Question about Panasonic KX-TG5673 Trio Cordless Phone
I have a three-phone system & there is no dial tone but it sounds like a phone is off the hook and it isn't. What do I do ?
  • eileenham1 Sep 10, 2010
    did disconnect and reconect with no results
    didn't work but I did call my local phone company and they reset it and now it works. Evidently you can reboot your phone system on the back of the modem. Simple solution!
  • Panasonic Master
  • 6,993 Answers
Below is what you can do concerning the "no dial tone"
  • Check that both ends of the Base Unit telephone line cord are connected
  • Make sure the AC Adapter is plugged into the Base Unit and wall outlet.
  • Make sure the battery in your handset in connected properly
  • Disconnect the AC Adapter for a few minutes, and then reconnect it and ensure the power is turned on.
I hope this helps.
Good luck.
Posted on Sep 10, 2010
    President:
  • 2,185 Answers
Have you tried restarting all the three handsets and the base itself? Also, try hooking up a different handset on your telephone main phone line and make sure the line is not dead.
    President:
  • 3,278 Answers
Hello, Eileen.
Disconnect the power and line from all three phones. Wait 10 minutes. Then, connect one at a time. If the first one works, go to the next until you find the problem phone. If the first one doesn't work, disconnect it again and connect the 2nd phone.
Hope this helps.
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
I have a KX-T7130 phone system with intercom. for the last 4 weeks, every phone will ring once and then the call gets hung up before I can answer it. I can use every phone to call out, but just can't...
Most likely NOT your phone system (anonymous)
Neither is it likely accidental...
What it sounds like you are getting is a "ring splash"
It is a token ring to let you know a call was forwarded...
My best suggestion would be to call YOUR OWN
number and find out who has been getting your call...
Or at least what kind of TREATMENT your callers have been getting...
Since this is a GLOBAL SITE... I would suggest you consult
your service PROVIDER.. for the appropriate enable & cancel CALL FORWARDING.
BELL-SYSTEM Codes to invoke and cancel
Codes: *72 and *73: respectively
Forward... *72 = ("star, seven, two")
*72 (wait a second dial tone) dial tone + (forward number)...
If the call is answered the FORWARD is complete...
(confirmation)
Else
Repeat the SAME dialing PROCESS
(OK: indicated by two stutter dial tones followed by dial tone).
((confirmation)).
Cancel FORWARD...
*73: To CANCEL forwarding... *73 = ("star, seven, three")
(again OK... Success is indicated by two stutter dial tones followed by dial tone (yet another confirmation))...
Hope this helps...
https://en.wikipedia.org/wiki/Carnac_the_Magnificent Carnac the Magnificent
May 24, 2017 | Panasonic KX-T7130 Corded Phone
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
Dial tone problems, when i press on hook dial and dial the number the dial tone keeps and the number won't dial
Sounds as if the phone line from the wall is not in the correct jack. The correct jack should say "L" or "line" not "T" or "aux"
Jun 30, 2009 | Dell Office Equipment & Supplies
Dial tone
my phone has no dial tone and when you call the phone it has a busy signal. There is no static just sounds like it is not hung up.
Sep 23, 2008 | Panasonic KX-TG1033S Cordless Phone
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
Polycom Sound Station
SoundStation: Changing dialing from Tone to Pulse
http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10966&sliceId=SAL_PUBLIC_1_2&dialogID=979138&stateId=0%200%20977279
Description
sp.gif sp.gif There are three ways that a SoundStation can be changed from tone to pulse, which depends on when the unit was manufactured.
1. Pressing the Keys 3&Vol + simultaneously, will toggle between Pulse and Tone while the unit is in On Hook Mode (off).
2. Pressing the Keys *&MUTE simultaneously, will toggle between Pulse and Tone while the unit is in On Hook Mode (off).
3. Operation done by DIP switches. Dipswitch Configuration On the bottom of the SoundStation, in the lower left hand corner of the large sticker may be a small silver sticker. Underneath that sticker are 4 DIP Switches. Switch number 4 is for tone and pulse,ON being tone, and OFF being pulse. Do not change the other three swithces as this could render the phone inoperable.
Sep 19, 2007 | NorStar Polycom Soundstation ( Phone...
Can't dial out
What are you getting when you try to dial out? Sounds or display wise? How are you dialing out? Do you access a line, dial 9 from intercom? The dial tone is probaly the phone system generated dial tone. With more information, I can help..
Oct 25, 2006 | Nortel Meridian 9417CW 2 Line phone
Panasonic KX-TG5673 Trio Cordless Phone Logo
94 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
