Question about Solis Palazzo Espresso Machine
Solis pallazo rapid steam. I can't remember how to clean the system
  • 1,089 Answers
Descaling the Palazzo: The Palazzo is programmed to descale the boilers on its own, when set in the correct mode. You program the machine to descale it's self, do the following. With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next, have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz's. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don't turn off anything until the machine stops on its own. This will clear the descale light. Refill the water tank again with fresh water and your ready to go.
Posted on Oct 25, 2010
Super automatic espresso machine leaks water into drip tray and onto counter when I use the frother
The stream valve is leaking and probably needs to be replaced. If you remove the top cover it is visible.
Sep 12, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Manual
Hold the coffee button down from the moment it is pressed till the water in the cup reaches the desired volume, then release. It will now save that volume amount to memory.
Jun 13, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Container leaking water
Ther is tank seal that is at the base of the machine where the tank goes on . it will dry up , waer out and leak overtime.
Apr 20, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Solis palazzo not producing coffee
I think the blockage might be at the brew unit, remove unit and check the screen under the red o-ring, connected to that is the chute that leads to the espresso spout. That tube might be blocked, there are 2 screws holding that piece together, be careful when you remove them do not lose the spring and ball in the fitting. Clean tube and reassemble.
May 24, 2012 | Solis Palazzo Rapid Steam Palazzo Fully...
Steam/water valve leaks water, only fills coffee to 50%, help? I have completely removed steam valve assembly to clean and reassemble. Leak persists, suspect o-rings?
Hi
If your water valve is cream or black colored, you need a new manifold. They will get hair line cracks if you steam, but don't cool them down after steaming by running cold water through them. If you have one of the new brass(silver) manifolds it could be your O-rings but i doubt it.
Oct 07, 2009 | Solis Palazzo Espresso Machine
Need to buy water tank of solis pallazzo coffee maker
The only importer of solis I know of is Barratza.com, they will have the parts needed.
May 29, 2009 | Solis Master 5000 Espresso Machine
Solis rapid Steam stuck in descaling cycle
try to run a new descaling to see if it works normal again.
/Mirran
Sep 22, 2008 | Solis Palazzo Espresso Machine
Solis pallazzo rapid steam
Hi Alex,
Try to prime the machine.
May 20, 2008 | Solis Palazzo Espresso Machine
Solis Palazzo with rapid steam
Not sure who the distributor is but I've had luck calling 888-437-8340 and speaking to Josh or Jerry. So far they've been able to talk me through all problems.
Good luck
dgsrgr8
Jan 20, 2008 | Solis Palazzo Espresso Machine
Solis Palazzo Espresso Machine Logo
406 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
