Question about Cameras
When i turn my camera on the lens goes out and right back in, how do i fix it?
    Brigadier General:
  • 3,006 Answers
This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Lens faults are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the manufacturer's service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Sep 25, 2010
Nikon s220 lens error
The s220 seems to be very susceptible to lens errors, usually associated with the lens barrel being unaligned. It only takes the slightest bump/drop in many cases. Fixing it is a hit or miss solution. http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html Has a good list of possible fixes.
Jul 06, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
My kodak easy share M1063 turns on then shuts right off how do i
I had the same exact problem. When the camera turns on and then lens extends, hold the lens out while the camera shuts off. Then sort of move it around a bit. I did this and when I turned it on, it was fixed. I guess something was jammed in the lens.
Jun 24, 2009 | Kodak EASYSHARE M1063 Digital Camera
My camera says lens error when i turn it on
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 09, 2009 | Canon PowerShot A560 Digital Camera
TURN ON CAMERA THE LENS GOES IN AND OUT JUST A LITTLE THEN SAYS LENS ERROR
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 21, 2009 | Nikon COOLPIX L18 Digital Camera
Lens Error
Jan 03, 2009 | Nikon COOLPIX L3 Digital Camera
Camera goes off
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
Oct 15, 2008 | Kodak EasyShare Z740 Digital Camera
Camera
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Mar 14, 2008 | HP Photosmart M525 Digital Camera
Turn camera off then on again?
I posted and looked around more online- I found this, did it and it worked! I just held camera with lens upright and used my left thumb and applied pressure when turning off with right thumb.
"I have dsc-w70 with lens stuck out . When you turn it on , you will see a message turn the power off . I've just fixed this morning without any tool and it took only a second . When i turn the power off with my left thumb , i used my right hand to squeeze the lens with little push it in , it will be back to the right position it should be . My camera is working great now like before . Do not affraid , hope everyone can do it . Good luck ."
Feb 22, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Open Questions:
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
