Question about Dishwashers
Bosch dishwasher SHU3032UC/U12: Gets stuck mid cycle. Timer does not move, but will continue if turned manually. Will stick again. Thought it might be the timer (control unit), but now am wondering if it could be the heating element or thermostat.
  • Dishwashers Master
  • 2,605 Answers
Welcome to FixYa.
Based on you description of the timer not advancing you`re on the right track when you said "Thought it might be the timer (control unit), but now am wondering if it could be the heating element or thermostat"
I suspect the thermostat isn't satisfied when heating the water, hence it get`s hung up trying to heat in the part`s of the cycle it`s called for.
It very well could be caused by a faulty flow switch, NTC or heater as well but not very likely.
The SHU 30** series Bosch dishwashers with a rotary dial timer have very few if any, issues with the actual timer or element but they do with the thermostat within the door panel.
If it ( the thermostat ) is not satisfied the water may heat but not be indicated via the thermostat, hence timer will not advance.
Here`s what you can try. If you have any hesitation or reluctance to service this yourself please call in an authorized B/S/H/ appliance technician.
**Turn off the breaker at the service panel before attempting any service suggested **
  1. You will require a #20 torx screwdriver to remove the door panel by taking out the screws around the panel, except the ones along the top ( watch the edges they are very sharp )
  2. Once the panel is removed you should see the thermostat over by the detergent dispenser clipped to the inner door, remove it and test it. You`ll need a ohm meter/multi-meter plus a lighter or match to heat it up to see if it open`s & closes.
Example...
Bosch dishwasher SHU3032UC/U12:  Gets - 5e74230.jpg
**NOTE** it can occur the thermostat can become loose and detach from the bracket which holds it in place, this too can manifest in the sysmptom of the timer not advancing.
Let me know how you make out and what you find.
Thank you for choosing FixYa and Good luck.
Regards,
Macmarkus :)
Posted on Sep 10, 2010
Testimonial: "Wow, loads of good inf to try to fix my dishwasher! I appreciate the very detailed answer to my question."
  • rstaines Sep 10, 2010
    I have the same model of d/w with the exact same problem as Dendra13. I followed your advice, located and removed the t-stat. By the way, there was a white, slightly creamy substance between the t-stat and the door. Is this normal? I wiped it away with a tissue, but does it serve a function? Anyway, how do I test the t-stat? Am I checking for continuity?
    Thanks, Roger
How do I fix the heater in my Bosch shu5306uc / u12?
SHU5306UC-12 BOSCH DISHWASHER Manual - Sears ...
www.searspartsdirect.com > Kitchen Appliance Parts > Bosch Parts
Download Manual for Model SHU5306UC-12 BOSCH DISHWASHER.Sears PartsDirect has parts, manuals & part diagrams for all types of repair projects.
Aug 01, 2015 | Bosch Dishwashers
Bosch shu4006uc dishwasher timer problem
REPLACE YOUR MODULE. IM A OLD BOSCH TECH. POST 4 THUMBS FOR THE INFO THANKS
Feb 08, 2010 | Bosch SHU4006 Dishwasher
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Bosch Dishwashers
Timer (cycle knob) gets stuck on occaision and
possible that its the timer more likely an internal blockage main wash water level not being reached and activating heater if the water does not reach temp selected for any reason the appliance will stick at the heating phase also if your dishwasher is getting old over 10 years wiring loom in door may be breaking down, will need service to sort out
Nov 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
STICKS on cycle, wash, etc. If manually moved
Do you mean the timer or control dial sticks. If so then it may be the timer mechanism itself.
Make sure that when you are skipping a turn on the timer that the machine is actually performing that particular task of the cycle. For example if the timer gets stuck before the drain cycle, and you manually skip forward to it, that it actually drains the water out.
If so then it is most likely a worn timer mechanism which sticks.
Ash
Oct 23, 2009 | Frigidaire Dishwashers
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Dial Timer sticks between wash or rinse modes
Hello. Is the water getting hot? Usually the timer won't advance because it isn't getting a signal from the thermostat that is on the bottom of the tub, so it thinks that the water isn't hot enough to go through the rest of the cycle. That is if the water is hot. If it isn't hot then you may need a new heater. You may or may not need a new timer. Try the thermostat first because that is usually the thing that goes out and it is less expensive than the timer. You can order it from www.coastparts.com or www.marcone.com .
Let me know if you need anymore help.
Dec 07, 2008 | Dishwashers
Replacing Control Module
Sergio,
Did you get your problem resolved. By now I think you have found the two screws on the sides of the inter part of the door. Did replacing the module fix your problem. I have the same problem.
Mike
Jun 28, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
1,382 people viewed this question
Top Dishwashers Experts
Owen Barnes
