Question about Samsung LN52A650A LCD TV
LN52A650A closed caption will not turn off. Tried resetting to factory setting and that didn't work.
    Top Expert:
  • Samsung Master
  • 14,553 Answers
CLOSED CAPTION can come from two sources:
1.) in the set there are settings for it, make sure not on or set to CC1
2.) If you are using a box to provide signal to the set--all boxes have the same option--they have Closed caption and SAP---
Check the set menu first and then the box menu---one of them is engaged.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
If you have questions comment here and I will answer--I am here to help.
SD TECH
Posted on Sep 10, 2010
The television stays in closed caption mode regardless of the settings. Is there a way to reset it to factory default
try turning off the caption through the remote of the menu. to reset it to factory settings, go to menu, then settings, then there should be an option to reset the tv. If this doesn't work look through your manual. Sometimes you have to hold the power button for some length of time or the menu button on the tv. if these methods don't work, tell me the model and make of the tv.
May 28, 2011 | Televison & Video
I can't turn off closed captions please help
Hello
There is only one way, and that is to unlock the closed caption feature by entering the code. By entering the code you have set to lock closed caption you can set it off. If you have forgotten the password you have entered, do the folloing ot unlock your TV, and then reset all the features later.
if you ever forget your
code, the 0, 7, 1, 1 code is the factory
default and can be used to
enter and create a new access
code.
After unlocking the code you have to reset all the settings again if you wants.
OK.
Dec 26, 2010 | Philips 32PT6441/37 32" TV
Closed caption will not turn off in any menu options.
Leave it off unplugged from the mains overnight. This should reset the TV to factory settings removing the closed caption problem.
If this fails you should be able to find factory reset in the set up menu.
Jul 27, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
I have a black rectangle covering the center of the screen from top to bottom. How do I get rid of it? I tried the menu for Closed Captioning but it did not seem to work.
Try turning off the closed caption and text also check v chip, if you have a channel or channels blocked it could cause a black rectangle to pull up on the screen, if that doesn't work try resetting the unit to factory settings
Jun 16, 2009 | Toshiba 50HP66 50 in. Plasma Television
Can't Turn off Closed Captioning on Sanyo 36 in TV AVM-3658
Hi Hfrohman, This may sound crazy, but, press and hold the power button on the TV while unplugging it, continue to hold power button for 60 seconds or more. Release it and plug TV back in. Sometimes that will clear the settings.
I hope that works for you.
Jun 26, 2017 | Sanyo AVM-3658S 36" TV
Viewsonic n3251w will no longer display Closed Captions
You can reset your viewsonic remote control by removing the batteries, and holding the power button down for 10 seconds. Just 10 minutes ago I repaired my remote, which was doing absolutely nothing, not even turning the set off and on, Called Viewsonic, they told me this, and it worked ! Yay !
Dec 11, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Closed caption
maybe in cable box setup?
May 27, 2008 | Samsung DLP HL-P5663W 56" TV
Closed captioning
I experienced the same problem for about an hour before recognizing that the "continuous on" closed captioning had been activated on my cable box, not the TV. The signal feeds through despite the CC settings on the TV. If you haven't already, try checking the CC settings on whatever device is supplying your video.
Apr 22, 2008 | Hitachi P42H401 42 in. Plasma HDTV
Can't shut off closed caption
I have the JVC I Art 46" TV. The Close Caption was turn on accidentally by my grandson. After lots of searching for the original remote. I called JVC Customer Support. He told me to change the Close Caption settings to CC2 and T1. That fixed the CC without having the original remote.
Apr 10, 2007 | JVC AV-32F704 32" TV
Samsung LN52A650A LCD TV Logo
146 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
