Question about GE Kitchen Ranges
Short circuit with my stove top GE Profile Electric Stove. It happened when I left some water on the stove top. When I tried to reset the breaker it created a spark under the glass top in the area along the 4 knobs
hotuna
  • 288 Answers
SOURCE: Viking stove top gas burners
When you say plug I'm assuming you mean the outlet in the wall. And you checked it for 220 volts with a meter? If all this is good then maybe you need a new ignition coil. I need more info.
Posted on Nov 05, 2007
appldoctom
  • 311 Answers
SOURCE: replacing glass top on stove
its not too bad.kill the power.then under the frount of the top where the top meets the oven door .under there are screws remove those and the top lifts up as on hinges.their is a ground screw wire to loose and unplug the the wire harness that connects the burners to the rest of the stove.then all is disconnected so lift entire top off from hinged area and set upside down on table.transfer all burners to new top thats nexted to old one upside down also.when done reinstall.ive done lots wont be bad.please dont for get to help me with my rateings.God bless ,tom
Posted on Jan 05, 2009
SOURCE: f2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Posted on Apr 17, 2009
erpaalai
  • 999 Answers
SOURCE: How do I raise the stove top of a ceramic glass mo...
Open the oven door and look up across the front for 4 screws.
Eric
Posted on May 23, 2010
SOURCE: Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Posted on Sep 13, 2010
GE Spectra flat top stove electrical short
Go to your electric circuit panel. Locate the breaker for the stove. Turn it all the way OFF then back ON. This should correct your problem.
Aug 18, 2009 | GE Kitchen Ranges
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Ge profile stove top strikers stuck on
If water or liquid gets in the switch it can short the circuit and cause the igniters to fire.....try pulling the knobs off and hairdrying the switches..i had one that sparked for 2 days before they finally stopped. good luck :)
Jun 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag stove mer6769baq trips the breaker whenever plugged in
It sounds to me like there is a short circuit either in the plug or the connections at the stove. It could also be within the stove although that seems very unlikely. If this happens when your using the stove, the breaker and circuit could be undersized (required breaker size-50AMPS) Check all wires and the breaker.
Apr 01, 2009 | Maytag MER6769 Gemini Electric Kitchen...
GE Profile Electric Stove - Buttons for oven don't work
We had a bunch of storms roll through the area and we figured a surge must have fried our control panel. We decided to buy a new oven rather than spend $200 fixing this one. Luckily, our local Sears rep wasn't in it just for the commission and suggested we flip the circuit breaker off for 10 minutes to allow the range to reset itself. Works good as new! So, try this first before you make a decision. Good luck!
Mar 15, 2009 | GE JBP24 QuickClean Electric Kitchen Range
Electric stove elements stopped working
Circuit breaker is tripped duel breaker 1 of them is tripped, maybe an electrical problem causing this.
Feb 20, 2009 | GE Kitchen Ranges
GE Profile Gas cooktop stove- buzzer won't stop
Unfortunately you have to wait until it dries out. I have tried hairdryer before but most of the time I have had to leave it off overnight. FYI if you dont shut off at the circuit breaker and the sparking continues it will short out and definitely get worse
Feb 09, 2009 | GE 36 in. Profile JP968 Electric Cooktop
Ge spectra glass top stove.
Two possible reasons come to mind.  1. There most likely was a short circuit that activated the top unit. Was any part of the top glowing when you looked at it while it was crackling?
2. Be aware that glass tops CANNOT take as heavy a load of pots and pans as a STANDARD range can. The glass will crack. The stress can accumulate over a period of time and you will be left with the 4 am  madness dim experienced.
If anyone out there finds themselves in a similar situation, don't wait when  you hear the crackling. Pull the the range plug, or find the ranges circuit breaker in your electrical box and turn it off.
Nov 24, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE glasstop stove problem
Try removeing power too unit for a couple minutes. You can due this by turning off breaker. Sometimes this will reset board. If not, you may need an ERC board.
Nov 04, 2007 | GE Profile JTP18 Electric Single Oven
Kitchen Ranges Logo
644 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
