Question about Karcher Garden
My Husky 1800 electric power washer won't draw detergent. It's probably stopped up. How do I get into the machine to repair it. Is there anything I should look for. Unless you have another idea. Thank you, Bob Miller Lapel, Indiana
3 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: I have a 2200 Troy Pressure washer, I cannot get
Dismount the bolt that is use to connect the soap line.Turn on the washer and test if you fill if is "suction" intake air.Sometimes it becomes clogged so see if anything is clogging the suction .Is that not work the suction system is bad.
Posted on Nov 17, 2010
  • 174 Answers
SOURCE: my karcher electric power washer will not
If you have used an extension cord with it you have destroyed the motor. If not, the bypass valve is stuck. On THIS diagram, section 2.1, part number 1 needs lubrication with a good waterproof grease.
Posted on Aug 15, 2009
Husky 1800 Pressure Washer motor will not turn off when wand trigger is released
I think you have one of two things going on hear, an overpressure problem or a carburetor issue with the engine.
Jul 25, 2017 | Husky Garden
No pressure on my husky power washer 1650
Basic Issues As an electric-powered washer, a circuit overload may cause your Husky 1600 to shut down or prevent it from starting. In this case, check your home's electrical service panel for a tripped breaker or a blown fuse -- the 1600 requires a dedicated circuit rated at a minimum of 15 amps. To prevent a blown fuse, avoid using other large devices on the same circuit as your washer. If you use an extension cord, it must be rated at 15 amps as well. Before moving on to more complex troubleshooting measures, check the gun safety trigger and release the lock if your 1600's trigger will not move. Water Woes Releasing air from the pump serves as a simple fix for low-pressure water output; remove the wand and allow the washer to run as you depress the gun's trigger until the water output normalizes. If your water output seems to lack detergent, ensure that the clear tube is securely connected to the detergent nozzle. Likewise, check the connected water supply and make sure the faucet is fully open and that there are no kinks in the hose to ensure optimal pressure. Using a shorter garden hose makes for stronger pressure, as well -- Husky recommends a hose with a maximum length of 50 feet for a city water supply. Clearing Clogs If your Husky 1600's pressure seems lacking or its water flow is obstructed, clean the nozzle by removing the wand from the gun, clearing the nozzle hole of obstructions with a stiff wire and flushing the nozzle with clean water. Similarly, clean the washer's inner water screen, located behind the garden hose connector, by removing the screen and flushing it with water. This also corrects low or irregular pressure and may remedy a unit that does not stop releasing water when the trigger is released. Model HD1600 features a chemical solution reservoir with a similar screen; clean this screen in the same fashion if you experience chemical intake issues. More to Consider If your power washer issues go beyond troubleshooting basics, contact Husky's customer service department at 800-381-0999. Husky recommends contacting customer service when your 1600 has problems with its pump, bypass valve, discharge valve or manifold assembly, for instance. Because this series of powerwashers was originally offered around 2001 through 2008, Husky's one-year limited warranty no longer covers the cost of replacement parts or repairs.
Sponsored Links
Sep 29, 2016 | Garden
Detergent won't go through siphoning tube
it will only draw detergent with the large black nozzle or the nozzle wide open with not draw with high pressure
May 20, 2012 | Honda Black Max 2600 PSI Pressure Washer
Whirlpool wtw5tesvno
Hello.
Whirlpool washers are available in many colors and with different options, including various tub sizes, front or top load styles, a fabric care system, high efficiency wash features and energy, time and water sensors. The washers may be purchased in department stores, home repair stores and online. Many are Energy Star rated. However, the washing machine may malfunction occasionally and not agitate or spin. If this occurs, some troubleshooting steps may be useful in solving the problem.
1 sure the washer has electrical power and is connected to a grounded electrical supply. Replace or reset the circuit breaker or fuse if needed, particularly in event of a recent power outage. Make sure the washer lid is closed tightly before use; the washer won't work if the lid is open.
2 void selecting the following cycles: "Extra Low,, "Low," "No Spin", "Delicate," "Casual/Perm Press" or "Hand Washables." All of these cycles use little to no spinning or agitating during the cycle. Select the highest possible spin cycle for the fabrics being washed.
3 pen the washer lid and redistribute the load; unbalanced loads may cause the washer to stop or slow down. Add additional items if only one large item,
such as a rug or blanket, is in the washer.
4 Use only the recommended amount of laundry detergent, as excess sussing can reduce the overall spin speed or cause the washer to stop agitating. If the Whirlpool washer is a high-efficiency model, use only high-efficiency laundry detergent.
5 Examine the drain hose and straighten if kinked. Remove any possible obstructions and ensure the end of the hose is no more than 96 inches from the floor, as this will cause water to flow back into the washing machine.
Thanks.
Nov 13, 2011 | Whirlpool Washing Machines
The detergent draw won't pull in and out easy. You've really got to 'pull' to get it open and 'push' really hard to make it close.
theres is probably soap inside the track where the drawer slides, just clean it out and you should be fine.
Jul 09, 2011 | Asko W6761 Front Load Washer
My washer stops and suds flash on the display
Sud: Suds lock (overdose of detergent detected during wash cycle)
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
Possible causes/procedure:
If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
Use your tech sheet for diagnostics it is behind that panel the Handy Hippy showed you how to take loose (see above link) Use this MANUAL for Duet sport as a guide for repairs
Thanks for using fixYa
Jan 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water runs out of the detergent compartment when the washer is filling.... what is the problem?
probably soap blocked at back of draw, remove draw and clean out, there is also normally a small pipe where the conditioner goes in and this tends to block
Dec 17, 2009 | Samsung WF337AA Front Load Washer
Do not know how to work power washer
Dear Carrie688,
I cannot for sure understand your problem. You say, you do not know how to WORK power washer. Does WORK mean FIX...or USE???? I will assume that you wish to know how to use it.
First without water connected and without gun connected...switch on the machine. If it turns, then this means the electric motor is OK. Now connect the hose and gun. Connect water supply. Now always start the machine with gun open. This will help to remove air from system. When pressure builts up, close gun, and machine must stop instantly. If machine does not stop, open the gun again and switch off the machine. If the machine continues working when the the gun is closed, this will result in a lot of damage. I do not know what model you have, because also there are old models that when gun is closed, the machine keeps running. I assume your model is recent. So the machine will stop when gun is closed. Now when finished, switch off machine and electricity. And most important release pressure from gun. Do not store machine with pressure still in it. This will damage machine and it is not safe.
Now if you have detergent, this can only work on low pressure. There are bigger machines that detergent works on high pressure. But the normal system is that detergent works on low pressure. Also before storing, pass fresh water to remove all detergent from pump of machine. Never store a machine with detergent in its system.
Regards,
Fulltech.
May 13, 2009 | Karcher K2.26 Electric Power Washer
Ryobi 3000 psi pressure washer detergent injector
Most detergent injectors work by the venturi system. That is that the detergent is drawn into the stream by the forward flow of the water thru a very narrow port after the water passes thru the pump. This system works best when the pressure at the tip of the wand is low. Trying using a very large tip to draw in and apply the detergent, then remove injector and rinse with high pressure. Not good for the pump but to apply soap reliably under high pressure the soap needs to be injected through the intake of the pump. enjoy
Oct 13, 2008 | RTO 1800 PSI Pressure Washer
Garden Logo
221 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
