Question about Singer QuantumLock 14T957DC Mechanical Sewing Machine
After threading my machine for a 5 thread safety stitch the machine will not feed fabric
  • 27 Answers
SOURCE: I have a Singer Inspiration
It's possible that there is foreign debris in the top tension assembly ,thread the machine and lower the presser foot and ensure that there is tension on the top thread
Posted on Jan 10, 2009
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
  • 65 Answers
SOURCE: How do you thread the Singer QuantumLock 5 Differential Feed?
Its a different model, but most sergers thread the same way.
Posted on Mar 30, 2009
  • 11 Answers
SOURCE: needle will not sew thread into material
Sounds like the timing is off. Take the bobbin out of the bobbin case and lower the needle into the needle plate. As the needle starts on the upswing, the hook should meet the needle just above the needle eye on most machines. If it isn't meeting at that point then your hook timing will need to be adjusted.
Posted on Mar 17, 2010
  • 1116 Answers
SOURCE: Bobbin thread will not stitch.
Have you had the machine serviced since you purchased it? This is something that should be done at least once a year.
Take the machine to a certified Singer dealer and explain what is happening. There may or may not be something that needs to be adjusted.
Your warranty is still in effect, but is now limited. Attempting to repair it yourself or having someone who is not a Singer dealer repair it will invalidate the remaining warranty.
Posted on Apr 16, 2010
Why is the fabric not feeding forward when stitching
on the front of the machine there is a lever/knob that sets the stitch size
if it is in the middle position ,the teeth will just go up and down and not back and forward
check that setting
it is used to seal of the threads when starting to sew and when finishing
start the sew for about 1/2" then reverse the feed then go forward again to complete the sewing
at the end of the sew do the same thing again before cutting the threads
this locks the threads as a knot so that the seam will not come undone
Sep 27, 2015 | Sewing Machines
How to fix bobbin thread on computered memorycraft 9000 sewing machine ?
1)Check that your bobbin does not have a nick in it where the thread can catch and won't feed smoothly.2) make sure the upper and bobbin threads are the same.3) pull out the bobbin case and chect to see if there is a clump of lint.4) make sure the feed dogs are moving the fabric through smoothly,some fabrics can get caught on the dogs and make the bottom thread get loopy.5) check your needle,if it's bent or has a bad tip,it can mess up the stitch.
Aug 15, 2014 | Janome Memory Craft 9000 Computerized...
I am trying to do a rolled hem using a singer ultralock 14sh654. Do I disengage the knife? The stitches are uneven and some are quite loose no matter how much I adjust the tension. I am positive I...
no, you need the blade in place and cutting to give an even cut fabric edge. Set up for a three thread using the right hand needle, take out the left hand needle. move blade over to the right so it is cutting wide. Most overlockers there is also a thread finger you need to change on the foot, or a little lever you flick to move this finger forward into the stitching area. Check this on your manual as each make is a bit different.
If you can source it, put wooly nylon thread into the upper looper (knot it onto existing thread and just chain it through, the knot should go through the looper eye fine). Now turn the tension on top looper down so it is looser and tighten up tension on bottom looper, so needle 5, top looper 2 and bottom looper about 7.
Now test serge, the fabric cut edge should be wider than the overlocking seam so the fabric rolls under inside the stitching. Adjust the two looper threads so that this is happening, you want the bottom looper thread to nest right up against the needle stitch and the top looper thread to wrap all the way around too.
Once you've got this happening, turn the stitch length down to 0.5, to close the stitching right up. On some fabrics you'll need to adjust the differential feed too if the fabric is "waving" a bit.
Uneven stitches or sometimes loose when serging could indicate that one of the tension devices is faulting, so if this machine is not new and its doing this, it could need a service. Can you get a regular smooth three or 4 thread seam out if it???
It is always good to just recheck the threading path, make sure the thread aerial is up and that a thread hasn't got caught back on the thread stand somewhere if you're getting something wonky happening, threads stream off overlocker cones through the machine so anything wrong in the thread path will throw off the stitching.
Jun 25, 2011 | Singer 14SH654
How do I thread a janome 204d serger
Serger may have a threading diagram inside the front looper cover which should show the various thread eyelets that you need to pull the threads through and they may be numbered one to 4 also to indicate order of threading. The diagram is usually colour coded to match the tension dial colours and serger usually has colour dots on the different thread eyes to help you follow the thread path for each thread.
This video is great and hopefully will help you, it has lay in tensions while yours has dials so just pull the thread around the dial right to left and then across to the next thread eye and this should pull the thread into tension. Dials are usually all set to 5 for normal stitch formation.
On my serger you thread up in the following order: top looper (second from right dial), bottom looper (right hand dial), then right needle, left needle; this video shows all threading going from right to left however, so if you have a numbered diagram inside your thread cover, then certainly use that order. But always loopers before needles.
Raise the thread aerial first before you start, put the cones onto the thread spools and if you have any cone holders (little plastic triangles) put them on the spools first to steady the cones. Now for each thread, take the thread tail from the cone, up through the aerial thread guide, then follow the coloured dots and take this down the front of the serger putting it into each coloured thread guide, through looper then up under the raised pressure foot. Repeat for next looper, then the needles.
Pull all 4 threads out under the foot to the left, lower foot, then chain off a little to start and test sew on fabric, adjusting the tensions if you need to.
Other adjustments are stitch length (usually a knob on right beside the flywheel numbered 1-4, blade position, a dial either left or right of the blade, press on the blade to release the tension on it before you try and move it. And differential feed, this is also a knob numbered 0.5 to 2 usually. If you can't see this on the right by flywheel then open up fabric plate (left cover) and look in there for these two adjustments.
I would suggest you start with tensions on 5, and stitch length of 2-3, and test sew on scraps of the fabric you wish to overlock. You can then either move the blade to cut wider or narrower to suit and adjust the two looper tensions if you need to close up the thread on the cut edge. There is no black and white settings as each fabric will behave a little differently, generally you adjust the looper tensions a bit until the stitch is encasing the cut edge and you have a seam width that suits the weight of the fabric.
Differential feed leave on zero unless you find you need it when a loose weave fabric goes wavy, then turn it down to close up the feeding. Sergers have two feed dogs, one before and after the foot and turning differential knob changes the ratio of feed between the two so either stretches the fabric, or pushes it together as it goes through the stitching sequence. So by turning differential feed up to 1.5 or 2 you are stretching the fabric and you can do a narrow rolled hem edge that is all fluted (lettuce edging).
I hope this helps you out a bit, if you are completely new to this machine and have never used a serger then I always suggest taking a class from a local dealer, it is really worth the money and time as they are quite different to sewing machines but once mastered, really change the dynamics of sewing and techniques are much more like commerical production with flat construction etc.
May 22, 2011 | Janome MyLock 204D Mechanical Sewing...
Have a brand new Singer 1507 that keeps jamming the bobbin thread. Have followed threading and winding bobbin instructions closely, but am still having problems with the bobbin thread jamming after 1-2...
I would try adjusting the tension on the machine - this sometimes causes the bobbin thread to jam while sewing. Re thread the entire machine including the top thread. Also it is recommended to use new thread as old thread can ball up after time. If no luck I would call the store you purchased the machine from.
Nov 30, 2010 | Sewing Machines
Presser foot will not feed and the thread wont catch
The presser foot is not suppose to feed. It's purpose is to hold the fabric in place as the feed dogs feed the fabric from the front to the back of the machine as stitches are formed.
Check the needle to be sure it is installed with the flat side of the needle shank facing the back of the sewing machine.
Refer to your manual to be sure the bobbin thread is feeding from the bobbin spool in the correct direction and through the guides.
Pull the bobbin thread up by lowering the threaded needed down and then back up. Pull both threads under the presser foot and to the back of the machine.
Set the stitch length to 2.
Place a scrap of fabric under the presser foot. Holding onto the ends of both threads, lower the needle into the fabric for the first stitch.
If the machine still does not stitch, the machine may need to go in for maintenance as the timing may need to be adjusted.
If the feed dogs are not moving, this also needs to be repaired by sewing machine service tech.
Mar 29, 2010 | Brother LS-2125 Mechanical Sewing Machine
My ls2125i won't stitch
Although I am not a expert at sewing machines, I have worked a lot with an industrial sewing machine. You might check the tension of the thread that goes through the needle. If it is to tight it will pull it through the needle. There should be somewhere on your machine that you can adjust the tension.
Jul 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
The needle will not pick up thread from the bobbin
Remove bobbin and be sure the bobbin thread is correctly placed into the machine. Put fabric, place feed dogs up, pressure lever down, hold the thread from the needle and stitch one stitch. This will have the needle go down and pull up the thread. You will never have a clump of thread under your fabric!
Jul 19, 2009 | Singer Tiny Tailor TT700
Singer 301A stitch jam
It sounds like your feed pressure and tension are both off. Try sewing with out thread. If the fabric goes all over the place, you need to adjust the feed pressure (the screw on the top of the machine). Tighten it down until your fabric feeds evenly. If the fabric is bogging and not feeding, you need to loosen it.
Your tension sounds like it is off as well. Make sure it is set around 2-3 and check your tension disc, make sure there is no thread in between the disc. If so, remove it. Now, thread the machine and check the thread through the needle. It should pull out quickly and smoothly. Now, put the presser foot in the down position and pull the thread, it should have some resistance. If not, your tension is set too low. Turn it up a little and try sewing. If the thread is still knotting up, you can turn the tension up to about 5, if that does not correct the problem, you will need to adjust the tension dial itself. To do this, press on the numbered part of the dial and it will push in, then turn it to a lower number, release and make sure it has locked back into place. Then adjust again as I previously instructed.
Feb 06, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
Dec 03, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Singer QuantumLock 14T957DC Mechanical Sewing Machine Logo
100 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
