Question about Poulan "" Push Mower
The mower will start but won't stay running - Poulan "" Push Mower
  • Poulan Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Posted on Sep 10, 2010
  • sjlockwood1 Sep 26, 2010
    The mower is brand new
  • Curtis Sewell
    Curtis Sewell Sep 26, 2010
    Be sure to check your gas tank on the mower for water and trash inside it.
    You could have some debris/trash in the jets of the carburetor from the gasoline you put in it. Besure to check your gasoline can for trash in it.
    Sometimes when you get gas from a station it will contain debris/trash and water.
Won t stay running
could be a bad coil
Oct 15, 2013 | Craftsman Garden
My cub cadet zero turn won't run. Changed pluggs
Try cleaning the carburetor that might mean that it is not getting gas
Apr 17, 2013 | Garden
Won't stay running
sounds like carburetor is clogged or has something in the jets or possibly fuel line or tank is clogged. check fuel tank and line to make sure fuel flows easily then carburetor cleaning and rebuild may be required
Aug 24, 2012 | Mtd 22" Yard Machine Push Mower
Not Staying Started
I can't tell you how many pieces of small equipment I have been given for free because it "just won't start" or "won't stay running". Start by draining the tank and cleaning it out - use a good carb cleaner. It only takes a grain of sand to create a problem. You may have to take the carb apart and clean that out too.
Aug 01, 2012 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Where is the primer ball
It may not have a primer ball. If it does, it would be attached to the carberator. If it starts, but won't stay running, that could mean your carberator needs to be cleaned/serviced.
May 29, 2012 | Mtd 22" Yard Machine Push Mower
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Mower starts but won't stay running
check the inside of the cap. Check the underside of the gas cap for a cardboard disk. Remove the disk, and try starting again. My mower had same problem, and I removed the disk and suddenly it ran like there was no problem at all.
Aug 13, 2011 | Mtd 22" Yard Machine Push Mower
Start, won't stay running
check fuel plug. nut holding on silver fuel bowl
Jun 24, 2011 | Briggs & Stratton Garden
Won;t start
I got a new air filter for mine today, plus cleaned out the metal fuel canister under the carburator and the little brass bolt and my mower started right up. I was having hte same problems getting my mower to run and stay running. Glad I checked this site!
Sep 09, 2009 | Mtd 22" Yard Machine Push Mower
Poulan "" Push Mower Logo
197 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
