Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
So i Stat Plot to get a to get a linear regression graph, but it does not tell me the correlation coefficient. How do I get that to show up?
  • Texas Instru... Master
  • 8,073 Answers
If the OS of calculator has been upgraded to version 2.53 MP, press [MODE] to open the configuration screen of calculator and scroll down to get the second page. Use down arrow to highlight the ON on line STATDIAGNOSTICS: Off ON
See screen capture:
If you did not upgrade to the OS version 2.53MP, then you can access the catalog of commands to execute the DiagnosticsOn command.
Press [2nd][0] to open catalog.
Press [X^-1] to jump to the first command that starts with D.
Scroll down till you reach DiagnosticOn. Press [ENTER] to execute command.
From now on, unless you change settings, the Correlation coefficient will be displayed along with the equation of best fit.
Posted on Sep 10, 2010
Testimonial: "excellent. not even my own teacher would help me as much!"
Am trying to calculate corelation on a Casio fx-9750GII,
Press Menu.
Use arrows to highlight STAT icon and press EXE.
Enter your data in two lists (x-values in L1, Y-values in L2)
Press F2 to activate the CALC Tab at the bottom of screen.
This is what you see.
Press F3 to activate the REGression tab.
This is what you will see: the TABs at the bottom of screen.
Each tab corresponds to a regression model: X-linear, X2 quadratic, etc.
If you press F3:X^2, you get the following
You see the parameters of the regression equation, the coefficient of determination r^2, and the Mean Square error. No correlation coefficient is defined for this regression model.
For other models like linear, logarithmic, power and exponential regressions, the correlation coefficient is defined and is thus displayed with the regression equation. It is the r-value.
Jul 31, 2011 | Casio FX-9750GPlus Calculator
Whenever i enter coordinates for a scatter plot or best fit line the point do not show up neither does the line i can trace the points and the calculator tell the coordinates but they are not visible
Two possibilities:
  1. Graph is out of range (out of the window). If your data is positive set Xmin=0 and Ymin=0. Set Xmax a bit larger than the maximum x-value and YMAX a bit larger than the maximum y-value. You can also press [ZOOM] and select [9:ZoomStat].
  2. To mark the points you may have select the dot and your calculator screen is too dim.
To help you setup your calculator To perform regression analysis I am inserting here a copy of a more detailed post of mine where I show the complete procedure applied to a quadratic regression.
Before doing statistics, you have to prepare the calculator by clearing old data that may generate errors.
A. TO CLEAR OLD DATA
  1. Press [2nd][ ] (MEM) to open the memory management screen.
  2. Press [4:ClrAllLists]
  3. The command echoes on main screen, press [ENTER] to run it.
  4. Calculator displays Done.
B. RUN the SETUP EDITOR Command
  1. Press [STAT][5:SetUpEditor] [ENTER] ; calculator displays Done.
C. TURN DIAGNOSTICSON option (optional)
To obtain the correlation coefficient in a statistical analysis on the TI8xPlus family of calculators you must activate the DIAGNOSTICSON option. To access the command
  1. You press [2nd] [0] (CATALOG)
  2. While the list of commands is displayed, press [X^-1] (D)
  3. Cursor jumps to first command that starts with D, dayOfWk(
  4. Press the DownArrow 9 times to reach DIAGNOSTICSON
  5. Select it and press [ENTER]
  6. Command echoes on main calculator screen with blinking cursor
  7. Press [ENTER] to set the option
  8. Calculator displays Done.
From now on, if a correlation coefficient has meaning for a regression model, it will be calculated along with the other statistical results. If it has no meaning to the model it will not be calculated.
D. ENTER THE DATA
Press [STAT][1:Edit]
Type in your D (X ) values in L1 and the N (Y) values in L2 (see picture 1). Sorry the picture does not have YOUR values.
TO OBTAIN statistical RESULTS (optional)
  1. After you finish entering the data, press [2nd][Quit] to exit StatEditor.
  2. Press [STAT] and highlight Menu (CALC)
  3. In the list select [2:2-Var Stats]
  4. Command echoes on main screen.
  5. Press [ENTER] to calculate the stats
Here is what one gets with the data above.
Notice the Down Arrow next to n=7. That means the results screen has more values. Press the Down Arrow to display.
You notice that the n=7 line now has an arrow pointing Up. Notice the Down Arrow on the bottom line (more data is coming). Here is the rest of the statistical results.
There is no arrow at the bottom of the picture. End of statistical results.
The screen captures with 2-Var Stats summarize all the statistics.
However there is no correlation coefficient, no line of best fit, etc. To obtain that you have To perform a regression analysis.
E. PERFORM A REGRESSION ANALYSIS
To perform a regression analysis, you must try several regression models and then find the one that mimics the raw data best. Select Regression model ( exponential, linear, sine, quadratic, etc.) Here I selected Exponential
  1. Press [STAT] , highlight [CALC]
  2. In the list of regression models select [0:ExpReg]
  3. The command ExpReg echoes on main calculator screen.
  4. If you press [ENTER], you'll get your equation but you will not be able to draw the curve on top of your data to verify the goodness (no it is not a swear word) of the fit. So you must save the equation as a function in Y1 variable.
  5. While ExpReg command is still in command line, press the [VARS] key.
  6. Highlight the [Y-VARS] menu and select [1:Function], then press [ENTER].
  7. In the Y function variable list select [1:Y1]
  8. At the command line, you have ExpReg Y1.
  9. Press [ENTER] to save the equation of best fit in Y1.
Here are your results. (These are your actual results)
You also have r and its square.
Since the equation is saved in the Y1 function it can be superposed on the scatter plot. You just have to press GRAPH and it will be drawn. But that will not tell how good the fit is, until you see the function drawn on top of the raw data.
F. DRAWING THE SCATTER PLOT AND BEST FIT CURVE ON SAME SCREEN
Regardless of the curve of best fit, you can draw a scatter plot as follows.
  1. Press [2nd][Y=] (STATPLOT)
  2. Select [1:Plot1...Off] and press ENTER to open plot1 configuration screen
  3. Use arrow to highlight On and press ENTER
  4. Use the Down Arrow to move cursor to the line Type.
  5. Select the first icon for a scatter plot. NOTE: To navigate the 6 statistical stat plots on the line Type, use the right or left arrow (to backtrack), but not the Up or down arrows.
Here is the configuration screen
Here plot1 is active (ON), it is scatter plot (first icon) the XLIST is L1 by default but you can change it to some other list. Notice the highlighted A cursor on XLIST line. It means that the [ALPHA] keyboard is active.
On the line Mark you can choose the appearance of the raw data point.
And here are your two graphs: the raw data scatter plot and the line of best fit on the same screen. On the picture the ZoomStat option was used.
The graph above represents a parabola and has nothing to do with the sample data entered. But it shows the raw data and the curve of best fit on the same screen.
Sep 03, 2010 | Texas Instruments TI-83 Plus Calculator
I need to find the equation for some points with my calculator but they are for an exponential regession. How do I do this?
  1. Press [2nd][+] (MEM) to open the memory management screen.
To obtain the correlation coefficient in a statistical analysis on the TI8xPlus family of calculators you must activate the DiagnosticsOn option. To access the command
  4. Press the DownArrow 9 times to reach DiagnosticsOn
D. ENTER THE DATA
TO OBTAIN THE STATISTICAL RESULTS (optional)
Here is what you get (THESE~ARE NOT YOUR RESULTS). Your results will be different.
Notice the down arrow next to n=7. That means the results screen has more values. Press the down arrow to display.
The screen captures with 2-Var Stats summarize all the satistics.
However there is no correlation coefficient, no line of best fit, etc. To obtain that you have to perform a regression analysis.
To perform a regression analysis, you must try several regression models and then find the one that mimicks the raw data best. In this particular case, you have already decided to do a linear regression, and that is good for me. I do not have the time to take you through all of them. In this step you must select the exponential regression model.
  4. If you press [ENTER] you will get you equation but you will not be able to draw the curve on top of your data to verify the goodness (no it is not a swear word) of the fit. So you must save the equation as a function in Y1 variable.
You also have r and its square. You need to read your theory to know which of the two correlation coefficients you have been asked to obtain.
Since you saved the equation in the Y1 function you can draw it. You just have to press GRAPH and it will be drawn. But that will not tell how good the fit is, until you see the function drawn on top of the raw data.
  4. Use the down arrow to move cursor to the line Type.
Here plot1 is active (ON), it is scatter plot (first icon) the Xlist is L1 by default but you can change it to some other list. Notice the highlighted A cursor on XLIST line. It means that the [ALPHA] keyboard is active.
On the line Mark you can choose the appearnce of the raw data point.
Now, it is up to you to accept this model or to try another model.
May 13, 2010 | Texas Instruments TI-84 Plus Calculator
How to Plot & graph or Model Quadratic on the same screen. I want to plot the points from adta table & then using Quad regression I got the equation ,but I can't graph on the same screen as the...
Read this post. It answers all your questions and shows you HOW to do find your equation of best fit, correlation coefficients, etc.
D. ENTER THE DATA
Apr 16, 2010 | Texas Instruments TI-84 Plus Silver...
I need to find the equation for some points with my calculator, but they are for an exponential regession. How do I do this?
D. ENTER THE DATA (ENTER your own data)
Type in your X values in L1 and the Y values in L2 (see picture 1).
TO OBTAIN the statistical RESULTS (optional)
Here is a sample of what one gets .
Here are sample results.
You also have r and its square. You need to read your theory to know which of the two correlation coefficients you have been asked To obtain.
Mar 21, 2010 | Texas Instruments TI-84 Plus Calculator
TI-83 Texas calculator, exponential regression. How to input data in calculator? I have D list (time/days list of 1,2,3,4,5,6,7) and N list (6,10,13,27,42,65,120)- how do I input into calculator and draw a...
D. ENTER THE DATA
Mar 14, 2010 | Texas Instruments TI-83 Plus Calculator
How do u store linreg(ax+b)as y1 on ur graphic calculater
When you press [STAT] and right Arrow to highlight CALC you see two linear regression model [4:LinReg(ax+b)] and [8:LinReg(a +bx)]
If you select [4: ...] the command echoes on main calculator screen as LinReg(ax+b) and a blinking cursor
If you press [ENTER] you will get your equation, a, b, and r^2 if DiagnosticsOn command has been executed before. However you will not be able to see the line of best fit on top of the raw data scatter plot.
To save the equation of best fit in a function variable, ex Y1, you complete the command as follows
LinReg(ax+b) [VARS][=>][Y-VARS][1:Function][1:Y1]
The Y1 variable will appear on main calculator screen, and you have
LinReg(ax+b) Y1
Press [ENTER]
Screen display the equation, its parameter and its correlation coefficients (if so configured).
Press [GRAPH] to draw the line of best fit on top of the scatter plot.
Here are two screen captures to show you the equation and the line of best fit.
As you can see from the value of r^2, and the graph, a linear regression does not seem good.
Feb 01, 2010 | Texas Instruments TI-84 Plus Calculator
I own a TI-84 Plus (silver edition). Does this calculator have formulas built in for the least squares line so I might enter the data to get the values for b and m? If so will it give me the correlation...
A. To clear old data
B. Run the SetUpEditor command
C. Turn DiagnosticsOn option (optional)
D. Enter the data
Type in the X values in L1 and the Y values in L2 (see picture 1)
To obtain the statistical results
Here is what you get (with you data).
The screen captures with 2-Var Stats summarize all the satistics. Some of the values your are looking for are among the result. NOW it is you mission to identify what you need (I chewed all the work for you).
Perform a Regression analysis
To perform a regression analysis, you must try several regression models and then find the one that mimicks the raw data best. In this particular case, you have already decided to do a linear regression, and that is good for me. I do not have the time to take you through all of them. A linear regression it will be.
  2. In the list of regression models select [4:LinReg (ax+b)
  3. The command LinReg(ax+b) echoes on main calculator screen.
  5. While LinReg(ax+b) command is still in command line, press the [VARS] key.
  8. At the command line, you have LinReg(ax+b) Y1.
The slope is a and the y-intercept is b. You also have r and its square. You need to read your theory to know which of the two correlation coefficients you have been asked to obtain.
Drawing the scatter plot and the raw data on the same screen.
  2. Select [1:Plot1...Off] to open plot1 configuration screen
And here is your two graphs: the raw data scatter plot and the line of best fit on the same screen
Jan 28, 2010 | Texas Instruments TI-84 Plus Silver...
You are given the following data. x y 2 16 3 11 4 12 5 15 5 11 7 8 7 11 Find: - SS(x) - SS(y) - SS(xy) - The linear correlation coefficient, r - The slope b1 - The y-intercept, b0 - The equation of the...
OK, you convinced me to do your homework for you.
D. Enter the data
N
Jan 21, 2010 | Texas Instruments TI-83 Plus Calculator
How to calculate the coefficient of linear correlation using casio cfx-9850 Ga plus
Although the coefficient of correlation is well defined for a few regression models, you do not calculate it directly because your calculator does that for you.
I could just tell you that it is displayed along with the statistical results (equation of best fitting curve, ) but if you do not know how to do that you will just shoot my post. If you know how to do a linear regression, stop right here and ignore what follows.
For those interested: How to do a regression on the calculator
I am sorry but I will have to assume that you know how to enter the data through the [MENU][STAT].
  1. After you finish entering all the data
  2. Press [F1:Graph], select Gph1, Gph2, or Gph3.
  3. Once the graph of the experimental data is drawn, you will have access to the diverse regression models.
  4. Your choices are
  5. [X:Linear]
  6. [Med-Med],
  7. [Quadratic :X^2]
  8. [Cubic;X^3]
  9. [Quartic: X^4].
  10. Press [F6] to scroll right to access the others
  11. [Logarithmic:LOG],
  12. [Exponential :EXP],
  13. [Power :Pwr] and
  14. [Sinusoidal: Sin]
After you select a model and press [EXE], the screen displays the equation and its various coefficients, a correlation coefficient if it has meaning, etc.
On that same screen, you have a menu option [F6:Draw]. If you select it, the regression curve will be drawn on the same screen as your statistical graph. This allows you to judge if the fit is good. If it is not, you have the option to choose another model.
The other option [F5:Copy] allows you to save the regression equation in the Y1, Y2, etc. variables.
Jan 03, 2010 | Casio CFX 9850GA Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
146 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
