Question about Sony Cameras
When i turn it on the lens won't open it states to turn off and turn on !, it has an exclamation above the wording, Nothing changes but I can hear the motor turning trying to open it
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 10, 2010
Hatch opening mechanism won't work
The inside panel of the hatch has to be removed to gain access to the locking mechanism which is stuck or unhinged.
Aug 22, 2017 | 2003 Pontiac Vibe
ASUS X44H won't recognize DVDs in the optical drive.
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Jul 15, 2012 | ASUS Computers & Internet
My lens won't open
The gear linkage in the lens is seized or is out of alignment, this is a job for a camera specialist, I recommend estimate first.
Jun 23, 2012 | Canon Sx150is Powershot Sx150 Is 5664b001...
I get an image on the screen of an exclamation point and it says ZOOM ERROR. What should I do?
Just quote comments about this problem...
Originally Posted by msjace2u
I had the same problem with mine and I tried several suggestions, BUT the only one that has worked is to gently grab the lens, pull it out as far as it will go until fully extended. While keeping it extended turn the lens to the right until you hear a click. Once you hear the click, release the lens and turn the power button on and then back off again. This should take care of the problem. A word of warning. ALWAYS make sure your fingers do not touch the front of the lens when you power on the camera. Even the slightest bit of obstruction seems to make the problem reoccur. Another note. I had tried this several times until I finally heard the click, so please don't give up on it, just keep trying. This will work and it will save you a lot of time and money having it fixed.
Hope helps.
Mar 29, 2011 | FUJIFILM FinePix J40 Digital Camera
I have a EX-S600 Casio. When I turn it on the lens pops out, I get 3 audible beeps, hear some grinding and then the lens retracts and the camera shuts off, it all takes about about 6 to 7 seconds. I've...
If you hear a grinding then it's toast. Any issue with the mechanism would cost more to have repaired than replaced. This usually happens as a result of the lens being bumped while open or opened in a bag. Or, a contaminate such as sand inside the body of the camera.
Mar 28, 2011 | Casio Exilim EX-S600 Digital Camera
My cannon camera lens will not open when i turn it on.
you will have to take the camera to a service station to get the lens repaired. the motor that drivers the lens is damaged giving the above error. thanks
Apr 20, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Having same no reponse on new Olympus FE-3010
Unless it's a generic problem with this model. Lens out and not moving usually means it has been damaged by a knock or has grit/sand in it. When exactly did it stop working, you must know as the lens was out, hence it was on when it stopped working.
Sep 26, 2009 | Cameras
I have a sony dvd player (dvp-N5725p) and it says cannot play disc now. I hear it trying to spend but nothing no play or anything it spins until it states cannot play disc now.
Try to clean optical lens of dvd player with soft and nice quality cotton bud / swab by opening top cover of player.
There might be chance of lens sled mechanism stuck so move lens left-right for 2-3 times.
If cleaning doesn't work, you need to replaced optical lens.
Oct 23, 2008 | Televison & Video
Lens is stuckpartly open power button does nothing-won,t turn off
mine has done this and I have grabbing the lens and pulling it out at the same time as I turn it on. It is a pain but it now works
Jun 24, 2008 | Samsung Digimax L730 Digital Camera
Canon PowerShot SD200 E18 Error
The "E18" error code indicates an error that involves the lens unit or lens cover. The grinding noise you hear-to my regret- means that len's mechanism is malfunction. This type of problem could be fixed by professional only.
Jun 23, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Cameras Logo
19 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
