Question about NetGear CM212 Broadband Cable Modem
The internet connection is not working and it has worked before. The internet only works when it is connected directly to the comcast motorola modem.
  • 385 Answers
I'm guessing by you incomplete statement that the wireless portion of your internet is not working? How many computers? Running a router wirelessly to them? If so, from the connected computer open a browser window and type in 192.168.0.1 or 192.168.1.1 and check settings, especially security. If you can't access router do a hard reset putting it back to factory settings, then try again - when asked for username leave blank and enter default password for router if you never set one up. password is in the user's manual. might also try new drivers or firmware from manufacturer's website. user's manual is there too. hope this helped. wasn't exactly sure what your specific problem was...
Posted on Sep 10, 2010
How do I get my Zonet Router to play nice with my Motorola Modem and Comcast Connection?
If this types of issues again again then may be some technical Fault.
A> Your Network connectivity Not Good or loose.
B> Your IP Add or mac Add change or conflict.
C> Your Modem or router not proper connectivity establish.
D> Contact network ISP provider or ask some issues.
E> If possible check it loose connectivity and connection.
If not solved contact Network Support Technician.
http://setuprouter.com/router/zonet/zsr4154we/manual-915.pdf
Linksys Support Phone Number
Thanks,
Sep 05, 2014 | Zonet ZSR4134WE Wireless Router
WRT54GS ROUTER don't work with new modem
I would suggest you to look into the user manual first it may solve your problem.
Click HERE
Goodluck..
Feb 15, 2008 | Linksys Wireless-G WRT54GS Router...
What is the best modem to connect to the internet via VPN?
This is a known issue with that modem and Comcast wont support VPN from residential installations. If you want to change modems that don't have this issue, get a Motorola surfboard. If you want to change settings on the one that you have because of the protocols for assignment of addresses let me know
Jul 31, 2014 | Computers & Internet
D-link has stopped working with comcast internet.
Are you trying to install the router.You can do it manually
without the CD.
MAke sure that your computer is able to go
online through the modem.
If your computer is able to go online
through the modem
Then you need to connect the computer to the
router ad the modem to the router.
open the set up page of the
router and change the settings of the router according to the
ISP.
Click Here for step by step by instructions
Jan 16, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Bought on eBay, trying to setup with comcast. See wireless signal but can't connect to the internet. I got to the configuration page and changed the SSID and setup WEP but the internet is not working.
have you tried connecting an ethernet cable directly to the modem to see if the internet is working that way? Have you considered contacting comcast as they can make sure its on your end or their end. Use this faq to help you. If you need further assistance please let me know.
http://www.comcast.com/Customers/FAQ/FaqCategory.ashx?CatId=578
Thank you,
Lee
Jan 14, 2010 | Arris SURFboard SBG900 (49402201900) Modem
Moved router to connect directly to the Comcast modem that also provides VOIP. Comcast activated modem and internet works when computer is connected directly to Comcast modem. Router does not connect to...
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
I have comcast cable net and D-link WBR 1310
Hi, forget about the USB connection since you wanted to use a router for your wireless connection. Contact Comcast asnd make sure they assist you in making your computer connect to the Internet using the ethernet connection because you are going to use the ethernet connection for the modem-router connection. Once your computer is online with the ethernet connection, you can connect your Dlink router to the modem and configure it for Internet connection. There will be more steps before you can use the wireless connection. Just make sure you can get online with ethernet connection first.
Jul 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I have comcast and i purchased the surfboard so that i could play use the internet for my xbox in my room. There is another modem on rent from comcast a touchstone telephony modem which provides internet...
u need a router to share internet connection, not 2 modems, from the way your explaining it im going to assume you just bought the modem went home and plugged it up, Well.. thats not going to work , your modem needs to be registered with the network your trying to access(comcast)
Jul 13, 2009 | Arris SURFboard SB5120 Modem
Internet connection issue. Is it setup or internet service
The problem would be comcast. Your connections are setup correctly. The modems do not control the internet traffic flow, they are made to produce maximum flow.
If more people use the internet, the less flow it will have.
Check all internet options settings, and make sure EVERTHING is set to automatic
Jun 06, 2009 | Arris SURFboard SB5120 Modem
Router wont work with new modem
Hello Ladoof,
We offer support for Comcast supported routers because they are widely used in the world today. If you are using one such router and it has stopped working, then you just need to call us for instant support.
Comcast Tech Support Internet Help Toll Free 1855 856 2653
May 08, 2009 | Blitzz Technology Computers & Internet
NetGear CM212 Broadband Cable Modem Logo
192 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
