Question about Kenmore 19233 Computerized Sewing Machine
I am trying to hem a pair of Lulu Lemon yoga pants and the material keeps getting caught (pulled down into the needle guide.) I am using a double needle and in "B" # 73. That design actually allows the pants to keep their reversable feature. However, I can't get it to sew on the material. It was great on regular material. So do I need other needles... my twin ones are the ones that came with the machine or is there some other trick.
  • 109 Answers
Most likely the pants are a knit or stretchy fabric and you should be using a ballpoint needle especially for knits. Try poking the needles through your fabric and pull them back out just to see if there's a burr on one of them. If not, you can use them if you can't get the ballpoint ones. If the fabric is knit and it keeps getting caught, try putting a stabilizer under the fabric to get it to sew smoothly. You can try a light tearaway from Joanne Fabrics. If you can't get to a store, try waxed paper, tissue paper, an old pattern or anything that you have that can be torn away after you stitch. You only need a strip on the bottom of the hem. If the pattern is intricate and the paper sticks after the tearaway process, you can just dampen the paper so it will fall off. Hope this solves your problem.
Posted on Sep 10, 2010
How do i sew a hem with a twin needle?
Sewing a hem with a twin needle is done differently than with a single needle. Normally you stitch on the wrong side of the fabric but in twin needle seeing you stitch on the right side of the fabric. Using fusable stay tape to keep the hem in place to sew the hem works well.
This video should be helpful. Watch it in it's entirety and remember some things on your machine may be different.
Sewing the hem will be the same.
https://youtu.be/t5eEPCj-LGE Sewing with Double or Twin Needle
Jul 21, 2017 | Sewing Machines
Need to now where to put tentions to sew sweat pants.
use a couple of pieces of waste material the same as the sweat pants material and sew about an inch long
adjust the needle tension and do it again
repeat the exercise until the top and bottom thread joint at the middle of the two pieces of the material
tension settings on the machine are a loose guide as the thread thickness, material thickness and needle size all have a bearing in the tensions of the thread
so practice and adjust prior to sewing is the way to go
Nov 07, 2015 | Sewing Machines
I am attempting to hem a pair of jeans and when I sew the top thread isn't catching properly and is making big loops between when it DOES catch. I have tried adjusting tension, stitch length, almost...
iam reliable informed that you will need to change the needle by the one who controls this machine in our house for different thickness materials you need different size needles ,or you will get exactly the problems you describe ,iam told to look in the book and see whats suggested for this sort of material ,as some of the smaller machines will not go through tougher type materials and some jean material you will have to do it by hand with a special long needle ,the type of needle i use on my boat for the awnings and sail .
Sep 06, 2010 | Janome 659 Mechanical Sewing Machine
I've just got janome 634d serger, how can i make the bottom of a T-shirt ? Thank you so much
If you want the bottom of the T to look like RTW with the double row of stitching, you cannot do this on a serger.
You can achieve the effect by using a twin needle, two spools of thread, bobbin and a straight stitch.
Make sure the double/twin needle will pass through the presser foot and opening in the needle plate below the presser foot.
Practice on a double layer of a scrap of the T shirt material as the tension may need to be slightly looser than the normal setting.
Apr 05, 2010 | Janome MyLock 634D Mechanical Sewing...
Material is puckering.i was hemming pants ,that went good;so i tried working with a very light material.threads are nor releasing, i guess, as the material is pulling together as i sew, its all puckered.
you should always use needles that are the right size and sharpness for different fabrics. any fabric store can help you with this. according to your machine the smaller the # on the needle the finer teh fabric it will sew. also using the right weight of thread is important...light weight thread for light weight fabric and heavier for thicker fabrics
May 18, 2009 | Singer Sewing Machines
Cant hem unable to workout what length to start with to end up with the correct length required looking at the manual it says to take the hem and fold it over etc. but its very confusing
Sorry, I don't understand just what you mean by "length to start". Length of what - stitch? hem turn-up?
Let us assume you are taking up a hem of a pair of pants. Try them on and put a pin where you want the hem to finish i.e. this will be the bottom of the pants. Take pants off, turn them inside out (careful that your pin does not fall out!) and fold the excess pants on that pin mark. The excess fabric should be on the outside, not tucked inside the leg tunnel. Measure how much it is from the existing hem to where you folded it over, let us say for the purposes of this exercise it is 4 inches. Your hem is to be 1 inch and you need 1/2 inch to turn under for a neat finish, total 1 1/2 inches, so you need to cut off 2 1/2 inches from the bottom of each pants leg. Fold 1/2inch at new leg bottom (wrong side of fabric to wrong side), press, fold 1 inch hem same way and press. Place pins every 2inches or so at a right angle to the hem edge. Pins should come out 1/4inch from edge of hem where the 1/2inch neatening fold was made (this is where I wish I could draw a picture!). Fold the hem back inside the leg tunnel. The pins should make the fabric fold under only enough so that 1/4inch of the hem sticks out beyond the pants leg. You will sew on this bit using the blind hem stitch (04 on my 7550). You might need to adjust the stitch width - not length - so that the straight part of the stitch goes along the hem bit and the zig-zag JUST bites into the pants leg fabric.
I do hope this lengthy explanation is of some use to you!
Jul 01, 2008 | PfaFF Creative 7570
Problems when sewing over heavy jean hems
Are you using the correct type of needle? have a word with your needle supplier and explain the problem. Different threads and different thickness material need different top and bottom tension adjustments.
Can I suggest sew one thickness material at a time with tension adjustments for that thickness. Then change the tensions and do a batch of thicker material.
Mar 29, 2008 | Juki DDL-8700
Kenmore 19233 Computerized Sewing Machine Logo
1,063 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
