Question about GE GSL25JFPBS Side by Side Refrigerator
GE Refrigerator Model # gsh25jstc ss. My problem is very low water pressure when getting water from door. I have changed filter several times and the water control valve still low water pressure, any advice thanks?
  • 101 Answers
Check pressure to refridge,or check for frozen water tank in bottom of fresh food behind bins
Posted on Sep 10, 2010
  • yeaiwon Sep 10, 2010
    Pressure is fine and the water is not frozen thanks
  • t059 Sep 12, 2010
    water valve c[oged or bad
I have a GE Refrigerator that the ice maker keeps getting frozen up, I have changed the ice maker and the water valve out and it has started doing it again now...works good for a couple weeks maybe???
check the ice chute door,where the ice comes out of the door,sometimes the door doesn't close or it's broke,warm air gets up into the freezer and will start icing up everything the air hits,or the door gasket has a tear in it but if it's not water leaking from the ice maker then it's an air leak causing this issue.
Nov 02, 2017 | GE Refrigerators
My GE refrigerator is no longer cooling. Model GSH25JSTC SS. I just replaced the mother board WR55X10942 and it is still not cooling. Water dispenser, fan is working fine.
Is the compressor running? Is it any good? Is the thermostat control working and cycling the compressor on? Is the self defrost mechanism stuck in defrost cycle (shuts down compressor), etc?
Is the motor getting power?
U need to check all of these areas.
Apr 08, 2015 | GE Refrigerators
GE Refrigerator Model gss25sgrbss water line problem
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
May 09, 2010 | GE Refrigerators
Ge refrigerator water low, Drinking wate.
make sure line is not kinked behind the frig, maybe change filter if it has one. then change water valve if that dosent solve problem
Apr 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
G.E. Arctica Profile Frig produces bad drinking water
The bleach idea sounds the best. How did you get the bleach into the system? It would have to be under pressure from the water inlet to the connection on the refrig, running the water dispenser for several minutes until you could smell the bleach from the dispensed water, plus the icemaker would need to be cycled, and then left for at least 15 minutes to an hour, then flushed with clear water. (again, several, as in about 10, minutes for this step) (icemaker line also needs to be flushed with clear water) Best to be done with the filter bypass plug in place, then when done, a new filter. It is not really possible to replace all the water lines, as the one inside the freezer door cannot be replaced without replacing the entire door.
Sep 13, 2009 | GE Profile PFS22 33" Artica French Door...
Low water flow after changing the water filter in a gf profile re
Just a suggestion, you could try installing a filter on the water supply line to the fridge. A nice one should dramatically lessen the frequency of replacing the one in the fridge. As for your the pressure being low, look for a kink or pinch in the water supply line.
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Profile side by side refrigerator,model #GSC23LSRC SS
If you can get to the line in queston take it loose and blow it out, make sure that the filter has been taken loose prior to doing this
Aug 28, 2009 | GE DBSR453EBWW Electric Dryer
Have you tried a new GE filter? Use only GE brand. You can purchase a bypass plug from GE parts 800-626-2002
Jun 23, 2008 | GE DBSR453EBWW Electric Dryer
In operative water dispenser.
I have GE side by side refrigerator - 2004 model GSH25SGRB SS. From the blog I found out the problem is with frozen water line. If I keep the door water would dispense ( thawing). Or if you disconnect at the bottom ( take the grill out and disconnect) the water would dispense.
I placed a call to GE. The service person came. He said GE could fix with a 3 watt heater. He opened the panel. Pasted a heater. It came in a Y shape form. He connected that to the internal wiring. After some time the water started working.
Part $40. Labor for 15 min work = $210. Total = $250.
This is really should be a recall case. No part broken. They had to design a heater to solve this problem. What a rediculus thing is this. I am trying to call GE and ask to refund.
What a cheat GE!!. F them.
Feb 11, 2008 | Refrigerators
GE GSL25JFPBS Side by Side Refrigerator Logo
594 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
