Question about Microsoft Internet Explorer 8
Can't find or srart ie 8 in win 7 - Microsoft Internet Explorer 8
    President:
  • 2,291 Answers
If you are using IE 7/8 you can try to run the program without loading any add-ons to see if one of them is causing the problems. To do this, click Start -
Posted on Sep 16, 2010
How do Iget my browser sback
Probably just the icon (shortcut) has been deleted. Look through the program items under the start button on Win 7, or use the Win 8 search tool for "ie", or use the disk file search on drive C: for "iexp". If you find it, you should be able to right click and use the create shortcut option. If not found, you may need to go to Microsoft support and download and re-install IE. You could also go to Mozilla and download Firefox, or get Chrome from Google, as alternative browsers to IE.
Jul 25, 2014 | Computers & Internet
Can asus k42f be ugraded to windows 8?
Windows 8 has updated drivers as much as you would get from Asus built into win 8.
Go to devise MGR, if windows 8 did not load drivers, you will see a flag.
See what hardware did not load a driver and then use the win 7 driver.
You don't do anything to make a win 7 driver work, if the driver is newer, and signed it will install, if it's older then the driver windows installed, it won't install. If you see a flag and windows did not install a driver, then try the win 7 driver, or go to the MFG of the hardware and see if there is a win 8 driver.
You can also run windows update, if win update see's a newer driver out it might pick it up and give you a install option.
Now, your chipset, and most hardware has windows 8 drivers out.
The drivers are the biggest problem, the biggest problem for you is the BIOS was not set for windows 8.
So you could find even with the best drivers, win 8 slower or has bugs more then win 7 will have.
Me, I would bench test all the hardware with win 7, then with win 8 and see which one is better.
Apr 08, 2013 | ASUS K42F A1 Notebook
How to stop ie from pop up when I use msn mail and more. I have 3 computers, win XP, Win Vista, Win 7 Professional and ie 8 on XP and ie 9 on win 7 and vista.
IE: 8 right click in the top toolbar select the command bar this will add it to the toolbar then on the far right hand side select the tools then from the drop down list pop up blocker make sure its turned on and settings
hope this helps
Aug 17, 2012 | Computers & Internet
I am using windows 7 but I am unable to install internet explorer
Win 7 will only work with I.E. 8 or 9. You have to disable your virus checker before you can down load and install I.E. 8 or 9.See: http://support.microsoft.com/kb/917925
Jun 15, 2011 | Computers & Internet
I use : WIN 7 Ultimate 64 bit . IE 8 for 32 bit ( I tried IE 9 Beta, with catastrophic consequences ). Many times I get the following message WITH NO SOLUTION : " IE HAS STOPPED WORKING. A problem...
I would perform a systems restore and take it back to the day before you installed it and it will restore the system to a working state.
If you need me to step you through it please let me know.
Cheers,
Dave
Nov 26, 2010 | Microsoft Internet Explorer 8
The new IE 8 set up can not uninstall old version of IE 8 What to do? Win XP prof 32
Click START
Open Control panel
Open Add/Remove Programs
Click on Windows components Tab
Uncheck Internet Explorer in the list
Click OK - Continue with the Instructions and Restart the PC
Try opening I.E 8 or Installing, If not follow the above steps and Put Check on I.E and Restart PC and later Start I.E 8 Installation
Jun 17, 2010 | Microsoft Internet Explorer 8
Remove IE 8 and Replace with IE 7
First uninstall IE totally, don't try for upgrade by online which results of loading IE 8 and so try to get a pack of IE 7 individually / separately along with other CD's under support material theme and have fine browsing
Dec 16, 2009 | Microsoft Internet Explorer 8
Problems trying to install Internet Explorer 8
Firstly Remove SP3 through
http://support.microsoft.com/kb/950249
Then Download SP2, it works fine. Either way u can also go for SP3
Then try again for IE* or Mozilla
Hope It Works Out ur Problem
Apr 12, 2009 | Microsoft Internet Explorer 8
Open Questions:
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; nsapshr 10.0.3) Timestamp: Mon, 7 Jul 2014 20:45:22 UTC Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js
Jul 07, 2014 | Microsoft Internet Explorer 8
See all Microsoft Internet Explorer 8 Questions
Microsoft Internet Explorer 8 Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
