I have a Crossman 357 177cal. Pellet gun.. The problem I have is the the clip securing the barrel shut has lost a spring and the barrel is not securing itself shut.. You can touch the top of the barrel and it opens.. Who can I contact so I can get it fixed.. Thanks
[email protected]
Assume this is a conventional air weapon powered by a spring.
I suspect the main pressure washer is defective. The gun will need dismantling and a new washer fitted. It could be wise to also replace the spring and the breech seal.
Time to buy a new model. I had 2 of those with similar problems and couldn't find parts. Try the CO2 model 1088. I'm happy with mine. Spray the seals with silicone spray monthly or every 2 cartridges.
This gun is a break barrel or break action gun. Hold the stock in your left hand and pull down on the barrel with your right. Once the barrel is down you feed your pellet right into the chamber. Pull back up to set the barrel ready to fire.
It looks like you pull back the slide, drop in your pellet, hit the slide release and you are ready to fire, 400 FPS, single stroke pneumatic, Made in germany, recoiless, formerly the Marksman 2004, $50.
The barrel pushes the piston back when you **** it.
The seer grabs the piston to hold it.
It sounds like you have an engagement issue between your seer and piston.
Often there are springs which hold the triger paul and seers in place. You may have lost a spring which isnt allowing your trigger mechanism to reset after the trigger is pulled. This results in the trigger being permanitly in the fired position.
Good luck and hope this gives you something to look for
