Question about Kodak Carousel 4400 Slide Projector
When I turn on the lamp with no tray mounted, the light shines through and shows a shadow of the slide lift arm on the screen. The tray does not properly mount on the projector and the For and Rev controls do not work.
    President:
  • Kodak Master
  • 412 Answers
You are describing, among other things, a timing problem with the projector. That is why the light projects with no slide in the gate and the tray does not properly mount. This could have been caused by a slide jam, which "broke" the re-settable emergency clutch. To check (and re-set the emergency clutch), plug the projector in, turn it on and push & hold the reverse cycle button on the projector for a couple of cycles. If it fixes your problem - great!! Otherwise you need to contact an authorized repair dealer for repair.
Posted on Nov 03, 2010
Viking Frig ice maker
Depends how old the Viking is?
Older Vikings with icemakers with a arm on the side, simply lift
the arm up until locks.
Newer Vikings with Electronic Controls look for a "slide switch"
mounted on the right side of front interior trim. You will see a
red led light usually blinking on and off near the slide.
Feb 19, 2015 | Viking DFSB483 Side by Side Refrigerator
The carousel in my slide projector is stuck
I presume you are talking about a kodak projector. Look down into the center of the slide tray as it sits on the projector. There may be a small slot. Get a quarter, put it in the slot and turn it clockwise (?) a little, then lift the end of the tray furthest from the stuck slide. The tray should lift away. WITH THE RING ON, turn the tray over and rotate the metal bottom of the tray until it clicks, returning it to the "zero" position. Turn off the projector (if it's on) and retrieve the slide. Turn the projector on and hit the FWD button to get the arm situated correctly.
Dec 29, 2014 | Office Equipment & Supplies
Slide tray won't turn and accept slide --the arm moves up and down but that is about all.
Sounds to me like one of the return springs has either stretched out or fallen off. There is no easy way to diagnose this.... takes hands on from an experienced tech. The Slide Lift Lever has to come up high enough to put the slide back into the tray, plus give enough clearance for the tray to rotate. I sure hope this helps. Jim
May 08, 2012 | Kodak Carousel 4400 Slide Projector
The brake lights that we need 2 fix r on the trunk /hood.( what holds the spoiler if there was 1) looked all over. either cant find or see or get 2 it?
This is right out of the manual. Hope it is what you are looking for. Cobra. :-) Lamp, Rear Hi-Mount Removal
  1. Slide rear hi-mount lamp cover (13A656) away from back window glass (42006) and remove rear hi-mount lamp cover.
  1. Remove one screw retaining rear hi-mount lamp (13A613).
  1. Lift edge of rear hi-mount lamp and pull away from back window glass.
Installation
  1. Follow removal procedure in reverse order.
  1. Slide rear hi-mount lamp cover onto rear hi-mount lamp to engage retainers.
    Hi-Mount Rear Lamp
    Item Part Number Description 1 921 Bulb 2 56929-S2 Screw 3 13A613 Rear Hi-Mount Lamp 4 13A656 Rear Hi-Mount Lamp Cover 5 15A442 Rear Hi-Mount Lamp Wiring
Jun 05, 2010 | 1997 Ford Thunderbird LX
How to replace the PF roller on a brother DCP 8065
1.Pull out the paper tray
2.turn the machine upside down
3.push the blue lift arm and pull out the pin of the PF roller
4.then slide the PF roller to the left and pull it out
5.replace it with new one put the pin of the new roller into the hole of the blue lift arm.
6. place the machine on its base.
P.S you need reset pf roller counter after replacement
press "MENU - START - 088"
LCD shows "PARTS REPLACEMENT"
go down with arrow till "reset PF kit T1?" PRESS "SET" key
all done.
Jan 31, 2010 | Brother DCP-8065DN Laser Printer
Projector light does not shine. (Power is on, bulb
I will assume from your description that the projector is powered on and you can look in the rear vents and see the lamp illuminated, yet the light does not shine on the screen.
The Ektapro 9020 and most of the Ektagraphic line of projectors are equipped with a "dark shutter". What that does is keep the screen dark unless a slide drops into the gate. At that time the sensing circuits trigger and open the shutter, allowing light through the slide & onto the screen.
Dec 16, 2009 | Kodak Ektapro 9020 Slide Projector
I'm testing my 4400. With slide tray loaded (no slides in tray) when I advance the carousel the light from the lamp does not shine through. Does the carousel have to have slides drop down in order for the...
Yes!! The projector is equipped with a "dark shutter", which means light is only allowed to exit the projector when a slide is in the gate. That eliminates the "white screen strain" on your eyes when no slide is present. Happy New Year!
Sep 16, 2009 | Kodak Carousel 4400 Slide Projector
3M model 45CG Thermofax Machine how to change bulb?
On either side of the drive table are single wires that go to each end of the lamp. Remove one screw on each side of the snap-in levers. Turn red handle on left side of unit as you are looking at it. Lift up each lever (screws you just removed) carefully. You can slide the entire unit out from under the clear plastic, then you will be able to see the lamp. It is a long halogen lamp. Do not touch the lamp with your fingers!! The oil on your skin will cause that area to overheat, boil, and blow. Disconnect wires on each side. Loosen bracket screws (2 on each side). Lift lamp out of heatsink tray by porcelain ends and slide out. Replace in reverse order. REMEMBER: DON'T TOUCH LAMP WITH FINGERS. USE GLOVES OR HANDLE BY PORCELAIN ENDS. GOOD LUCK!!
Apr 05, 2009 | Office Equipment & Supplies
Under desk sliding tray won't slide
It sounds like She closed it with it not quite aligned properly.
First try lift up on it a bit while pulling it out some, if it's jammed it may take quite a bit of force. If you have more than one person 1 might lift and the other pull.
If this is tried with no success, you may have to go underneath the desk with a screwdriver and remove one of the sliderails in order to dislodge it. Once loose seperate the sliderails from the mounts and then reattach the mount to the desk. Then insert the rollers into the mount (Holding tray at a 45 deg angle.) Once the rollers are in tilt the tray down and push the tray in to seat it. It should click into place when it catches. It should now be able to slide as normal.
Hope this helps
Dave
Nov 21, 2008 | Ergotron VERTICAL LIFT SLIDE-OUT KEYBOARD...
My Sharp LCD 26" TV shows most black and shadow colours as vivid blue, I have tried resetting the colour to factory reset but that didn't seem to help at all. It occurs on all channels and on 3...
the problem with LCD tvs are that they have back lamps that shine thru the LCD sceen. the job of the screen is to block the light of the different colors to make the picture. the problem is that the very thin screen can not block all the light. if the set has a back lamp setting turn down the back lamps and adjust the brightness control it should help a little. you my notice that the blacks and dark sceens look better when the room is fully lit and look much worse in a darken room.
May 27, 2008 | Sharp Televison & Video
Kodak Carousel 4400 Slide Projector Logo
62 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
