Question about Ovens
Looking for the Gibson wall oven model br60G-1 wiring connections
5 Suggested Answers
  • 1891 Answers
SOURCE: Westinghouse POC700M Ultimate One wall oven. We
if you have not removed the old one yet . reinstall the ones onthe right to the right. and the same on the left . there is on most ovens only two . mm
Posted on Nov 22, 2009
SOURCE: What size electric wire/breaker for Jenn Air model
According to the manufacturer's schematic, the orange wire is powered through a 15 amp breaker from the red conductor.
Posted on Dec 23, 2009
pride applia
  • 232 Answers
SOURCE: St George wall oven element. which wire to connect
green is always grounded
Posted on Dec 24, 2009
  • 2006 Answers
SOURCE: i just installed an electrolus
Unfortunately, you do not have 220 volt standard house wiring. In fact, I bet if you put a meter on it, you will only have 110 volt. All US standards and codes require the standard 220 Volt wiring (Red and Black - hot; White - Neutral and green is the ground.
Also you need to look into what the oven require for amperage. Not only is that important for the circuit breaker that you install but also the size of the wire required.
I would suggest you read your manual and then run the proper size wire from the circuit breaker panel to the ovens.
If you attempt to operate the ovens on the wire you have installed, your insurance company has not legal obligations to pay for the repair of your house when it burns down.
Posted on Jul 12, 2011
I'm looking for classic chef wall oven manual please help
The manual is here
Page 1 Operating and Installation Instructions Electric Classic Wall ...
https://product.electrolux.com.au/Public/File/?Id=14896The Chef Classic oven is a compact wall oven or under bench oven and is available in the following models. Conventional oven with 90 minute ringer timer.
classic chef wall oven manual Google Search
Nov 22, 2017 | Ovens
Where could I find older model thermostat replacement for Kenmore 2784218590 Model # Thermostat Part # 326542
You're going to be hard pressed to find that exact part. What I would do is start looking into replacing it with a universal thermostat. Here's one that I've used before that usually works with very little modification:
Appliance Parts and Accessories Repair Appliance Parts Discount Parts...
Give it a shot. What have you got to lose? It's cheaper than buying a new wall oven!
Good luck
Oct 23, 2014 | Ovens
I have FP Double oven OD 302 the screen dark no light and oven as of no power, but breaker is on, please help
Pull the oven from the wall and look for a safety switch. See if it is off or the inside breaker trip. Check for corroded wires. Check for loose connection in the wall sockets. Sometimes those wires connected to the wall socket are so corroded that proper connections are not possible.
Jun 24, 2014 | Fisher and Paykel AeroTech Double - OD302M...
Need part for an older Gibson wall oven
IF YOU CAN NOT FIND ONE ONLINE HAVE SOMEONE INSTALL A GENERIC THERMOSTAT BUT BE SURE THEY ARE KNOWLEDGABLE TO DETERMINE PROPER VOLTS / WATTAGES
Apr 21, 2014 | Ovens
Older Gibson wall oven part needed
Try www.repairclinic.com
A good source for appialnce parts.
It has a white wire,red wire,and bare wire but I on have 2 black wires and one bare wire for ground that comes out the wall.I don't know what hooks up with what
Hi and welcome to FixYa, I am Kelly.
What is the model number so I can look up the installation procedures for THIS oven?
Usually for a 3 wire connection it will be connected as follows:
1 WALL black to the left terminal block terminal
The bare copper wire to the center terminal of the terminal block
2nd WALL black to the right terminal of the terminal block
See this picture link:
http://www.ask-the-electrician.com/images/RANGE%203-WIRE_CORD_CONNECTION_250.JPG
If you notice in the picture it shows a black red and white connection.
Red = black for your connetion 115VAC
White = bare wire neutral Ground
Black = 2nd black for your connection 115 VAC
When the power is connected properly and using the house wires as a reference if you are
reading it with a meter you would read EITHER black wire to the bare wire = 115 - 120VAC
Reading Black to Black = 230 - 240 VAC
If you still have questions feel free to respond here and I will gladly help you.
Thanks for choosing FixYa.
Kelly
Dec 02, 2010 | Ovens
I need to know which kind of plug is used on this oven so that the electricians can install the right kind of receptacle. Maytag cwe5800acs 24 Double electric wall oven
Your oven needs to be hard wired to a junction box. No plugs on a oven that pulls 30 or more amps 220v Read your install book that came with the oven.
Dec 01, 2009 | Maytag CWE5800A Electric Double Oven
I HAVE A W136C Jenn-Air wall oven and would like a wiring connection diagram. Icant figure where to connect the orange wire
Look for schmatic behind control panel, open oven door and remove 4 screws that hold upper face panel down, panel should slide up 1/2' or so and lift off.
Sep 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
The clock on my wall whirlpool oven flashes a error code of F2 and beeps on and off?
F2-- Oven temperature is too high
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
Jul 09, 2009 | Whirlpool GMC275PRS Oven
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
Ovens Logo
83 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
