Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
I have a Sony Handycam DCR-HC42 Mini DV Camcorder and i inserted a pro memorey card then my camera wouldnt turn on! i charged it and i reset it but nothing is working. can you please help me?
    Genius:
  • 1,812 Answers
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 10, 2010
Do i need a sd card o make camera work
You can't make the DCR-HC42 work with an SD card. This camcorder uses DV tapes, or Memory Stick Duo or Memory Stick Pro Duo memory cards.
Jun 06, 2012 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
Mar 28, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder LCD goes black purchase 4 year back. Any chance to repair LCD.
If you are able to see picture in the viewfinder (eyepiece) on closing the LCD, then the cable connecting the LCD to rest of the camera has gone bad and needs replacement. Take it to a Sony service centre. They will charge Rs 750 for service charges and about Rs 700 for the cable. You can save the service charges if you replace it yourself, but I'll advise against it unless you are conversant with these sort of precision jobs.
Nov 01, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Dont know how to close sony handycam
Just close the LCD screen or the View finder to turn OFF the Camcorder if you want to turn OFF the Camcorder.
Sep 26, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
When I insert the cassette into the camera it won't close.
Try the following link to troubleshoot this issue:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C190805
Aug 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Camera will not insert tape. Mechanism works OK without tape. Sony dcr-hc42
A C31:40 error indicates that the drum (the spinning video head) is either not spinning or is not supplying a signal to the main computer to tell the computer it is spinning. It could be a bad drum or a loose connection. It will likely take a qualified technician to verify the diagnosis.
Oct 20, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
SONY HANDYCAM DVD610E
Check the battery is charged and properly attached. Is the battery old? They don't last for ever.
Sep 02, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
SONY camcorder DCR-HC42 color stripes
Try with the side display closed. Does the viewfinder show the pix OK? If so, then the problem is isolated to the LCD display. There is a small ribbon cable between the camera body and the LCD that sometimes gets a small crack in it. Replacing the cable usually fixes the problem.
Dan
Jul 10, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
29 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
