Question about Cutler Hammer Electrical Supplies
We are unable to get power to one specific area of the house. I did reset the circuit breaker associated with that area. Nothing works. I do not have power in that area. This is a brand new unit in a brand new house installed less than 2 months back. My email Id: ppc_rao@hotmail.com
  • 760 Answers
You may have arc fault breakers in this area. Be sure to unplug all devices and try to reset breaker again. Some brush type motors will not work on arc fault breakers. If this is a brand new house then call the builder back and let him get the electrician back in.
Posted on Sep 24, 2010
Where is the rear bedroom slide reset circuit breaker switch on a 04 fleetwood revolution
There is a fuse panel that houses the slide control and the leveling system. Check your manual for its location, but usually under the coach below the driver area...
Mar 26, 2017 | RVs
The control panel on my oven doesn't seem to be working. I pressing COOKING MODE for 5 seconds and nothing happens. The display just blinks once in a while.
In the power panel on your house. There are two circuit breakers with their handles joined.One of these breakers has tripped internally which will stop the heating elements but not the control panel or oven light since they work on 120 volts. Reset the breaker or replace it.
Feb 02, 2016 | Bosch Ovens
Checked the well pump and its working also reset the house breaker and still no power on one side of the house
Check both sides of main breaker, if no power on line side, call power Co. If no power on load side it's the breaker. Call power Co they should check it for free
Nov 21, 2015 | Electrical Supplies
Kenmore Series 80 Dryer won't start after Circuit breaker was tripped
A breaker thrown that many times indicates a serious electrical problem. You need to have the problem taken care of by an electrician. You should be worried about the safety of yourself and your family.
That being said, I would guess that breaker has gone bad and needs to be replaced.
Dec 18, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
No power
Hi Lawrence, this is AP! Thank you for your post.
I understand you are having trouble with your Frigidaire electric dryer. Without knowing the specific model number there are still some troubleshooting tips I can recommend. Make sure the dryer is plugged into the outlet, and plugged in correctly. Check to see if the house fuse is blown or circuit breaker tripped. If so, replace fuse or re-set circuit breaker. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the dryer may turn but will not heat. Check and replace fuse in fuse box if necessary. If the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer. Circuit requirements are individual 30 amp. branch circuit fused with 30 amp. time delay fuses or circuit breakers. Your dryer requires a power supply of 240 volts to operate. Make sure that the electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. If needed have a Licensed Electrician check to make sure it is on a circuit by itself.
Lastly, the thermal limiter could have tripped or there is an internal problem with the dryer. A thermal limiter automatically turns off the motor (electric dryers only) in the unlikely event of an overheated situation. If this is the case I would recommend contacting an authorized service for repair as this is not a typical DIY project. Contacting an authorized technician can ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds.
You can use the link below if you need assistance in locating an authorized technician in your area. I hope this information proves helpful for you.
http://www.frigidaire.com/Owner-Center/Locate-Service--Parts/
Mar 19, 2014 | Frigidaire Electric Dryer
House power tripped After power restore all the
You might try turning off power to it by flipping off the specific breaker that serves the unit. Leave it off for 2-3 minutes, turn it back on and see what you've got. If you have a manual, it could be there is a reset button, but I have no idea. . .
Oct 21, 2013 | Whirlpool Kitchen Ranges
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
Why do i get power at the 120v outlet but nothing works when its plugged into the outlet
It sounds like a bad neutral wire. Somewhere the neutral is not properly connected. Most residential wiring operates on a 240 single phase system comprised of two seperate 120 volt legs. Connect between either leg to the neutral gives you 120 volts.connect btween the two legs gives you 240 volts. If the neutral is not present the circuit will search out the other leg to try to complete the circuit causing dimming of lights extremely bright lights and all around chaos. Check ahead of the main to see that the voltage is correct. Check each leg to neutral with a voltage tester. Have some one turn some lights on and off while checking as sometimes a load is required to get fluctuating readings. If the reading fluctuate wildly the problem is between the power grid and the panel. If not recheck on a a couple of breakers and if the readings fluctuate it is on your side of the system.
. Hope this helps
. Bob
Nov 21, 2011 | CUTLER HAMMER BR4040B200V BREAKER CIRCUIT...
Need to reset circuit breaker
  • 1 Turn off the light switches and unplug appliances in the room that has lost power.
  • 2 Find your circuit breaker box and open the cover.
  • 3 Locate the tripped breaker. Circuit breakers are small, usually horizontal switches labeled by the areas of the house they serve (for example, "kitchen," "bathroom" and so on). The tripped circuit breaker will be in the "off" position or in a middle position between "on" and "off."
  • 4 Reset the breaker by moving it to the full "off" position and then back to "on." That may clear an overload and return power to the room. If the breaker re-trips, you may have too many lamps and appliances plugged into the circuit; a damaged cord or plug; a short circuit in a receptacle, switch or fixture; or faulty wiring.
  • 5 Identify and correct the malfunction before resetting the breaker.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Sep 25, 2010 | Computers & Internet
    Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
    • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
    • Make sure the clock is set.
    • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
    • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
    Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Electrical Supplies Logo
    358 people viewed this question
    Top Cutler Hammer Electrical Supplies Experts
    Steve
    Hippy_dd
    Craig Butler
    Craig Butler
    Are you a Cutler Hammer Electrical Supply Expert? Answer questions, earn points and help others
