Question about Toto Home
Water kept going after flushing the toilet. can you explain what is the cause of it?
  • 127 Answers
If it is new you may need to adjust the fill valve so that there is enough pressure on it to shut it off. It may have also got some dirt into the fill valve not allowing it to shut off.
If it has been in service and has just started doing this you may need to simply change the flapper on the flush valve. Make sure you get and exact Toto replacement.
Posted on Sep 10, 2010
My toilet flushes, then the water in the bowl drains over 4-5 minutes resulting in sewer gas smells.
Look inside the tank under the lid, it sounds like the flapper that lets the water into the bowl is getting hung up on something when you flush. It could be the flushing lever. This would cause the flapper to stay open letting water to just pour into the open sewer line. It should be a simple fix. Just see what is binding the flapper & make an adjustment.
Dec 02, 2015 | Duravit Starck 2 One-Piece Toilet
Why does my toilet belch water after flushing
Always the first thing with bad toilets. Take a big plunger and pump hard covering the entire bottom of the bowl. Blockages cause air breaks which cause the belching
Mar 19, 2014 | Computers & Internet
My toto neorest 500 "burps" when I flush but the water does not go down
The problem may be in the venting of the toilet. If the vent for the toilet is plugged or in the northern climates frosted shut the air in the toilet drain has nowhere to go when displaced by the flushing water so it backs up through the toilet and causes the "burping" you mentioned. Hope this helps.
Dec 12, 2013 | Toto Home
Water runs after it fills up?
I am not familiar with that model, but it sounds like your fill valve is leaking or the water level in the tank is too high. Take the toilet tank top off and flush the toilet. When the water gets full and you hear the water stop ( except for your leak) look at the flush valve. Is water running over the top of it and running into the hole in the middle? Then the float need adjustment.
If you are hearing you leak still, lift up on the float. Did it stop? if so the valve may need adjustment due to it not seating completely. You can probably find something online (youtube) easier than I can explain it.
Sep 08, 2010 | Caroma 270W-RF Reflection Round Front...
Toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Jan 23, 2010 | Toto Aquia II Dual Flush Toilet
My toto toilets do not fuush consistently...why?
there are numerous reasons that could cause the problem. If you are having any kind of problems with the sinks or tub/showers draining...then I would say it is either a venting problem or an actual moving blockage in the toilet or drain lines. Check to make sure the water level is where it is supposed to be when you flush. The toilet actually works on downward pressure that is provided by the amount of water in the tank. Also if the flapper is closing to soon that could cause the problem too. Just so many variables.
Oct 17, 2009 | Toto Promenade, 1.6 GPF, Elongated...
Cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
May 08, 2009 | American Standard Cadet 3 Right Height...
Toilet doen't stop flushing
Sounds like the flapper is stuck in the open position.
They sometimes get hung on the flush tube or the chain hanging from the handle.
Is the water level overflowing the tube?
If so, try adjusting the level down, you may need a new fill valve if that doesnt work.
Nov 18, 2008 | Eljer Aqua-Saver 12" Two-Piece...
Home Logo
118 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
