Question about Radio Shack Pro-96 Scanner
Turn knob no volume on scanner - Radio Shack Pro-96 Scanner
    Genius:
  • 1,274 Answers
Hi, my name is John. Try a external speaker on it and see if you still have problem, if so let me know, will have further if you need it......Will post it here....Rate this solution on the four thumbs-up......hope this was very helpful.......John
Posted on Sep 10, 2010
Can the radio volume be tighten? The volume button will not change the volume unless I turn the knob many times.
the knob may be slipping on the stud it turns for the volume. you may need a new knob.
Sep 10, 2014 | 2010 Pontiac Vibe 1.8
Need to replace volume potentiometer on BC-60 XLT scanner
make a trip to radio shack for a replacement volume control..
Feb 02, 2014 | Uniden Radio Communications
Scanner is not picking up anything
it should have a squelch knob . Turn it all the way up and try your scan again. Also turn your volume up a little.
Jan 13, 2013 | Uniden Bc125at Handheld 500 Ch. Special...
How do I turn off the demo mode in my jvc kd-hdr44 radio deck?
Press and hold MENU. Turn volume knob to select group, press volume knob to select item, turn volume knob to select, and then press volume knob to save.
Mar 01, 2012 | JVC Car Audio & Video
How can i stop the squelch ive tryed turning the sqcuelch doesnt help
Plug the AC adapter into the back of the scanner and into a wall electrical outlet. Screw the antenna into the receptacle on the back of the scanner (extend the antenna to full length for best reception).
  • 2 Set the squelch level to allow signals to be heard by turning the squelch knob counterclockwise. Rotate the volume knob clockwise until you hear static. Slowly turn the squelch knob clockwise until the static noise disappears.
  • 3 Start programming frequencies into the scanner by pressing the "Manual" button.
  • 4 Press the up arrow or down arrow key until the channel you wish to program is visible on the display.
  • 5 Use the numbers on the keypad to enter the frequency for the local transmitter you wish to receive.
  • 6 Press the "E" key to complete the process of entering the frequency.
  • 7 Repeat steps 3 through 6 for each additional frequency you wish to monitor.
  • 8 Press the "Scan" key to start the scanning process. The scanner stops on a channel when it detects a signal strong enough to hear over the squelch setting. Two seconds after the signal stops, the scanning process resumes.
  • Dec 06, 2011 | Uniden BC248CLT Base Scanner
    How to set digital clock on ix35 Hyundai highlander
    Turn the radio on.
    Hold down the volume knob for 3 seconds.
    The display will come up Volume Setting
    Rotate the volume know clockwise until the display switches to time setting.
    Push the volume knob.
    Rotate the volume knob to select the hour
    Push the knob
    Rotate the volume knob to select the minute.
    Push the knob.
    Done.
    Nov 30, 2010 | Car Audio & Video
    I Have a Radio Shack Pro 95, thats loud or freaking loud.
    Could be that you wore out the volume knob, or may have turned it too far in either direction. If its the knob itself then depending on your experience working on electronic equipment and the ability to get a replacement knob you can maybe fix it yourself or may have to send it into Radio Shack for them to repair it.
    If the knob turns real easy you probably have a worn out knob.
    Jun 05, 2010 | Radio Shack Pro-95 Handheld Scanner
    No or low sound/Volume knob may have loose connection
    That sounds like a bad solder joint where the knob is attached to the board on the inside. Depending on how long you have had your Scanner, you may be able to return it to Radio Shack for another one or they may want to send it in for repair.
    If you have had Experience in working on Electronic devices you could probably open it up and re-solder the joint yourself, but ONLY if the Scanner is OUT of warranty would you want to take that route.
    May 15, 2010 | Radio Shack Pro-82 Scanner
    How to progam a bearcat police scaner
    To program known frequencies into your BC370CRS:
    - Slide the MODE switch to the "Scanner" position.
    - Press and hold the POWER button momentarily to power the scanner ON.
    - Turn the SQUELCH knob slowly to the left until scanning stops and you hear a hissing noise.
    - Turn the Volume level down to a comfortable level.
    - Turn the SQUELCH knob to the right - slowly, until scanning resumes.
    - Press HOLD.
    - Press E (PGM).
    - Press 0, 1.
    - Press HOLD.
    - Enter your first frequency, including the decimal point (EX: 158.075).
    - Press E (PGM).
    You've just programmed channel 01. To contimue programming, press the up arrow to advance to channel 02, press HOLD, enter your frequency, etc.
    When you're finished programming, press the SCAN key.
    Need the manual for your scanner? You can download and print it here:
    http://www.uniden.com/pdf/BC370CRSom.pdf
    For a comprehensive database of active frequencies in your area, visit:
    www.RadioReference.com
    Please contact me if you have any further scanner questions.
    BillB
    Jan 08, 2010 | Uniden BC370CRS Base Scanner
    Mercedes e240 car radio
    check on the capacitors or audio ic of your car stereo they maybe defective,
    Nov 05, 2007 | Radio Communications
    Radio Shack Pro-96 Scanner Logo
    54 people viewed this question
    Top Radio Shack Radio Communications Experts
    Jason
    john milligan
    Steve
    Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
