Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
I replaced my bulb 6912V00006C on my Zenith E44W46LCD and when i plug the TV back in a red light comes on. when i press power a green light blinks for 5 seconds and then goes back to the red light. I don't hear any sound at all when i press the power button. Any ideas?
    Top Expert:
  • Zenith Master
  • 14,553 Answers
YES, this set is difficult to replace the lamp correctly---it is very likely when you put the cartridge back into the set the two pins on the back did not properly engage inside the set.
Remove lamp and try again, if set was working before and now different problem, the lamp is not properly seated.
If I remember this model, just the bulb is available, you have to take the housing apart and replace bulb--if not perfectly done plug on back with two pins will not engage.
SD TECH
Posted on Sep 10, 2010
Zenith E44W46LCD TV power/operation indicator lamp blinks green then goes red when power switch pressed. I can hear the fan motor but no picture. No history of lamp indicator warning.
If the tv projection lamp already been inside the tv now like a 1 1/2 or 2 years?Tv used it every day like 4 or 5 hrs every days?Yes?Than it is the tv projection lamp have to be replace,because the tv projection lamp life span have ended.
Sep 04, 2011 | Zenith E44W46LCD 44" Rear Projection...
When trying to turn on my tv, the green light blinks a few times then the red light blinks a couple of times then automaticaly the tv shuts off. There is no picture at all. It makes a couple of sounds like...
sounds like the projection bulb went bad. change the bulb and it should work. sometimes they make a high pitch noise when they are trying to turn on. the bulbs seem to last about 2 years for me.
Jun 04, 2010 | Zenith E44W46LCD 44" Rear Projection...
I have a zenith e44w46lcd tv, while watching it, it turned off and now will not turn back on again. Green light flashes for a bit then goes back to red. Also lamp light is on orange. Do I need to replace...
More then likely your lamp is faulty, you can replace this lamp urself, but on zenith models the lamp comes as a bulb only, you will have to change the lamp and use your original housing. Also lamp timer will have to be reset. The only reason you might need a repair man is to go into factory mode and reset lamp timer. But if you are mechnically incline you can swap the lamps yourself..
Thanks any questions email me at -
Delhielectronics@live.com
Sep 27, 2009 | Zenith E44W46LCD 44" Rear Projection...
TV wont turn on
The main power supply is failing or it is shutting down because of a fault on the output side of it and it is trying to protect itself from overload which can cause a fire. Contact Zenith customer service and describe the problem, particularly the flashing LED which may be giving you an error code.
Sep 04, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W48LCD will not power on
I would suggest a bad lamp then...This is a DLP projection correct?
Aug 14, 2009 | Zenith E44W46LCD 44" Rear Projection...
Yellow circle
The huge yellow circle is either your blue filter is burnt out (very common in Zenith DLP) or you LCD cube is bad. I would bet it is the blue filter. Zeniths DLPs have 3 color filters one blue (a pinkish color), one green (a grayish brown)and one red (it is red). For the bulb indicator I would check and make sure your lamp is seated to the ballast correctly. Just take it out and put it back in.
Mar 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
117 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
