Question about Delta 15 - 126 Drill Presses
Model OR-1412 Orbit Machine Tool Drill Press wiring Diagram. I have two broken switch wires and can not locate their source.
5 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: need information about the motor for an orbit
Look at eReplacementParts.com and the parts diagrams
Posted on Nov 10, 2010
  • 10865 Answers
SOURCE: Who and where was this drill press made? Anyone now?
it was made by craftsman [sears] but it was not made for long due to poor design
Posted on May 10, 2009
  • 582 Answers
SOURCE: Need manual for Delta Drill Press Model 17-965 do
IF THIS IS AN OLDER DRILL PRESS YOU CAN GO ONLINE TO DELTA AND THEY SHOULD HAVE ANY THING YOU NEED. I HAVE NEVER HAD A PROBLEM WITH THEM SUPPLYING THIS MATERIAL; AND YOU SHOULD BE ABLE TO PRINT ONLINE
Posted on Aug 19, 2009
al_kupchella
  • 843 Answers
SOURCE: i need a chuck wrench/tool for a duracraft drill press
Are you talking about the chuck key? That's the little wrench with a collar of gear teeth on it.
There are only a few standard sizes plus a couple of odd-balls. Last time I looked, Sears carried a good selection. If you have the old one, take it with you to the store. If you don't have the old one, find a way to measure or approximately measure what you need. Another chuck key that doesn't fit can be a useful reference. If you can find something (maybe a drill bit) that is a close fit into one of the three holes in the chuck, that can be useful too.
Posted on Jan 19, 2010
Need Wiring diagram for drill. Have a blue wire from magnet switch that is loose and I am not sure where it goes.
hi if you cant find a diagram try using a magnifying glass and look for broken solder . i have done this a couple of times when needed.
Apr 28, 2016 | Drills
The variable speed on my black and decker drill not working
FIRST it depends on the model Machine most cases its difficult and only left to replace the complete switch because there is inside OR OUTSIDE the switch a mosfet used look right corner downunder the photo how it looked always this mosfet is mounted with a screw on a heatsink if its insite the switch the heatsink is long and on the switch heatsink is outside the switch on if its outside replace the yellow , blue and black cable as its mounted if all black wires then look of the model code name of the mosfet where gate , drain and source are on the wires . in most case the mosfet has sometimes not a standard code to get from Ebay or a shop and also not to get by the importer.
Feb 03, 2016 | Speed Drills
Wiring diagram of hammer drill model CD 50
I am an authorized DeWalt and Black and Decker dealer and that tool does not come up in my listings. If it is a non USA spec tool I can not access break downs or wiring diagrams for it.
Aug 18, 2012 | Black & Decker Drills
My drill press runs backwords
was this drill press recently rewired or had a switch installed. The only thing I can think of is that it is wired incorrectly. Recheck the wiring. Let me know if you need more assistance. Usually on the motor cover there is a wiring diagram for the proper voltage and rotation.
Mar 15, 2012 | Drills
My dewalt cordless drill stopped working in the middle of drilling a hole. is the trigger faulty/broken?
First before you open the tool ground yourself. The switch is probably static sensitive. Now open the tool and check for wires that may have come loose from the switch, or motor brush area. If no bad wires make sure the switch terminals are ok (not broken or bent and are tight enough to make contact with the batery terminals). Next check the brushes and make sure they move freely in the brush holders. You didn't state the model so it may not have brushes you can access. If all that is good disconnect the motor from the switch and secure the motor in a vise. Take wires with alligator clips and connect the battery directly to the motor for just a second to see if it runs. If the motor runs you have a bad switch assuming your battery is charged.
Dec 08, 2011 | Dewalt 18 Volt Compact Drill Kit
4270-21 Compact Magnetic Drill Press: mag base will not hold at all...
If I'm not mistaken, these drills use an electromagnet. Start by measuring the current when the magnet is switched on, but not the drill. If you don't have a current meter, just plug the drill plus an incandescent light into a long lightweight extension cord. You should see the light dim a little when you switch on the magnet. If the light doesn't dim, you just aren't getting power to the electromagnet, and it's probably a broken wire or a bad switch. If the tool has it's own fuse, I would think it would be for the drill only, not the electromagnet.
May 06, 2010 | Milwaukee 4270-21 Compact Magnetic Drill...
Need wiring diagram for switch on Cat #5378-20 SN 897D705030452 Hammer Drill
Go to Milwaukeetool.com and under service/manuals you can type in your model number and download the wiring schematic for this tool. If I have helped you with your request would you please rate this response accordingly and thank you.
Oct 25, 2009 | Milwaukee Tool Drills
Delta 15 - 126 Drill Presses Logo
1,516 people viewed this question
Top Delta Drills Experts
Bill Boyd
pete musca
pete musca
Level 1 Expert
Are you a Delta Drill Expert? Answer questions, earn points and help others
