Question about Microwave Ovens
I have a kenmore gas range model 790 trying to convert the oven allready screwed down the spud, converted the regulator,and adjusted the air shutter and the flames are still orange in color and to high
  • wabutler69 Sep 10, 2010
    thanks for the cure i just turned down the spud all the way down until it stopped the directions said do not over tighten I am a auto tech. for 25 years and i do know what to tight is . those spuds are just to tight from the factory . almost like your going to turn the burner ,regulator and everything right out the back of the oven AGAIN THANKS !!!!!!
    yes very helpful thanks the spuds needed to be turned down more.they are just to tight from the factory
  • Microwave Ovens Master
  • 43,501 Answers
Are you sure that the spud is screwed down all the way...also make sure that the regulator spring is in right and if it is an adjustable one you can back the screw out till the flames go to normal...also open the air shutter all the way open...
heatman101
Posted on Sep 10, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Sep 10, 2010
    Yeah, I hate when they use obscure terminology like that...
    But then there are some people that will just srtip the brass right out...
    Glad you got it working right!!
    Heatman101
CAN a ZANUSSI gas cooker be converted to utilize NG ? Without affecting its programs and controls ?
usually any gas cooker can be converted as long as the gas jets are changed to the right size. they also have to be the right fitting. it would involve a lot of work as you will need to get into the nitty gritty of the gas lines inside the cooker and if you make a mistake it can cost to get it fixed.
Jul 02, 2017 | Microwave Ovens
Cant remove kenmore over the range from 1984
The unit has two long installation screws located behind the upper grill. To remove the grill there are 4 small #2 Phillips screws holding it on. After loosening the installation screws, the unit tilts down and you lift the back free from a hanging plate attached to the wall.
murf427
Aug 02, 2012 | Kenmore 1.9 cu. ft. Over the Range...
Need to know what size wire and breaker to use to install my kenmore electric range model 790
need at least #12 (12guage wire) but #10 is even better and requires 50 amp breaker
Jul 21, 2011 | Kenmore Microwave Ovens
I have a kenmore elite range model number 790 46809 991 and the burner on both the left and right are acting up. They both show that a burner is on on the control panel (not surface indicator) and the...
Hello gralexander,
The problem you are experencing is with you control switches. The cheapest place i can find the switch is from searsparts direct. Here is a link to the webpage http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Range-Parts/Model-79046809991/0583/0124160/P0050380/00001?blt=06&prst=0&shdMod=79046809991
You will see a diagram in the top left side of the page use it to locate the switches that are bad and order them from sears. You may also need the burners to check them you need a continutity tester.
1. Remove the burner from the socket
2. Take your test and touch one probe to each side of the burner.
3. If you have continunity then the burners are good
4. If not you will have to order burners as well.
Changing the switches:
1. Unplug the range
2. Remove the back panel where the switches are.
3. Remove the knob from the front
4. Remove the screws from the switch you are replacing (Due one at a time)
5. Move the wires from the switch to the corresponding terminal on the new switch
6. Replace the switch and screw in place
7. Do the other switch
8. Reinstall the cover on the back of the unit
9. Plug in and try
Doing all of the above steps should fix the problem that you are having. Please make sure that you install L1 to L1 and L2 to L2 on the new switch other wise you will cross wire it and the rest of the switches will short and need to be replaced.
Thank you for choosing FixYa.com. If you have any other questions please post back to this thread and I will do my best to help you with your Range problem
Justin
Mar 10, 2011 | Kenmore 63252 Microwave Oven
Our ignitor is stuck on on our Kenmore 790 range. It's the large "power burner" in the front. How can we stop the clicking?
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Jan 04, 2011 | Kenmore Microwave Ovens
When one of the gas hobs is on ,it does not burn with a blue flame but a more yellow one .also black soot forms under the burner plate.it is on lpg
Have to adjust the piolot lights for the amount of gas coming out. U have too much gas coming out(yellow flame). On older gas ranges, there was a small screw between the piolot light & burners that had to be adjusted. (if this is a older model) have to turn the screw just a little at a time, till ur flame returns to blue on ur burners. Hope this helps.
Sep 12, 2010 | Microwave Ovens
I have an old model #12 gas Fryer and I want to convert it to propane. What do I need to do?
Unless the original manufacturer offers a conversion kit, do not attempt this yourself. It requires changing the orifice in the regulator, but requires someone experienced and certified with gas appliances to get the correct one. Experimenting in this case could be very dangerous.
Mar 19, 2010 | Microwave Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
How to convert from lp gas to natural
Microwaves are electrical only.To convert a stove,range or oven the orfices must be replaced.Insome cases a gas regulater my need to be instaled depending on if your on high or low gas pressure
Jun 24, 2009 | Microwave Ovens
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
