Question about Hardware & Accessories
We have a ryobi one plus power caulk and adhesive gun, we have been using it for about 15 tubes of caulk and when the tube of caulk is empty the gun stops. Well, the tube is empty and the charge is good but the gun did not stop so that you can pull the plunger back and remove the old tube and replace it with a fresh one. The plunger will not pull back, when the trigger is pressed the gun continues to try to work on an empty tube. Another words all is stuck. What can we do? Jan
5 Suggested Answers
SOURCE: My Ryobi 15" ElectricTrimmer ZRRY41002 Not Operable
[The previous posted solution was garbled by the forum software.]
I was thinking about purchasing this product from Amazon sometime soon (today being 4-26-2008). However after reading of the above problems I am not so sure anymore. However I did find a discussion about this problem at the Ryobi forums at " ". (If the link does not work go to " " and do a search for " 597 ". One of the displayed threads will be entitled "weedeater problem?" It will have the proper link to the discussion.) From the multiple postings in that thread it appears that the switch is the problem and it seems to be a consistent problem for many users. The switch itself can be replaced for less than $4, however the shipping seems to drive the cost up to anywhere from $12 to $15, unless one can find a local supplier. I hope that this helps.
Posted on Apr 26, 2008
SOURCE: I have bleedby so bad I can pull the plunger back
I had some old guns and replaced the air delivery assembly valve. It works great so don't trash your old guns, you may need parts.
Posted on Jan 11, 2010
  • 1015 Answers
SOURCE: My caulk tube isnt producing
It is probably one of two things. Either there is a seal where the tube and spout come together or you may have a spot of caulking that has hardened to the point that it will not come out. Thank you.
Posted on Aug 09, 2011
  • 1388 Answers
SOURCE: Gun is full of nails, but acts like it is empty (the plunger won't advance). You go to tap it with the trigger pulled, and it just does nothing. Seems like firing pin is not getting air or somet
If no air is leaking from the gun, take out the nails, remove trigger by removing 3mm hex head bolt to expose the trigger pin. With air connected and side door open so that you can see the feeder, quickly depress the trigger pin with finger. Gun should fire. If gun does not fire (only makes air sound at trigger) dissconnect airline, remove head and lube headvalve with white grease and reinstall. Test again. If ok replace trigger. If still no joy, replace trigger valve with new factory or generic (part # TVA6). If gun fires but does not activate the feeder claw, remove two 6mm hex bolts from front of gun and split apart upper and lower body and check white oring (part # 149885) Good luck
Posted on Oct 16, 2012
How do i caulk my bathtub
get caulk and a caulk gun at the local hardware or Walmart. Load the caulk tube into the tray part of the caulk gun, snip the end of the tube. push on the rear of the tube and slowly lay a bead of caulk around the area of the tub needing caulk.
Apr 13, 2017 | Home
How do you soften an unopened tube of silicone
There is no effective long term way to store tubes of silicon. Even unopened tubes have a finite shelf life. I have found the most effective way to store opened tubes for medium lenght time, is to allow a bit of excess to flow over the tip, and allow it to form a plug. In a few months, this plug may extend the full length of the nozzle, but you can push this out with a piece of steel rod (from the tip end). I keep my tubes of silicone and caulking in a cool dry place. I've never tried the bucket of water method, so I don't know how successful that would be.
Nov 02, 2015 | Adhesives, Coatings & Sealants
Video on calking tub to floor
I would suggest using 'relief cuts' in the strip so you can make the bend, and then continue -- though using a caulk gun would be better. With standard caulk you can just use your finger and a little water to leave a nice finish. I believe you will find it cheaper as well -- a tube of caulk is around 2 or 3 dollars -- and a caulk gun is a dollar or so.
Jun 21, 2014 | Home
Cant move caulking gun handle
There should be a thumb release on the shaft at the handle end, press with your thumb and then pull back with the other hand on the shaft. If you have a used tube in the gun, it could be that some of the caulk came out the inside of the tube and hardened so that you cannot pull back the shaft, you will now have to cut the tube off with a utility knife to remove the old dried caulk
Mar 06, 2014 | Draper 43851 Caulking Gun
How to attach painted particle board baseboard in bathroom
Try this resource for reliability and accuracy. There is a helpline so you may reflect a personal solution and be given a suggestive application. Having read the file. Section 33 Construction Adhesives & section 11 DAP Silicone Plus will interest you. More and more we are relying on chemistry to help save . Give this resource a look. . Fare. Well.
Jan 05, 2014 | Roberts 7200 30 fl oz. Wall Base Adhesive,...
Chevy Astro rear window is loose, how do I fix it
Sounds like the glass tech either didn't clean the area good enough,didn't use a good adhesive,or just hurried to much.You can get the stuff you need at a good parts place(NAPA or Carquest are my favorites for professional products).3M adhesives are typically the best.Use a "piano wire" removal tool to take the glass out.Clean everything down to the bare paint with solvent."Glue in" window glass is usually installed with a urethane adhesive in a caulk gun tube.Read the side of the tube,make sure you have any primer it may call for before taking it home.(The manufacturer's instructions are the best to follow-they want you to like their product's results so you'll buy it again!).This IS a job the average gearhead can handle.Hey-the last "pro" you took it to didn't do it right anyway,so what'll it hurt for you to take a shot at it?
Jun 13, 2012 | 2002 Chevrolet Astro
My caulk tube isnt producing caulk at the tip when its in the gun, theres caulk in there I just cant get it to come out when I squeeze the trigger i've tried multiple times and the bar that pushes the...
Aug 09, 2011 | Home
How do i insert the caulk and how do i use the gun
Cut the end of tube on a angle.There should be a rod with what looks like a plunger at the end.pull the rod back as far as it will go and lock into place.slide tube of caulk into gun with open end of tube towards the plunger.should be a slot at other end where nozzle fits in.take a piece of wire and poke a hole up the nozzle of the tube.release the rod and sqeeze the handle a few times you should see the rod start moving.if not turn the rod until the teeth are facing down.then try again .you should hear a clicking sound and feel pressure and caulk will begin to come out of tube and you will be caulking.Good luck.If you still have problems just come back to fix-ya and we,ll help you through it.
Dec 03, 2010 | Stanley Garden
How do i use the Stanley caulk gun?
All Caulk gun are used the same way no matter which model you have, hear are the instractions
  • Load a tube of caulk into a caulking gun, making sure it's well seated at both ends
  • Use a utility knife to cut the tip of the spout. Cut off as little as possible, taking into consideration the size of the 'bead' of caulk you need. Some people like to cut the spout at an angle, while others cut it straight; it doesn't make a big difference
  • If using caulk that comes in a cardboard tube, look for a second seal at the base of the spout. Insert a nail or awl through the spout to puncture the seal. Many caulking guns come with such a puncturing device. (Plastic tubes usually don't have a second, inner seal.)
  • If you want more precise instruction then go to the link below
    Read more: How to Use a Caulking Gun '
    Here is also a vid that will show you haw to redey the gun for use.
  • Sep 07, 2010 | Grip On Tools Grip Heavy Duty Caulking Gun
    Hardware & Accessories Logo
    222 people viewed this question
    Top Hardware & Accessories Experts
    Gene Haynes
    Craig Butler
    Craig Butler
    Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
