Question about Dryers
My dryer starts up for less than a minute and than starts beeping and all lights start flashing. For a while i was able to change settings from 60 mns to towels and it would work. Now it starts for a minutes, start flashing, beeping and stops.
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 10, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Sep 10, 2010
    Whoops... wrong one... here is the right one...
    Normal
    0
    font-size:10.0pt;
    There can be many reasons why your dryer will not start or turn...
    The most common causes are the belt breaking or jumping off, or the motor going
    bad...
    Here are a couple of tips that I wrote will help you to figure out why your
    dryer will not run...
    Dryer Repair - The Dryer is not Turning
    Dryer Repair - The dryer will not start
    heatman101
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
I opened the dryer door to put in a load of clothes and the light inside flashed and went off. power comes on, i can set to the drying time, but when i press start i get 3 short quick beeps...no error
It sounds like maybe the switch that recognizes your door is closed my be bad or out of adjustment. Look for a 3/8" to 1/2" opening on the face of the surface that the dryer door meets. There may be a small plate that acts as the actuator. It may also be a small rod sticking out that gets pushed in by the door. Either way, try to actuate it with your hand or screwdriver with the door open and press the start button and see if that works. If not you'll possibly have to take the dryer apart to get at the switch. If you're comfortable with using basic tools this can be done and you just need to be patient while doing it. Test the switch if you have an ohmeter to see if it works. An ohm reading is fairly simple to do and meters cost less than $30 at a Home Depot. Don't get intimidated by their dials and number readouts. (O.L. = Open, 0 ohms = closed) If the switch doesnt change states it's bad and you'll need to search the p/n on the switch in Google. Someone on Ebay or other sites will likely sell these switches for $5 or less. Hope this helps.
Dec 02, 2014 | Dryers
How to get the error code test on Frigidaire affinity model FARE1011MW
Good Afternoon Friend,
I understand you are receiving an error code on your Frigidaire dryer, model# FARE1011MW. I see that when you press the start button, your dryer beeps and the drying light begins flashing. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Dryers
Start/stop lights are flashing with "50" minutes readout. should be OFF. how do I clear it for good?
these dryers have alot of board problems i've seen them beep and then start up by themselves gotta love frigidaire,the computer board took the place of the timer so if the dryer didn't advance to off and got stuck in the same spot you knew it was the timer,so if it doesn't count down and beeps it sounds like a board issue and sometimes the board can't read itself out and you won't get a code.try unplugging it for like 5 to 10 minutes and then plug it back in to see if it resets the board but it probably will go back to doing the same thing
Jan 11, 2018 | Frigidaire AEQ6700FE Affinity Electric...
Malber Dryer won't start (sine-wave light flashing)
The dryer is easy: turn it on and turn the control to 0. It will beep. Then turn it to the desired program (20, 40, 60 minutes or a pre-programmed cycle), it will beep again and start. If there's a red light you have to empty the water tank at the front on the left. The washer is a normal washer. Just pick your program and press start (be patient as it takes a while to get cranking). Sometimes you have to really push the door closed very hard. Try and turn the control to 12 o'clock before setting it again.
May 30, 2009 | Malber TD800 Electric Dryer
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
Whirlpool Duet GGW9200LL1 will not start
The electric flash does not sound cool, It sounds like you have a door switch problem. Check to see if the door switch button is in tact. If it is , you may have to go after the door switch itself. Try this, press more time, less time, more time, less time buttons in that order, the whole panel should light up, open the dryer door, you should hear 1 beep and OE displayed, If you have this the door switch is ok, Catriver
Jan 14, 2009 | Dryers
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
150 people viewed this question
Top Dryers Experts
