Question about Haier Dishwashers
I have a IAG dishwasher Model IDI6IE 1 (Haier) of which the door hinge cord broke I have tried numerous outlets incl.Fisher and Pykel I understand from Doug Smith Spares that the part number is 1398026700 hinge cord but no result sofar
  • 2335 Answers
SOURCE: broken door spring on kitchenaid dishwasher
You will find the parts you need here by entering the model number and search for the part.
They will be able to help you with the installation as well.
Posted on May 07, 2008
  • 166 Answers
SOURCE: Dishwasher door hing broke
You need to write down the model number of your dishwasher and seek a local supplier who carries the hinge replacement for that model. It will likely take a while to order the part. You might want to try online. I remember a good dishwasher repair guide site at
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Dishwasher.htm
I think they offer a link to seek four free estimates from appliance contractors who may be able to fix it faster--since they might have the part on hand.
Posted on May 25, 2009
ehmbee
  • 9 Answers
SOURCE: Haier Dishwasher hdp18pa - Power reset
Are you blowing a fuse or throwing a breaker? Either way there is a chance that no outlet you have chosen to test with yet is on a circuit with sufficient amperage-I had this with a microwave I recently had installed. If you have the manual, check for requirements regarding amperage. You then need to be sure you are using an outlet with amperage comparable to the requirements-this is on your fuse or breaker. If your requirement is, say, 20 amps, a 15-amp or less breaker or fuse is going to fail. I had to go to a 'clean' circuit from my garage with nothing on it to find out I did not have enough amps in my circuit. My solution was a dedicated breaker. Another option is to use my second option (which I did not need), to plug it into a gas generator with sufficient wattage/amperage. This ensures nothing else is on the circuit.
Failing all that, it could be the power supply for the washer, a circuit board issue, etc. Don't mess around if you don't understand electricity, though-it's not worth frying yourself.
Finally, if it worked ok before and this has just begun to happen, I'd tend to think it's an issue with the washer itself. Hope this helps.
Posted on Jul 07, 2009
  • 17 Answers
SOURCE: Haier dishwasher wont run and shows a code OP
The code "OP" means the door is open. I would suspect you have a faulty latch. The dishwasher thinks the door is open and will not start the cycle.
Posted on Aug 02, 2009
SOURCE: Fisher Pykel draw dishwasher
my fihser dishwasher is showing f2 and not draining
Posted on Apr 28, 2010
Model 87278918TD Fisher and Pykel dishwasher manual
F&P usually have the user guides for download from their country-specific websites.
I cannot find a dishwasher with this model number. Where are you located?
Jun 23, 2016 | Fisher Dishwashers
E6 error code on fisher & pykel single door dishwasher
1-Time Flash & E6 error troubleshooting, part 1 of 3 for ...
? 3:04
https://www.youtube.com/watch?v=sYNN1Rvc7r0
Dec 18, 2012 - Uploaded by MitsubishiHVAC
1-Time Flash & E6 error troubleshooting, part 2 of 3 for Mitsubishi Electric Cooling & Heating - Duration: 2 ...
LG Control Panel Overview
www.lg.com > ... > Repair > Locate Repair Provider
LG ElectronicsAn OE error code indicates the washing machine is draining slowly or not at all. This is usually ... When you see the E6 error icon, it means there is a clutch error.
Nov 19, 2015 | Fisher and Paykel Dishwashers
Fisher pykel dishwasher not cleaning dishes properly
Avoid overloading the dishwasher.
Ensure the spray arms can rotate freely.
Remove scraps from dishes before loading.
Hope this will help
Feb 07, 2012 | Fisher and Paykel Dishwashers
Drawer won't open and get beep code 2 short 1 long
The drawer door seal is locked in. This could be either because the controller has lost power or the seal actuator motor is faulty.
You will have to force open the drawer before you can do anything. (Turn off the mains power when you work on the dishwasher)
Let me know if you can handle electric/ mechanical repairs so that I can guide you further. Otherwise you should call a technician. If you are getting beeps then most likely the door seal system is the problem.
Are you able to use the top drawer?
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher is Haier ESD300. I had just started to open the door and heard a loud "pop" kind of sound. The door just falls down with no resistance now. There is a string, yes a string, hanging from the left...
You'll have to slide the dishwasher out from under the cabinet to get a better look at the hinge cable system and you should be able to look at the other hinge to see what broke. could be the cable itself or the spring or a retainer. You will not know until you compare to other hinge. After you find the problem you can go to www.repairclinic.com and they may have the part and the picture if not you can talk to a person live chat. Hope this helps
Mar 08, 2010 | Haier ESD300 24 in. Built-in Dishwasher
Haier HRF-488FR/***
hi there, i noticed your post was in 08 did you find a seal to fit your fridge i have a hrf 488 fr/a and fisher and pykel are looking after them now... they advised be that this model is obsolete now and no longer have parts available.
May 19, 2008 | Haier Refrigerators
Fisher pykel original dish drawer
if you pull out the lower drawer, there s aside release pin on either side of bottom corner of hte drawers when extended. a small maybe quarter sized hole( no need to mess with that only removes the face panel) but under it is a release that you can push in and back a little, this will unlock from the drawer hinges(slides) just nee to lift up and over to the left slightly, on the back wall behind hte drawer youll find a pretty good trouble shooter for this model, itll tell you what hte code is and will try to walk you through as to what might of happened as well as recommended repair
Mar 26, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
89 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Melissa Martin
Melissa Martin
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
