Question about Max 2 Tail Rotor Blade For Yiboo Shark Rc Helicopter
My Yiboo Micro Blade Rc copter won't charge. I've tried disconnecting and reconnecting the batteries, but every time I plug it in the charging light doesn't come on and it goes into transmitting mode. There is NO CUSTOMER SERVICE WHATSOEVER, so please help me with troubleshooting.
Well my K11 helicopter that I bought from Paddys Markets Sydney Australia last week for $45 gave up after three flights. I suspect the battery is either dead or not charging or a burnt out wire. I suspect your micro RC helicopter has a similar issue. I smashed open my charger with a dumbell weight to see if the wiring inside it was ok. All looks good, but when it is plugged in, it does not even produce heat, which chargers always do to a certain amount. I also dismantled helicopter and took out battery. For $45 it is not worth me buying a voltmeter, another charger (which I cannot find online) and my manufacturer has a dodgy website as well! I recommend keeping your toy for parts and maybe getting another one?
Posted on Feb 27, 2011
  • rchelicopter Aug 27, 2011
    The K11 wall charger is know to give problems www.rchelicopters.it
Helicopter charger and batteries in remote ok, chopper won't fly
Is the "flight light" blinking on the copter? If you connect the USB cable to the copter will it power up? Have you tried different batteries in the remote? Check the pins in the charging port on the copter, Otherwise there's not a lot that can be done with these little RCs.
Feb 24, 2015 | Syma S102 IR Control Micro Blackhawk RC...
Leds stay on and do not blink,
Hi. I have the same issue.
RC has brand new batteries, switches on and see to work properly.
Quad is charged. But LED will not blink.
RC and Quad do not see to connect.
RC lights keeps blinking.
What happened ? As far as I know nothing unsual. I bumbed the quad slightly on the roof of the living room where I was fligh it. Nothing unsual. I landed it a bit roughly. Then it stopped responding. I assumed charge was empty but when I charged , nothing happened.
Dec 25, 2013 | Protocol Manta 4-Channel Radio-Controlled...
My Havoc Heli won't charge
http://www.buynicer.com/SWIFT6020--1-New-3--Channel-RC-Helicopter-w-Infrared-Remote-Control_pid8096.html
Aug 12, 2012 | Spinmaster Air Hogs Red Defender Remote...
Gyropter not lifting off after full charge
Mostly all the micro copters problem are the battery and the the pinion gear that's been worn out.
Check both of these part. Battery should at least gives out 350 mili amp. and the gear should touch the propeller shaft gear at the bottom of the copter.
Get a lithium ion battery for more power and longetivity.
Hope that helps!
Nov 20, 2011 | JCPenney Gyropter RC Helicopter
Air hogs pocket copter, brand new. Inserted brand new batteries into charger and controller per instructions. Plug the helicopter into charger and led blinks red as stated. About two or three minutes into...
You bought a defective mini copter, the internal micro relay is malfunctioning and I hope you could bring it back where you bought it. Replace it with a new one and let them try to test flight it before you go home.
Hope that helps you out.
Thanks for asking FixYa!
Aug 09, 2011 | Toys
Not getting altitude
Use only alkaline batteries, rechargeable batteries do not have sufficient voltage to fully charge the heli.
Apr 05, 2011 | RC Micro X Copter Mini RC Helicopter
My copter will not charge i plug it up,make sure copter is in off postion,but red light never goes off and copter never charges,the green light never comes on,this thing has been flown maybe 6 times since...
I just bought one for my Grandson and we had to plug in the outlet to the copter first, before pluging in the AC/DC adapter to the power charger. I know the instuctions do not explain it this way, but the green LED charging light would not come on and it would not charge doing it anyother way
Sep 27, 2010 | Silverlit Toys Ed Hardy 115" Special...
MY YIBOO CHINOOK HAS A BROKEN MAIN BLADE HUB. WHERE CAN I FIND REPLACEMENT FOR MAIN BLADE AND SHAFT?
I found this on xheli.com. Syma S022 big CH-47 chinook.
Looks like the same heli as Yiboo. Lists all spare parts.
Good Luck. Please post results if you order from this site.
I also have the Yiboo CH-47, have not needed parts yet, just got it for xmas from my wife.
Sep 15, 2009 | RC Toys
Nothing happens
The charger connection is sensitive on the Reflex Pro. It isn't uncommon to plug in the charger, see the light flashing, then when setting it down a slight movement of the cable stops the charging (light will stop flashing). Try connecting the charger again (if you haven't already) and let it charge for about an hour. While getting a good charge can be frustrating, it is worth it for the 4 minutes of fun to follow :-\
Aug 16, 2009 | Spinmaster Air Hogs RC Reflex Micro...
Max 2 Tail Rotor Blade For Yiboo Shark  Rc Helicopter Logo
1,826 people viewed this question
Top Max Toys Experts
ray gallant
Are you a Max Toy Expert? Answer questions, earn points and help others
