Question about ViewSonic VA1912wb Monitor
I am unable to get any sound from the monitor speaker. Cord is plugged into back of monitor and into cpu. Checked sound settings on Control Panel; made sure mute is not on. Ideas??
  • 11,361 Answers
Try feedin it with another sound source such as MP3 player, if you do not get the sound, then the amplifier module may have failed and you will be better of spending money on a set of powered speakers instead of trying to get it fixed, you will get better sound any way.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Sep 10, 2010
Not getting any sound from flatronw1942tq
Do you ave power lights on the speaker ? If not install the power cord or make sure it is plugged into a hot receptical. If the power cord is connected and has power you will need to go to control panel and make nessesary settings for your speakers
Mar 17, 2014 | Computers & Internet
I cant get the sound to come out of my speakers. I have checked all conection, ect
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 01, 2011 | Logitech LS11 2 Speakers
My speakers won't turn on at the outlet that my power strip is plugged into, nor when plugged into any of the outlets on the strip, however the computer and monitor are running off the power strip and...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar:
Jul 01, 2011 | Logitech X-530 Computer Speakers
Sound no longer comes out of monitor. I believe nothing is muted. I replaced cable between monitor and desktop. Any suggestions.
You didn't provide a model for your Envision monitor, so I can provide specifics - but here's a few things to try: (1) Start an audio program on the computer (mp3, CD audio, movie, etc. (2) Disconnect the audio patch cable from the computer's speaker jack and plug in stereo headphones. Adjust the volume on the computer's audio control panel to set the volume. If you're not receiving any sound - make sure you're plugged into the speaker jack (this is often the green jack). If you now hear sound, continue to (3). If you are unable to hear any sounds - your problem is INSIDE the computer. More on this later. Continue to the next step. (3) Disconnect the headphones and try the audio patch cable between the computer and monitor again. Make sure you're using a stereo cable - it has 2 individual contact points on the plugs - mono cables have just two. Pay close attention to the jacks if more than one are offered on the monitor (some monitors have power output jacks, etc.). Select the "LINE IN" or "SPEAKER IN" jack on the monitor. Be sure the plugs are firmly seated into the jacks on both the monitor and computer. (4) Check the menu settings of the monitor to make sure that the speakers are enabled (or not disabled as the case may be).
if you were unable to hear audio in step (2) above, there is a problem with the audio circuit in the computer. Some things to check are: Is there a volume knob on the sound card that is turned to minimum? Are (all) the correct drivers installed for the sound card in control panel? Is the sound card enabled? Does the sound card have a problem indicated by an "x" or "!" on the icon in control panel? Many times, "uninstalling" the device in control panel and the "scanning for changes" to reinstall will solve the problem. Other times, it is an output device issue: Have you selected "Speakers" as the output (not HDMI or Digital Audio).
If still unable to get sound working, provide the Envision model number along with computer name & model or the sound card name and model. If the sound is built into the motherboard, provide the mother board name and model. With that info, it will be easier to get the info you need.
Hopefully, you got the sound working with the tips I provided above. Please rate my reply. Thanks.
May 23, 2011 | Envision Computers & Internet
I plugged in power speakers (the cable green stereo plug which I plugged into the green inlet in the back of the CPU). I can see the volume level moving and I checked that it's not on volume mute) no...
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
don
Feb 21, 2011 | Acer Aspire™ T180 PC Desktop
How i could get sound from monitor speakers Do I need to connect cord between cpu and monitor
Hi
Yes you will nned to connect the cord between th monitor and CPU, on the cPU you will need to plug the cord into the light green connector
Regards
Shauqat
Sep 26, 2010 | Nokia 500 XA Monitor
My sound is not working. Checked volume control in control panel. Checks out fine. What could it be?
Pls check that the audio cable from monitor port to cpu port is connected properly ,re-connect it and check that you are connecting in output port.aftre that if still sound not come then re-install the sound driver and check it ,it still problem might be problem with speaker.
Nov 18, 2009 | HP vs15 15"LCD Flat Panel Monitor
The built-in speakers on my HP w2408h do not work. I checked the sound generating electronics in my HP computer with a headphone. That worked. I plugged in the sound patch cord to the headphone jack in the...
hello bill.. i have a 190 B and not getting sound... checked all sound generating electronics as well.. i wonder are the internal speakers 'gone'? in mine i.e...??
Oct 26, 2009 | HP Computers & Internet
I need help to to connect Monitor speakers to PC
if the speakers are built-in to the monitor then there should be a cord with a green phono plug on it---it plugs in to the green port on the back of the tower then you may have to go to control panel>sound and audio devices and make sure the volume and settings are ok
Apr 24, 2009 | Computers & Internet
Pc hook-up/sound issues
on the bottom of the monitor there is a audio input. you must connect you pc output(green) to the monitor input with a male to male audio cord. you can also use a rca cord with two adapters.
Oct 24, 2006 | ViewSonic N2750w 27 in. HD-Ready LCD...
ViewSonic VA1912wb Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
