Question about Kenmore Elite HE5t Washer
I can not open frent door. front door is lock.
  • 15,935 Answers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Close front cover This madsage show on lcd
when u close front cover there have swich not conected please check frent door switch
Aug 25, 2014 | Office Equipment & Supplies
Front Doors LOCKED OPEN.. How to close?
Lift the door handle as if you were opening it
Hold the handle & use a round phillips to hook
& rotate the white door latch to the open position
May 18, 2014 | 2009 Honda Odyssey
Central locking 2005 subaru liberty stopped working on 2 doors
1. Replace battery in remote
2. Replace sensor at rhf door lock (it is inside of door)
Apr 30, 2014 | Cars & Trucks
WE have Kenmore elite He3t Model Nol. 42926 203. We get an error code dL F. How do we correct this?
It is a door lock failure and it flashes after the door locking routine fails to lock the door after 6 attempts. Replace the door lock/latch assembly (part number 8182634) to solve the problem.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel. Pull the door lock/latch assembly out of the washer and disconnect the wiring harnesses.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel. the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Jan 07, 2011 | Kenmore Elite 45986 Front Load Washer
My door lock has locked with the door open , how do i get it to unlock ?
There is a manual unlocking tab located at the bottom of the door lock and switch assembly. Disconnect power to the washer before accessing it.
Remove the three screws attaching the toe panel to the cabinet then pull the panel down and off the cabinet. Prop up the bottom front edge of the washer or cushion and lean it against the wall for an easy access of the screws.
Reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side.
Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists. Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening.
Pull the door lock/latch assembly out of the washer and disconnect the wiring harness.
Secure the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Jul 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer will not start. I keep getting a "dl" and an "f" signal. I assume it means door lock failure. I've tried unplugging and opening and shutting the door before restarting but it won't...
It is indeed a door lock failure. Replace the door lock/latch assembly (part number 8181700) to solve the problem.
Mar 01, 2010 | Washing Machines
How i can to open the cover of lcd hp L1706
1.- remove 14 screw on back
2.- remove front cover con un desarmador plano pequeño, como si pucharas hacia afuera y luego al frente por toda la orilla.
3.- quitar la base es solo con un simple apreton y click y listo, sale la parte de abajo y luego aprietas la parte de arriba y estiras. y ahi vas a ver unas tuercas te puedes ayudar con una llave española o perica pequeña.
y listo.
Jul 22, 2009 | HP L1706 17" LCD Monitor
Driver's side door won't open in the cold
Power Door Lock Operation (Front Doors)
The front doors do not have traditional door lock actuators. They have electronically controlled door latches that will operate depending on the status of the door lock system. This status is determined by the front door modules and the last known state of the lock system. If the last known state is LOCK, the latches will not release when the door handles are operated. If the last known state is UNLOCK, the latches will release when the door handles are operated. The front doors are also equipped with red door lock status indicators. The front door modules will supply power and ground to the indicators to illuminate them when the lock system is in a virtual state of lock. The indicators will not continuously illuminate when the vehicle is locked. They will illuminate for approximately 5 seconds after a lock switch activation or after a door handle has been operated and the front door modules are in a virtual state of lock. For further information on the front door latches, refer to Power Door Latch Description and Operation .
I would assume they check for DTC'S - diagnostic trouble codes ?
DTC B3062 Front Door Key Lock Switch Circuit
• DTC B3067 Front Door Key Unlock Switch Circuit
DTC B3849 Exterior Door Handle Switch Circuit
The left front exterior door handle and right front exterior door handle switch signal circuits provide inputs to the driver door module (DDM) and passenger door module (PDM) when an exterior door handle switch is activated. These inputs allow the door module to detect a door open request. The door modules provide voltage to the door handle switches. If the door module detects that a ground is applied for greater than 30 seconds continuously, a DTC is set and the door module will ignore the door handle switch input.
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model and engine size . Under system click body & accesories .Then under subsystem click power locks . Click the search button then the blue links
Cadillac CTS Door Handle Repair Micro Switches Replacement 2nd Gen
Aug 10, 2017 | 2006 Cadillac STS
Door locks open by themselves randomly
some possibilities
The power door locks may self-activate or cycle on some vehicles. This may be caused by a misadjusted front door lock linkage, excess solder in the front door power window switch, water infiltration of a potential open wire harness connector inside the front doors, wiring harness chafe on the door check strap, or a damaged Remote Keyless Entry (RKE) key fob.
Nov 16, 2008 | 1996 Mercury Sable
Kenmore Elite HE5t Washer Logo
153 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
