that you used. Since this brand new, it's under warranty. If you've had it for a few days, return to the store from which purchased it. It should run right out of the box without having to work on it.
May 16, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
INTERTHERM HEAT PUMP/AC. BLOWER KEEPS RUNNING WITHOUT THE COMPRESSOR ON. SOMETIMES FOR HOURS. ALREADY REPLACED THE CONTROL AND LIMIT SWITCH.
Blower? Internal house air blower I assume. - Blower relay contacts pitted and stick in on position.
BAD Control BOARD, fault or adjustment program keeping relay energized. Bad emperature sensor not telling Board unit has use up cold air. loose wiring to sensors and board connections
Sep 11, 2013 | Intertherm Heating & Cooling
Need to replace blower motor
Instructions
    • Remove the passenger side kick panel using a Phillips head screwdriver. Pull the rug back from under the blower motor to allow enough room to drop the blower motor without the rug interfering.
    • 2Disconnect the electrical plug from the blower motor. Pull the rubber vent hose out of the blower motor.
    • 3. Remove all the Phillips head screws securing the blower motor to the housing. Drop the blower motor straight down.
    • 4. Install the new motor in reverse order of removal.
Dec 19, 2012 | 2003 Buick LeSabre
Honda Accord 2002 heater blower control works only in the high position. The 1, 2, and 3 positions do not work but the high (4) does.
The heater blower is normally controlled by voltage sent to the blower via a resistor network.
In this case it seems that this unit also called the fan resistor is defective.
I assume that 4 is the position where the blower is running HIGH and in this position the blower is powered directly without using resistor for lowering the speed of the blower. In step 1 - 3 the blower is powered via the mentioned resistor network.
In my opinion the resistor network is defective.
Replace it !!!!.
Jan 31, 2011 | 2002 Honda Accord
Someone just gave me a Craftsman 32cc blower without the manual. What fuel does this use?
IF it says 4 CYCLE then it uses regular gas.(87-89 octane unleaded) Another sign to prove it's 4 cycle it should have a crankcase you keep filled with oil.
Jul 18, 2010 | Craftsman 4 Cycle Blower/Vac
Kirby Suction and Blower Connector
Yes you can. The end of the hose that mates with the suction/blower is flexible. You can use a pair of needle nose pliers to compress the hose end and force it out of the suction/blower connector.
May 08, 2010 | Kirby G4 Bagged Upright Vacuum
Wrong kind of gas
It sounds like you used gasoline without oil in a two cycle engine. If so, the repair costs for damage to the engine, caused by running it without lubrication, may very well exceed the $250 to replace the leaf blower. However, I think it is worthwhile to have the repair shop take a look, anyway, before jumping to conclusions. Bring the leaf blower to the shop, explain what you think happened, and they should be able to check out the blower and advise you, without charging for a complete diagnosis.
Mar 27, 2010 | Ryobi Backpack Blower 25.4cc
Procom QL300TYLA Heater Logo
52 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
