I have a 5 yr old samsung dlp model hlp5663w. Replaced colorwheel and it worked fine. Now I lose the picture. Sound stays on and lamp stays lit. Fans still running but no picture. Replaced lamp but it still loses picture after a while. Have to turn off set for a while and then when I turn it back on it'll work for a couple hours then the pic goes out again.
  • 12,061 Answers
Http://www.retrevo.com/support/Samsung-HL-P5663W-TVs-manual/id/276bh036/t/2/
Above is your user manual, below is your service manual. It is a pay for one, but i searched and was unable to find a free one, but to even have a chance you MUST get a service manual.
http://www.tradebit.com/tagworld.php/samsung+hlp5663w+tv+service+manual+download
Before we can attempt to repair anything at all, there is one thing that one MUST do before anything else is done. Now that is, the making sure that the Power Supply,of the unit, no matter what it is, has the correct Voltages, coming into it, and more importantly, coming OUT of it. This is absolutely imperative, as, IF these Voltages are NOT correct then NOTHING will work, properly at all. So we must measure these voltages with a Volt Meter. All Voltage measurements are made with reference to ground. Meaning we clip, our Black, Minus, Lead onto the Earth, or Chassis, or Negative (-) "Rail" of the Power Supply. Now with the Red lead, we can now, measure these Voltages. Now sometimes, the Voltage of each Output is annotated,or written, onto the PCB, that will indicate the Voltage of that output. However most usually they are NOT, so in this case we MUST have a manual to tell us. Now this manual is called a "Service Manual" or sometimes a "Repair manual" This manual is absolutely vital so much so, that it can be near impossible to do without it. As apart from having "Troubleshooting" step through's, it also has our Voltages. When we measure these Voltages they are 100% EXACT, so IF the Voltage you measure, except for a few rare exceptions, the "Rail" that is NOT at the correct voltage is the one, that the "Fault/Cause" is "ON". Therefore we can now work outwards from the Power Supply, looking for the cause of that problem. Now if the Voltage is Lower than specified, we are invariably looking for a "Short", something has "Faulted" and is "Dragging" the Power Rail down to earth. Now if the "Rail" is "Higher" than the specified Voltage then the fault we are looking for is usually some sort of "Open Circuit" possibly a Diode, or resistor that has changed it's "Value". Now knowing this and knowing that the Power Supply is the FIRST place to start you troubleshooting and repair from. You now have a MUCH better chance of a "Fix". One thing more, DO NOT forget to get your SERVICE MANUAL. for you exact make & model. even if you pay for it, you will be glad you did.
The set Turning OFF is the key after a while, what is happening is that some component most likely in the PSU, is breaking down, under thermal load, now the fix for this is to get some Freeze Spray, from say Radio Shack etc, and in the PSU, carefully spray it on the components that are hot, try the hottest first, and the one that when you spray it clears or reduces the fault, is the faulty one.
But as always first you must check, are your voltages correct, measure them all.
Posted on Sep 10, 2010
My 60" dlp mitsubishi tv
Sound /No picture- Have you replaced the Lamp?
If Not, First make sure fans are running when Tv is Turned on .Then if fans are OK ,Most common reason is the Lamp.
What is the Model # that is printed on back of TV?
Feb 20, 2011 | Mitsubishi Televison & Video
SMASUNG DLP 50 HDTV
defininatly the fan that cools the lamps is either not working or going out and needs replaced
Nov 12, 2007 | Samsung DLP HL-P5663W 56" TV
How would this device behave when the lamp is broken, while the projector is otherwise ok?
it would depend on the projector. most will have the fans come on, the colorwheel spin (on dlp projectors only), then the lamp will light; if it doesn't strike, it'll try 2-4 more times. if no light after that, some projectors will have the fans shut off and one or more leds will flash and/or become red. others will have the fans stay on and have the leds blink and/or become red. check the lamp itself for bulges, black spots, or fogging. if it has any of those, replace it. if it doesn't light after that, you have another problem. for lcd projectors, it'll be the ballast or a fan. if it's a dlp projector, it's the colorwheel, ballast or fan. if you don't have the fans working either, the power supply is bad.
Jan 19, 2010 | Office Equipment & Supplies
MY SAMSUNG TV MODEL DLP HL -S4266W. I TURN ON THE TV AND I GET PICTURE SOUND EVERYTHING SEEMS FINE THEN AftER A COUPLE MINUTES IT TURNS OFF
Lamp maybe going out if you have not replaced it then it Lamp but Pull back off and make sure Fans are running if Fan to Lamp is defective then TV will shut Off. Look up Encompass Parts Distr or Call 1-800-638-3328
Nov 22, 2009 | Televison & Video
Sharp XG-3790E projector switches off soon after it is switched on
if you replaced the lamp recently, you'll need to reset the lamp timer. if it's a dlp projector, could be the colorwheel. listen for a high-pitched whir when the lamp strikes. if you don't hear it, replace the colorwheel. if you do, check the fans to make sure they work. if all else is fine, replace the ballast/power supply.
Nov 17, 2009 | Sharp Office Equipment & Supplies
The amber led labeled lamp lit up on my optoma ds303 and the picture disappeared. I replaced the original lamp with an after market lamp I purchased online. It worked for 2hours or so then the amber lamp...
the reason that it turns on without hitting the power button is that it thinks it's still in cooldown mode. while it's on, check the lamp hours through the menu. if it's close to 2000 hours (or the inside of the lamp is blackened or bulging), replace it. after market lamps never seem to last that long. if the fans stay on when the lamp goes off, it could also be the colorwheel. listen for chirping. if it chirps, it's the colorwheel.
Nov 17, 2009 | Optoma DS303 DLP Projector
When i turn on my tv it make a winding siren noise but no picture, i replaced the lamp, would it be the colorwheel?
sounds like the color wheel as it can almost sound like a whirling siren or a loud screeching sound
Jul 20, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung DLP TV, no picture, has sound
Try replacing the ballast next. Its the small circuit board directly underneath the lamp housing. You can access it through the lamp door. If the ballast is overheating or has a leaking capacitor, the tv won't stay lit for more than a minute or two.
Mar 12, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Poor Quality HD Picture
The lamp would make you picture dark.The colorwheel will affect color quality.If brightness is an issue = lamp.If color is the issue = Colorwheel.
Jan 12, 2009 | Samsung HL-S4666W Television
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
