Question about Yamaha POCKETRAK 2G Pocket Stereo Recorder
It is stating that the memory is full when it is not.. I go to each folder and nothing is there
I had my Pockettrax CX saying "Memory Full" although I'd deleted everything. What helped finally: I formatted the SD. Now I've got all the memory back. Don't know if that would help the recording speed. but maybe. IMPORTANT: SAVE ANY FILES on your LAPTOP before formatting the SD.Here's how to format the SD:Go to Menu.Click on "Common Menu"Scroll down until you get to "Format"Press "Yes""Formatting SD" comes up and, VoilaYou've got more space.
Posted on Dec 10, 2012
This link explains how to reformat.
http://faq.yamaha.com/us/en/article/music-production/recorders/pocketrak_2g/4497/6061/
Posted on Feb 12, 2012
I was trying to update my map on my nuvi 1350 and it said the internal memory was full. i tried to clear up some space and i ended up deleting some folders. I did back it all up, but now it won't let me...
The only files you should delete are unused voice files (.vpm), pictures files (.jpg), sum files (.sum) and you can delete the gupdate.gcd file as it is not used once the unit has been updated. You can also delete archived gpx files (.gpx) within the gpx archive folder but do not delete the current.gpx file (this file holds your favorites) or the gpx folder. Deleting folders is not recommended. That is a good way to delete files that you may need.
You can also right click on the Nuvi's drive letter and select "tools" and run an error check on the flash drive to make sure there aren't any errors on it that may involve how much space is really free.
Lastly, you may have to limit the map region, so that the map isn't too large. For example, instead of having US & Canada on the map, perhaps only have the US with the lower 49 states. You can limit it even further by selecting lower 49 states and selecting regions like Southwest (SW) or northwest (NW) etc.
f you really want to bypass the whole memory issue, just put the map on an external micro 4GB SD card. This way, you don't have to worry about deleting anything off of the flash drive.
I hope this info helps.
SHARCNET-USA
www.sharcnet-usa.com
Nov 30, 2013 | Garmin nuvi 1350 Car GPS Receiver
I think my palm pre was invaded by a virus when i connect this to my computer to upload photos..I cannot take pictures and even even videos..there was a message stating that i cannot take pictures because...
You are not getting this error because your memory card is having 11.4 G available but this error is coming because your phones primary memory is full. Kindly browse the phones primary memory and delete what you don't want. In case you are unable to see the files then connect it to pc and then browse the phones primary memory and from tools menu select folder options and then select show hidden files then you can delete whatever is not required and the error will go.
Apr 28, 2011 | Palm Pre Cell Phone
I am using sciphone i68+ as well.i got same promblem as u guy that i copy music into memory card then go to Audio music player but i cant use Audio music player.Just when i copy music into phone memory,it...
The i68+ have a folder in the memory card that is called My Music, you need to transfer, copy or move you songs to this folder, if you say the the memory is not enough for 3 songs, then you are saving the songs in the phone, not in memory. If you transfer from BT and it state that is full, then again you are saving it in the phone and not in memory, you need to go to the BT settings and change the saving location.
Jun 25, 2009 | Apple iPhone (16 GB) Smartphone
I accidently deleted the fuji folder thats inside the dcmi folder on my external memory and now i cant get the external memory to work or even a new memory card. Help
after several hours of trying to get answers through you and calling e mailing... everything with absolutly no help whatsoever. No one understood what i was saying. I kept turning off the camera and then trying everything again. I even used a different card and still nothing it still said memory was full when there was nothing on it. So what i did was i took a few pictures without the external memory.. so it used the internal memory then i reviewed them so i seen that worked. After i did that i re inserted the memory chip and it must have reset itself because all of a sudden it worked. I figured it out myslef.. so much for technical support.
Jul 04, 2008 | Fuji Cameras
Says drive is full with nothing on it.
the driver may need to reinstalled, usually when it said disk space is full is because it is reading it, but the driver is not workng properly or
If you're able to see the drive under your my computers, you should be able to right-click it and click format. That should clear up all the space on the drive, even though there is nothing on there.
Jun 05, 2008 | RCA TH1101 MP3 Player
MEMORY SAYS FULL
The Garmin Nuvi 200w comes with a 1GB solid state drive. The problem lies with the fact that the North American map preloaded with the 200 series is already around 910MB plus the help files and additional languages most of us don't use like Russian, Korean, Japanese etc etc that push it past 980MB or so. Now do the math and you'll find that the 37MB update doesn't fit in there, so you can choose not to update.
You can plug the Nuvi to your PC and explore the Garmin folder and get rid of the Help folder, which will not hinder the operation of the unit but will disable the HELP button when you power up the unit, and you can also remove all the languages you don't use from the Speech and Text folders.
Also when you add a 1GB SD card to the Nuvi, it doesn't add the extra storage to the actual unit. It just allows you to add more maps or pictures to it, but you cannot update the main file in the Solid State Drive by just adding more memory. The main files' name is GMAPPROM.IMG by the way and it's the biggest one at around 900 some MB's. You can just follow my instructions above and you'll be fine, if by any chance you bought another map you could load it up on the 1GB SD card. Except for ALL of Europe because that's 1.4GB if you load up all of it, so I would choose only the countries I know I'd visit.
May 29, 2008 | Garmin nuvi 200W GPS Receiver
Panasonic Memory card is full
You might be looking in a different (empty) folder on your memory card. Put the card into your computer media reader and see what's on it. Otherwise just format the card from your camera and that will erase the entire card no matter what's on it.
Sep 20, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
Yamaha POCKETRAK 2G Pocket Stereo Recorder Logo
273 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
