Question about GE Heating & Cooling
I have a GE ac model aew12amg1. It all of a sudden will not let me use the power buttons on the remote or the unit and it stays set now at 86 degrees with a light that says set. when i go to lower the temp it raises back up to 86 instantly?
  • 958 Answers
SOURCE: we set the temp to
hello frances...
it could be that the display goes back to the room temperature ..you have set it already at 64... it is just going back to display the room temp..
tnx 4 using fixya.. drcool
Posted on Sep 06, 2008
electrodynam
  • 35 Answers
SOURCE: thermostat window ac turns unit on and off 8 degrees above se
the unit may be drawing the cool air it just released back into itself,plus the air close to the unit may be a little cooler than the air in the rest of the room.
Posted on Mar 19, 2009
  • 306 Answers
SOURCE: I have a GE small unit that is 5 to 6 years will not start up
About the only thing can suggest is see if a lamp or other will work in the outlet that you have the AC unit plugged into.
Posted on May 07, 2009
  • 45 Answers
SOURCE: GE AGM08LJG1 window unit: digital temp increases
its telling you the room temp that is been sucked into the evaporator.its normal for this to happen.once you set the temp you want.it stays there untile you change it.but its all good.
Posted on Jun 09, 2009
daddyo742001
  • 70 Answers
SOURCE: I have a GE air conditioner with ditigal panel. I
Wash out outside coil from time to time.This is the most over looked part of window units. Take care not to spray water directly into fan motor. If not real humid in house check temp coming out of ac inside and make sure filter and coil are clean. run on high speed and the air should have good force. 20 to 30 degree temp drop of room temp should be about right. Much depend on outside temp and humidity and indoor humidity plus insulation factor of area. How many people are in the area and if you keep unit on day and night .
Posted on Jun 28, 2009
Previous tenant left ac window unit Haier HWF05XC5, but took the remote. Can I manually turn on this ac unit? when turning the power button, only the fan turns on, I'm unable to switch to AC
According to the Model Number you listed, it's a Mechanically or Manually Controlled AC unit. There is no remote control for it.Please be certain the Model Number you listed is correct and get back to me.
If it's the correct model number and it's manually controlled. You should have 2 rocker switches. One is to turn the power ON & Off. The other is to set the Fan Speed either on Low or High. Then there is a dial, numbered 1 to 10 to set the cooling level. 1 is min cool and 10 is Max Cool.
If the controls on your unit match what I described above, it's a manually controlled unit. No remote.
I hope this helped you. Please advise. Thanks.
Jul 11, 2011 | Heating & Cooling
How do I set up a ge universal remote control on a sony television Stopped working changed the batteries too.
Hi! For me to be able to give you the correct code for your universal remote control, I actually need the model number of your remote control because there are GE remote controls that need a 3digit code and there are GE remote controls that need a 4digit code. But since I don't have the model number you may just try these codes and the instructions below.
4 digit code for Sony are:
0128, 0013, 0002, 0071, 0380, 0152
3 digit code for Sony are:
002, 006, 013, 071, 128, 380
1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
2. Press and release the desired TV button. The red indicator blinks, then stays lit.
3. Enter the 4 digit code or 3 digit code from the list above.
Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4. With your TV on, press ON/OFF. If the TV turns off, no further programming is required. Note: If some buttons do not operate your TV, try one of the other
codes.
Jun 14, 2010 | Televison & Video
Television will not power up
Have you tried both power buttons? On the set and on the remote? If yes, you might have a blown fuse or a bad board.
Jul 09, 2009 | Televison & Video
AEW10AJS1 a\c digital panel keeps climbing to its
I have the same problem, 4 little kids in the house trying to keep them cool. Did you find out how to fix this?
thanks
Ian
Jun 28, 2009 | GE AJCQ08ACB Air Conditioner
May 07, 2009 | GE AJCQ08ACB Air Conditioner
No Power From My Reciever
Mook_trakzz, your device is most likely roasted and ready or scrap. Sorry.
Guest, check if the cables are connected properly, specially the cable between the device and the sub is quite easily shifted thus losing your sound.
timtlc, seems you have had some powerfailure during that night, you can try to remove the powercable for at least 15 seconds, that should reset the device.
to all, information from Philips on this device:
  • Press the STANDBY ON button on the front of the DVD system to turn on the power.
    If the device powers on at the unit and not the remote, the unit may have been turned off with TV selected as the source on the remote. The standby button on the remote will operate most Philips TV’s when TV is selected as the source. Change the source to disc or any other source than TV on the remote.
  • To completely reset the player, unplug the AC cord from the AC outlet for 15 seconds.
Feb 21, 2009 | Philips HTS3450 System
Ihave bought a GE universal romote control RM24948 and can not figue out how to set it up please help
Hiya this is how i got mine to work.Manually turn on the tv.Press and hold setup on your remote till the light comes on and stays on.
Then press the tv button then release. The light will flash then continue to stay on.
Now press and release the power button waiting 2 seconds before you press it again until your tv switches off.. you may have to press it for awhile.
Once your tv cuts off press the mute button and now your remote is set for your tv.
Dec 15, 2008 | GE RM24948 Remote Control
Ge 94948 universal remote instrutios for progaming t.v.
Feb 19, 2008 | GE RM24948 Remote Control
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Heating & Cooling Logo
233 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
