Question about Southbend Ovens
Hello I have a electric convection oven and when i start it the fuse burns as long as i don't close the doors the panel works and the temp controls and time controls work but close the doors and it will start for one second and then burn the fuse thanks ivan
  • igadc Sep 10, 2010
    hello again
    I don't know if i told you that this is a comercial oven and when i looked at the doors they do close at the same time and the switch there is only one swicth could it be the heat element or should i change the switch i have now
    burned my last fuse so it will take me a little time to get more the oven has not been moved in years also could you tell me where the model # is and the name of a company that i can get the elements or a switch
    thanks for the help
    ivan
    Genius:
  • 1,622 Answers
Another possible reason for the fuses continuing to blow could be because of a short circuit. You should carefully inspect the wiring of your cooker to make sure that nothing is shorting out where it shouldn't be. A short circuit will cause the fuse or circuit breaker to blow until you fix it.
If any of the wires have become frayed or have been bitten by mice then this could be causing the short circuit. Assuming the cooktop did work in the past then something has changed which is stopping it working.
Hope this help in fixing the problem. take care....
Posted on Sep 11, 2010
    Genius:
  • 1,478 Answers
The cause is almost certainly related to either the door interlock switches or the door itself. Marginal door alignment, broken 'fingers' which operate the switches, dislocated parts in the interlock mechanism, or a defective interlock switch may result in either consistent or erratic behavior of this type.
On some ovens, this can happen at any time regardless of the control panel settings or whether the oven is in the cook cycle or not. On others, it can only happen when interrupting the cook cycle by opening the door or when initiating the cook cycle from the front panel (if the switches are in the wrong state).
The rational for this basic design - some form of which is used in virtually all ovens - is that a defect in the interlock switches or door alignment, which might result in dangerous oven radiation leakage, will produce a hard permanent failure. This will prevent the oven from being used until it is inspected and repaired.
As noted, one of the interlock switches is actually across the power line. If the switches are activated in the wrong sequence due to a misaligned door, that switch will not turn off before the other switches turn on shorting the power line. Similarly, if its contacts are welded closed, the power line will be shorted when the other switches close.
Inspect the door, its mounting, and the plastic 'fingers' which operate the interlock switches as well. Again, if the sequence is not correct, the power line will be shorted blowing the fuse. If the oven was dropped, then such damage is quite likely. Look for broken or dislocated parts, warpage, and other indications of problems with the door and interlock mechanism Of course, if the oven was dropped, there could be much more extensive internal damage as well.
Take care.
Posted on Sep 10, 2010
Oven temp will not change
Most ovens have BAKE, BROIL and yours might have CONVECTION. Turn each on independently. If all don't work its one problem if only one doesn't its another
Also is it the gas doesn't ignite or it ignites then no temp change (or electric gets to xx degrees but doesn't get hotter?
Sep 04, 2011 | Wolf Range WKGD-2 Gas Double Oven
Maytag MEW6527B Oven.Push panel buttons,no beeps or codes. Convect roast starts at temp 888 then adjusts to 550, for 11:11 time, only #'s that work. Checked Sab mode, door lock, panel lock. Circuit...
I had almost the same problem I to have a Maytag.I was not getting any readings from my panel and the oven would not work.I called up Maytag and they told me to move the oven away from the wall.Whats happens the computer board heats ( Display ) up causeing this problem.I moved the oven a little bit away from the wall and now it works great.I hope this helps you.
Apr 23, 2011 | Maytag MEW6527B Electric Single Oven
We have a 30 in prostyle electric double wall oven - the oven takes forever to preheat and the doors do not seal tightly when they are closed.
Hello- Many ovens use spring-loaded hinges to carry the weight of the door. Over time, these springs weaken or the hinge gets bent just enough to not fully close door. The door gasket can also become flat and stiff, compounding problem. Any small gap releases heated air, and oven will not heat up properly. Replacing the door springs should solve problem.- Thanks -Ed
Mar 14, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Convection oven burns most things GE electric. Is there some way to turn off the fan
Don't press the convection bake key before entering your oven temp,just push the bake key first then set temp and then start.If this doesn't help GE help center is awesome @ 1-800-626-2000
Nov 22, 2009 | GE Ovens
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
Oven won't heat
Check your main panel. If you ran it for a long time with the door open, the elements never reached their shutoff temperature. Quite possibly, you burned them out.
Feb 19, 2009 | Ovens
Frigidaire gallery self cleaning convection oven
Press and hold the "clean" button for 5 seconds.
May 11, 2008 | Ovens
Ovens Logo
99 people viewed this question
Top Southbend Ovens Experts
Dennis Boxerman
Dan Webster
Dan Webster
Paul Bade
Are you a Southbend Oven Expert? Answer questions, earn points and help others
