Question about GE Profile JGS968SHSS Gas Kitchen Range
Hello, My problem is that the oven does not work. the screen on the stove indicates F3
  • 101 Answers
Oven sensor
Posted on Sep 10, 2010
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ā€Ž1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
My parents are getting an F3 on their Amana gas stove. This stove is about 9 years old. Not sure of the model. The burners are working fine, but they cannot use the oven. Any ideas? Many thanks!!
Hello & Welcome to FixYa
F3 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Amana AEW3530DD Electric Single Oven
Tappan stove model # mef352bfwa and serial # vf72904759 . When using oven F3 shows up on display and oven shuts off.
Kevin
Jun 18, 2011 | Tappan Kitchen Range
Stove reads F3 and won't cancel and oven won't shut off?
Kevin
Jun 15, 2011 | Frigidaire Ovens
It is all of a sudden beeping and there is a -F3- in the screen area. What do I do. It is a above the stove microwave. And has never done this.
hello,
The -F3- is an error code indication temperature sensing error. There is a chance that there is a loose wire connection from it position.
what you need to do to fix up this problem is to unscrew (open)the oven trace the wire down to the screen and also to the panel clean then fix up the loose wire back to it position then clean up all form of water or liquid you can fine around the wire and the control panel with this the problem of f3 code is solve.
than you.
Jun 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Jan 13, 2010 | Maytag MER5730 Electric Kitchen Range
I have an f3 code coming up on my stove. the manual says to call a repairman..the stove is 9 years old it may not be worth the repair. can you tell me what this f3 means...thanks
This error indicates the Oven temperature sensor has failed,
You will need to replace the Oven temperature sensor (RTD).
This part can usually be replaced from inside the oven.
Jun 22, 2008 | Maytag Kitchen Ranges
GE Profile JGS968SHSS Gas Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
