Question about Refrigerators
The ice maker stopped making ice. No cubes in the hopper. Is there a reset or something?
  • Refrigerators Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Sep 11, 2010
I have a french door fridge and it stopped making ice. Is there a reset button or something?
No. There several things that can cause this problem,valve,freezer temp, bail on ice maker down, cube stuck in ejector fingers, open high temp cutout, or a dead ice maker
Apr 27, 2017 | Refrigerators
Electrolux will not stop making ice.
Sounds like the ice level switch is either jammed on or is faulty.
Look for a flap of some kind that rests on the ice when it's made. Should be located at the back of the hopper.
Jan 07, 2014 | Refrigerators
The ice-cube maker on our Sub-Zero 650 has stopped making ice.
try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
Apr 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
Is it true that if you remove the white box where the ice cubes fall into, that it will stop the ice cubes from being made? I am interested in temporarily stopping the ice cubes from being made (4 months...
Removing the box may stop ice making on some refrigerators but not all. Look for an on-off switch inside your ice maker. Turning it off will not only stop the cubes from forming but in some cases will also stop the freezing action so you should remove any cubes that are there or they will melt and the melt water will run out of the ice maker. If there is no on-off switch you can raise the sensor arm up or block the ice detector beam to trick the ice maker into a "full" mode. That will stop the ice making function but not the freezing function. You could also turn off the water supply to the refrigerator if you do not need the water dispenser to work when you are not making ice cubes.
Oct 16, 2009 | Refrigerators
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Ice maker won't dispense ice cubes help
it may be as simple as realigning the awger
make sure the hopper is in all of the way
Sep 22, 2009 | Refrigerators
I have a GE Profile Side by side that is working fine except the ice maker won't dump the frozen ice cubes in the tray. Another party in the house decided it would be a good idea to put water in the tray...
The ice maker is basically frozen. There are two fixes for this condition. If you can transfer all of the food out to another appliance you can unplug and open the doors and let it completely defrost on its own.
the other method is to use a blow dryer. When you have completely defrosted the ice maker and thoroughly dryed it spray the ice cube tray with pam cooking spray which will act as a lubricant. When you are ready to make ice again expect the ice maker to take about 24 hours before the first batch of ice cubes are ejected.
Jun 16, 2009 | GE Profile PSS26NGS Side by Side...
Ice maker not working
I would check the ice maker assembly itself, perhaps an ice cube has not completely exited the mould,and is preventing the ive maker form cycling again
Jan 10, 2009 | Maytag 23 cu. ft. Side-by-Side...
THE ICE CUBE DISPENSER 0NLY SHOOTS CRUSHED ICE
yes and no ...... there is no real adjustment for it but you may have a sticking solenoid .....OK in the back of the unit remove the hopper and you will see the solenoid loop (white Plastic) in the back wall this need to pull up in order for the unit to dispense cubes. it maybe sticking ....now by moving it up and down a few times with your hand to make sure it is free....next dump all the ice out of the hopper and check the arm thathat sticks out the back of the hopper make sure it is not frozen after that reassby and place a few cubes back in the hopper to see if it is working..Let me know
Feb 16, 2008 | Kenmore 25.4 cu. ft. Side-By-Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
