Question about Dryers
I have an older kenmore electric dryer that won't heat. What commonly goes out on these dryers. I tested the heat coils, and both terminals have 120 volts. Also tested high temp overload and it's OK, and thermal fuse is OK. I am searching for some kind of problem that I am not seeing. Thanks.
  • 3 more comments
  • dharmon3561 Sep 10, 2010
    This is my daughter's dryer and when I go back to her house in the morning I will do what you suggested....ohm out the coil and make sure that there is continuity. I did check and had 240v across the coil terminals, but I will check again inthe morning. I will get back with you tomorrow, Friday 9/10. thanks
    OK. Thanks.
    Just wanted to let you know that I finally found out what the problem was. I had to replace the upper thermal cut out. It is now working properly. thanks for your help.
    Danny
    yes
    Just wanted to let you know I had to replace the upper thermal cut out. Problem solved. Thanks for your help. Danny
  • Dryers Master
  • 43,501 Answers
Check that you 240v ACROSS the coil terminals...you can have 120 to each side and still not have 240 across them...also check that you have resistance through the coil...in other wards ohm out the coil and make sure that there is continuity....
Here is a tip that I wrote about electric dryers not heating
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} electric no heat
heatman101
Posted on Sep 10, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Sep 10, 2010
    I am self employeed doing all kinds of mechanical work and am going to my brother-in-laws to change a well pump on Sat. driving there three hours on Fri. night...be patient It may take me a bit to get back to you...
    Thanks!!
I have a beko dcu9330 dryer givin n heat. changed blown sensor and tested both sesors, still no heat, no power getting up to heater. whats next step?
Electric dryers have a heating coil over which air is drawn to heat it up. Unplug your dryer and use a continuity tester to check the heating coil for breaks. Attach one lead to one coil terminal and the other lead to the opposing terminal. No reading indicates a burned out coil (very common). All coils are replaceable.
Oct 22, 2014 | Dryers
Dryer is not getting hot. Tested the heater Coil and it read 16 and my understanding is that a 10 is acceptable, so now I believe it could bet the Thermostat. What are your opinion and suggestion ?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 07, 2011 | Kenmore 659 Electric Dryer
2005 Whirlpool Gas Dryer. It won't heat. The coils won't glow. Had the fuses, ignitor, and coils checked and are ok. Could it be the timer? How do I check it?o
heatman101-
Jul 22, 2011 | Whirlpool LGQ9858P Gas Dryer
I have A kenmore elite gas dryer model # 110.75062501 it won't heat please help
heatman101;'
Jul 18, 2011 | Kenmore Dryers
Kenmore Gas Dryer 11072212101 won't heat. we
heatman101.,/
Jun 30, 2011 | Kenmore 73102 Gas Dryer
Kenmore dryer not heating up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 15, 2010 | Electrolux AEQ8700F Electric Dryer
Kenmore dryer, the dry runs, but does not heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 11, 2010 | Kenmore 63942 Dryer
Change thermostat, tested heater coil, dryer still won't heat on a Kenmore stackable
heatman101
May 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore dryer, not heating and blower not working
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 09, 2010 | Dryers
Dryer goes on. doesn't dry
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Nov 28, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
Top Dryers Experts
