Question about Breville BJE510 900 Watts Juicer
The motor does not start and diplay an ''e'' en the screen
Why won't my juicer motor start
no power --bad switch --motor burnt --bad safety
Oct 30, 2016 | Juicers
Base motor
The Start capacitor in the motor is faulty or the centrifugal switch is worn out info@nutrifaster.com.au
Jul 13, 2013 | Nutrifaster Ruby 2000 Juicer
The moment it is switched on& a small quantity of vegetables r put in the machine starts vibrating & in another minute starts spinning out of control,it's difficult to hold it down with both...
It is quite possible that the motor bushes , bearings or the jar bushes are worn out as this will make the motion of the high speed motor to allow the friction to work through therby making the whole assembly to vibrate.
You need to check this by observing the shaft play, it will be very minute but is enough to cause problems.
Aug 08, 2011 | Omega Juicers
The juicer overheated and stopped working
The motor sounds like it overloaded, I doubt it has a thermal cutout fitted (in which case you could leave it off for a while and see if it works) I doubt it has this feature and if it is the motor then the unit should be replaced.
Jun 20, 2010 | Breville JE900 Juicer
Champion Juicer leaking a lot; from screen holder!
I'm having the same problem, the blank screen just doesn't fit the main body that well (I think the body on mine may have been warped by someone putting it in the dishwasher). Since I'm only going to be using my Champion as a front-end for a hydraulic press, I bought some food-grade silicone sealant (from McMaster-Carr or EMI Supply) and I'm just going to permanently attach the blank screen to the juicer body and slide the screen holder over that. There's a new O-ring for the back where the body attaches to the motor that might be needed as well.
May 02, 2010 | Champion 2000+ Household Juice Extractor
Leaking dark fluid from motor when juicing
sounds like the start of a horror movie. lol
ok dark? and no cracks or leakage from the juice container? hmm
dark .... ...its gotta be juice leaking down and mixing with the dark grease they use on the bearings.. but this is a wild guess. and i cant think of anything else unless a 100 roaches live inside the motor housing.
get it fixed when it starts to whine or smoke.
Apr 03, 2008 | Champion 2000+ Household Juice Extractor
Juice extractor - dismantling after use
Look at the dismantling and cleaning procedure in JE95XL Juice Fountain Plus user manual on Page 14 and 15. Procedure is the same with JE900.
http://www.breville.ca/site/EN/products/je95xl/je95xl_manual.pdf
This is what manual doesn't tell you: clean the 3 spring loaded pins on the side of the motor clutch. Sugar and pulp may get inside and seize them when dries up, thus making very hard to separate the basket/cutter from the clutch.
Apr 01, 2008 | Juicers
Motor not working
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked. Hello Duane, Your machine is equipped with a magnetic start system which will only allow the machine to start when you have the screenholder all the way in place just as you would have it to start juicing. If you do not have any parts on the machine it will not start. Please assemble it again and give it a try. If it still wont start call me at 209-369-2154 for further assistance. Thank you Carl
Apr 16, 2007 | Champion G5NG853S Household Juice...
Champion Juicer stopped working
Nov 09, 2006 | Champion G5-PG-710 650 Watts Juicer
Breville BJE510 900 Watts Juicer Logo
51 people viewed this question
Top Breville Juicers Experts
Greg Cann
Greg Cann
Colin Stickland
Colin Stickland
eyecam
Are you a Breville Juicer Expert? Answer questions, earn points and help others
