Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
How do you replace a condenser on a 16 hp Briggs and Stratton v-twin model-303777...type 1142-E1. Note:Engine runs fine for approx 30 min(until it heats up) and then shuts off & will not restart until engine cools off....thinking the condenser could be the problem. What do you think?
  • 10,319 Answers
The condensor is not the problem for they go bad upon not hold a charge. When the engine heats up and the engines dies out the problem may lay in the magnito's frame mounting from swelling from the heat, a loose mounting bolt(s). Or a Magnito that is ready to go out completely
Posted on Sep 10, 2010
Engine runs good for about 30 min then dies
electric fuel shutoff in the bowl of the carb is going bad and not letting enough fuel in remove cut tip off if it runs fine replace or just leave it its all e same
Jul 05, 2012 | Briggs & Stratton Briggs Stratton Intek V...
22hp briggs and stratton intek v-twin model number 470577-0284-e1
to much fuel either the needle valve is stuck or the float is bad tear apart the carb acid dip and clean take float submerge in gas for 20 min pull out shake next to ear if you hear liquid inside its bad
Jul 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton vanguard 16 hp v-twin starter replacement
It most Likely is located under the engine cover..it mount just below the flywheel. Good luck
Apr 11, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Motor won't run unless choke is on. It is a 16 hp v twin.
check breather to make sure it is clean and clean the carburator
Apr 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Parts list required for starter and drive gear spring assembly (engages flywheel on start). Engine model 303777.
First on the shaft goes the small felt washer, if supplied, the the drive gear, the return spring, the cap washer and the circlip. Thats it.
Aug 30, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Have to choke to keep running
this is not hard to do here is what you need , 1 can of carb cleaner anykind will do , a 10 mm rench to remove the bowl 7/16 socket . now remove the carb take a good look where the spring is before you take the carb off it muct go back in the same hole , now that you have it off take the bowl off remove the float place to the side here is the fun part look in the carb you will see some small hole spray them this will clean all of the old gas out if you can let it set for about 10 min then do it again blow out with air if you have one nothing else to do but reinstall this works most of the time ...Good Luck..
Aug 16, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Engine appears to run normaly until PTO is egaged,then it backfires and quits. Engine is an 18 HP Vanguard twin, model 350777.
Check you float in the carb I had one a few years back and it was partualy plugged cleaned it out and everthing worked fine. Also is the PTO binding up or bearings going bad putting an excessive load on the motor.
Jul 04, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
379 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
