Question about Hotpoint VVSR1070D Top Load Washer
Water comes out out the bottom of the washer I have check hose and drain all ok most of the water drain out but when I move the washer you can hear water moving around but you can not see it in the tub it seem to leak out during spinning or draining to spin any thought ? I sure would be thankful for any help
  • 101 Answers
Possible transmision brake shot
Posted on Sep 10, 2010
Washer won't drain
The problem is either your pump or your hoses. This should be an easy fix. All you need is a screwdriver and a bucket to catch water. 1st unplug the machine and remove the drain hose from the drain. Then try to drain the water from the washer by plugging it back in and setting the washer to drain. if no water comes out of your drain hose then you know your plumbing is ok. Next put the drain hose back in the drain and take the cabinet off your washer. You will see your pump with 2 hoses connecting to it. One hose connects to the basket and the other to the drain. Disconnect the hose coming from the basket and if water comes out then you know the basket is not blocked with any article of clothing. If both check out ok your problem would be the pump. Write down the model and serial number to your washer and buy a pump. They are only about $15.00. Remove the old and install the new. Having a repairman install would cost about 150.00, so i advise you to do it yourself or have a friend help
Jun 12, 2010 | GE WBSE2090A Top Load Washer
Water plumb are not working. Does it worth to fix? Thanks.
IF THE WASHER IS NOT PUMPING THE WATER THROUGH YOUR DRAIN, AND YOU HEAR THE PUMP RUNNING, YOUR DRAIN LINE FROM THE WASHER TO THE SINK DRAIN IS CLOGGED. DISCONNECT HOSE FROM SINK DRAIN AND VACCUM OUT, OR RUN A WIRE OR SOMETHING SMALL BUT STIFF TO LOOSEN THE CLOGGED HOSE. NOW RUN THE WASHER AND ALLOW SOME WATER TO BUILD UP IN THE WASHER, IF WATER ALREADY EXISTS THEN TURN KNOB ON WASHER TO DRAIN. MAKE SURE YOU HEAR WATER DRAINING IN SINK AND PROBLEM SOLVED. IF THE PUMP MOTOR IS NOT TURNING AT ALL , BUT YOU CAN HEAR IT ENGAGE, THEN TURN WASHER OFF, TAKE FRONT BOTTOM PANELS OFF, LOOK FOR THE MOTOR AND TAKE YOUR HAND AND ROTATE THE MOTOR CLOCKWISE A FEW TURNS AND THEN COUNTER-CLOCKWISE A FEW TURNS, IT WILL FEEL LIKE A DISC IN THE FRONT OF THE MOTOR. IF YOU DON'T FEEL A DISC AT THE FRONT OF THE MOTOR, THEN LOOK AT THE BACK OF THE MOTOR AND YOU SHOULD SEE WHAT LOOKS LIKE SOME BLADES. NOW TAKE A SCREWDRIVER AND ROTATE IT CLOCKWISE AND THEN COUNTER-CLOCKWISE. MAKE SURE YOU GET SOME ROTATATION WITH EITHER METHOD THAT YOU HAVE TO USE. YOU WILL FILL RESISTANCE AT FIRST, BUT KEEP TRYING TO TURN THE MOTOR. AFTER GETTING IT TO MOVE, TURN THE WASHER ON NORMAL CYCLE AND ALLOW TO RUN. IT SHOULD DRAIN WITH NO PROBLEMS. REMEMBER THIS IS JUST BUILD-UP INSIDE THE WASHER AROUND THE INSIDE OF THE PUMP AREA. ALL YOU HAVE TO DO IS BREAK IT LOOSE. IT MAY SOUND LIKE A HARD TASK , BUT IT IS QUITE EASY. YES IT IS WORTH FIXING, BECAUSE IT WILL COST YOU NOTHING. IT TOOK LONGER FOR ME TO TYPE THIS THAN TO FIX YOUR PROBLEM. TO KEEP THIS PROBLEM FROM COMING BACK, OR COMING BACK MORE OFTEN, ALWAYS SCRAPE EXCESS FOOD IN TRASHCAN AND RINSE THE DISHES OFF WITH WATER BEFORE PUTTING THEM IN THE WASHER. ALSO PULL THE BOTTOM RACK OF THE WASHER ALL THE WAY OUT AND CHECK THE FILTER SCREEN TO SEE IF IT IS CLOGGED. IF IT IS UNCLOG IT . THIS TAKES APPROXIMATELY 30 TO 45 MINUTES, AND SAVES YOU $$$$.
Apr 13, 2010 | Bosch SHU9915UC Dishwasher
Leaks water out of bottom
hi friend,
Evidently you have reason to believe your washer is leaking. Probably there is water on the floor near the machine. Fine, then the first thing is some detective work. with an absorbent hand towel begin to inspect the areas where water enter or leave the washer. Those places are: 1. the hot and cold water inlet hoses located in the back and top of the machine and 2. the washer drain line, located in the back and bottom of the machine.
  • Step 2 One at a time, dry both ends of the hot and cold water hoses. watch for water to bead up. Water may be leaking from more than one place so don't stop with the first leak you find. Inspect all four possible connections and the hose itself. If there is a leak at a hose connection it's an easy fix. shut off the water supply of the leaking hose, unscrew the hose where it leaks and wrap Teflon tape clockwise around the threaded or male part of the connection. inspect the flat rubber washer in the female part of the connection. replace if it seems very worn. re-tighten the connection, dry and turn the water back on. check for the leak to return. If the leak in somewhere on the hose itself you will need to buy a new hose. Hot and cold water hoses are marked.
  • Step 3washingmachine3_thumb.jpg Next we need to check the hose where water drains from the washer. It comes from the washer near the floor level and usually inserts a male into the female of the washer hole. It then moves to the drain leaving the house. Again, dry the entire hose. Then you will have to run the washer. Use flashlight and inspection mirror to help you look for a leak during the draining process. If it leaks at the connection to the washer try reinserting and tightening the retaining screws. There usually are no threads to wrap. If that doesn't fix the leak or if you find a leak in the hose itself you will need to replace it.
  • Step 4 If you still have a leak under the washer it is probably in the drain hose between the drain pump and the outside hose or the short hose between the tub and the drain pump. This may be getting out of your level of competence. But if you want to be a Renaissance Man, give it a try.
    Unplug the machine. Now you need access to the bottom of the machine. depending on your brand you may be able to 1)remove the front by inserting a painters scraper and prying the spring snaps up, 2)remove the back by taking out screws and the rear plate or 3)you may have to go in through the bottom. With help tip it over on it's side. of course the machine will need to be empty of clothes and water as it's heavy enough already.
  • Step 5 However you access the inside bottom of the machine you will see a rubber hose coming down from the tub to a small electric drain pump then a plastic line will leave the pump and go to the back of the machine where it will meet up with the drain line you inspected in step 2. With your inspection mirror and flashlight look for water to indicate a leak. These lines are often held on by metal springs and can be moved or adjusted with open jaw pliers. If you find one of these hoses damaged take it off and bring it with you to your appliance store for a replacement.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • take digital photos before you remove any part. if you get confused you can use it as reference
    • don't work on the inside of the washer with it plugged in.
    hope this helps u
    please rate me.....................
    thank u for using fixya
    regards
    sivaranjini
    Nov 24, 2009 | Maytag Washing Machines
    The washer want drain
    Hi, the problem is either your pump or your hoses. this an easy fix. all you need is a screwdriver and a bucket to catch water. 1st unplug the machine and remove the drain hose from the drain. then try to drain the water from the washer by plugging it back in and setting the washer to drain. if no water comes out of your drain hose then you know your plumbing is ok. next put the drain hose back in the drain and take the cabinet of your washer. you will see your pump with 2 hoses connecting to it. one hose connects to the basket and the other to the drain. disconnect the hose coming from the basket and if water comes out then you know the basket is not blocked with any article of clothing. if both check out ok your problem would be the pump. write down the model and serial number to your washer and buy a pump. Thanks! mannu_rakesh
    Aug 21, 2009 | Washing Machines
    Water won't cut off on super load
    yes raise your drain hose up. do not shove it down the drain to far or the bottom of the hose will be below the water level in the machine. it is called siphoing. you can hear it by shutting the machine off when it is at the cycle you stated and hear it draining. pull the hose up and secure with a strap.
    May 17, 2009 | Washing Machines
    My washer dryer won't drain, is there a drain dial setting? there is a small amount of water that won't drain away. it means the door lock won't release
    Apr 21, 2009 | Washing Machines
    Water still in bottom of tub after drain/spin cycle
    I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
    Feb 14, 2009 | Kenmore 12502 Top Load Washer
    Leaking
    The leaks in a washing machine could be coming from many different places in the washer.
    The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
    The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
    Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
    If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
    Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
    When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
    Aug 21, 2008 | Miele Novotronic Premier 500 Front Load...
    Front load washer not draining
    If the water is not draining the firt thing to check is the pump. take the 2 screws off the front bottom panel and remove it. get a bunch of towels or a wet dry vac ready. the pump should be on the right attatched to the drain hose and the coin/debris cather(a black rubber bladder. Remove the drain hose (use pliers on the clamp and pull the hose off. A lot of water will come out as well. Remove the rubber bladder(coin catcher) clamp with a philips head screw driver and pull it off the pump.Un plug the pump remove the monting screws. Check the pump and the bladder for debris. Look in the pump and make sure the impeller is not damaged. spin the impeller and make sure it moves. if the impeller is damaged then the pump need to be replaced. Assuming everything seems ok reassemble and run an empty load with the dial set just before final spin. If the pump is working you should hear it, and possible feel water moving through the discharge hose.
    Mar 25, 2008 | Kenmore 44102 Front Load Washer
    Another flood. GE washer
    The water sound is normal. There is a solution in the top of inner tub for balance. Is it overflowing...as in not stopping the fill cycle? If so check to make sure small hose is still attached to outer tu at bottom left front. This dome that it connects to can become filled with scum and causes the unit to not know that it's full. This causes flooding. You can try removing hose and cleaning out with thin wire. Sometime only fix is to replace outer tub. Again, this is only if overflowing!!
    Another possibility is a bad break allowing outer tub to spin in agitation. This throws water up over sides of tub. Monitor unit when agitating to see if outer tub picks up speed and starts to spin. It is normal for it to index.
    Nov 08, 2007 | GE WDSR2080D Top Load Washer
    Hotpoint VVSR1070D Top Load Washer Logo
    63 people viewed this question
    Top Hotpoint Washing Machines Experts
    puggy666
    Level 1 Expert
    ptpumpman
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
