Question about Milwaukee Tool Milwaukee Orbital Jig Saw with L.E.D. 6268 - 21
Cant figure out how to change the blade on jiw saw Black and decker 3.5A quick clamp variable speed
Model JS250Q type 1 Skil Saw - cannot seem to get the blade to stay in and cannot find the manual - could you possibly send a pic of the clamping mechanism?
product diagram is at this link;http://www.ereplacementparts.com/black-and-decker-js250q-type-variable-speed-jig-saw-parts-c-4167_4262_11752.html. I suggest you remove the screw you use to tighten the assembly, install your blade and if there is a hole in the blade, try to visually line up that hole with the screw hole. Generally ,that screw has a nose that will pass the blade first, then tighten the clamping mechanism.
Aug 03, 2011 | Garden
What weight oil do I use in Porter Cable 637 Type 1 Variable Speed Tiger Saw?
use sewing machine oil, or 3 in 1 oil, you could use WD40 as well. but not motor oil
Mar 21, 2011 | Porter Cable Variable Speed All-Purpose...
I lost my instuctions for the JS200 variable skill saw, I don't know how to load the saw blade.
The JS200 jigsaw has a manual blade clamp so you will have to loosen the two screws on the front of the blade clamp. Insert your blade (teeth forward) and slightly tighten screws alternately so as to leave your blade straight. Once snug then you can tighten both screws completely. Any questions please post back.
Oct 16, 2009 | Black & Decker Saws
Need to change the blade on my sawsall
Make sure the cord is out of the plug! grasp the knob where the blade enters the machine, turn it 1/4 turn R or L and pull the blade out
Sep 29, 2009 | Porter Cable Variable Speed All-Purpose...
Borrowed a B&D jigsaw model 7571 want to know how two use the other speed and how to put the blade in properly....does not seem to cut without great force....Cindy
arrowred.jpgExclusive Quick Clamp® tool free blade change provides easy, tool free blade changes
arrowred.jpgAccepts U and T shank blades for use with your preferred blade
Aug 15, 2009 | Black & Decker Saws
How to remove the blade on a tiger saw quick-change,model#737?
At the base of the blade where it attaches in the saw you will see a round in shape with ridges fixture. Turn it so the slot is in line with the blade. Then you will be able to remove the blade. If the fixture does not turn, move the blade up and down while you turn the fixture.
Jun 19, 2009 | Porter Cable Variable Speed All-Purpose...
Broken blade on a porter cable 737 tiger
This is a jigsaw miscatagorized as a chainsaw. Do you have a blade big enough to drop 24" tree? We don't answer jig saw questions in the chainsaw section.
Mar 30, 2009 | Porter Cable Variable Speed All-Purpose...
My husband has a BLACK & DECKER JS515 VARIABLE SPEED JIG SAW WITH QUICK CLAMP 3.5 AMP which i accidently broke the blade on...i cant figure out how to change the blade..any help would be greatly...
Here is a link to the instruction manual, and just under the place where it says Save These Instructions it tells you how to change the blade.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90520882,JS515.pdf
Fitting the saw blade (figure A)
- Hold the saw blade (9) as shown, with teeth facing forward.
- Push the lever (3) downwards.
- Insert the shank of the saw blade into the blade holder (10) as far as it will go.
- Release the lever.
There is a little lever where the base of the blade fits into the holder that you depress to release the blade...You can see a picture of it in the manual.
I hope this answers your question...if so, please take a aec to rate this post...thanks.
Mar 23, 2009 | Black & Decker Single Speed Jig Saw
Milwaukee Tool Milwaukee Orbital Jig Saw with L.E.D. 6268 - 21 Logo
204 people viewed this question
Top Milwaukee Tool Saws Experts
Jim Thurston
Craig Butler
Craig Butler
JOHN LAPIER
Are you a Milwaukee Tool Saw Expert? Answer questions, earn points and help others
