Question about Vulcan 481FL Gas Kitchen Range
Our Church has a Vulcan (Shorkel) 10-burner gas stove (48' x 30") in which the right lower oven pilot light keeps going off and which must be constantly re-lit. An appliance technician replaced the thermocouple about three weeks ago, but the problem persists. The technician said it blew out because the kitchen door into the hall was left open - this does not seem reasonable, there is really no breeze involved and surely Vulcan's design is better than that - Please help !
2 Suggested Answers
  • 3083 Answers
SOURCE: Our Church kitchen has a
I don't know a whole lot about these, but I know that a pilot light heats a thermocouple, which controls the gas flow valve. The repairmen should have suspected and checked it or changed it out, but the thermocouple is easier, of course. Each oven is equpped also with a gas shut-off valve, and that may be faulty.
Make sure your pilot flame is adjusted properly. Here is the proper adjustment: explains:
A natural gas flame should be a bright blue with the tip of the flame having just a tinge of yellow. A propane flame should have a bluish green flame with a tinge of yellow at the tip. The flame should be strong enough to hit the thermocouple tip about 1/2 inch from the tip end. If the flame is weak or shaky looking, check to see that a breeze or draft is not blowing on it.
The following site will explain how everything works in detail:
This should help, just take it step by step.
Good luck, thanks for using FixYa, and hope this works for the benefit of your congregation!
Posted on Sep 10, 2010
Vulcan oven pilot light how to relight
Hello Lynne,
To relight the pilots,start by removing the floor of the oven,then remove the small access panel below the doors. On the main oven burner will be a small pilot burner that probably looks something like this 10_26_2011_9_29_16_pm.jpg
on the gas valve behind that small panel under the doors will be a red button,push that red button and hold it in while lighting that pilot burner...continue tohold that red button for 30 seconds,release it and the pilot should be lit.
Good luck,GENE
Oct 26, 2011 | Vulcan 60XLC Gas Kitchen Range
We are cranking up this BRAND NEW Vulcan flat top. Weh have the convection oven below up and running, but we can't even see a pilot light for the flat top. Advice anyone? Culinary-yours Chef Geir
older ovens have pilots but the newer machines are electronic ignition,there are ignitors in the oven and electrodes or ignitors on the top burners,when you turn the knob for the burner you should hear a clicking sound and see a spark around the burner,that's what lites the burner,the gas comes in and the spark ignites it,i don't know much about your machine but it can't be any different from other stoves.if none are sparking there should be a spark module in there or they could have separate modules,if you send the full model number i can look it up for you
Oct 30, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
The pilot lights ok,the burners light,but after sometimes 5 to 10 minutes later both will go out
The gas for both passes thru the FMDA Safety Valve - in you case it's defective and must be replaced. You can find it here
Oct 02, 2010 | Vulcan EF3 Deep Fryer
I have an old Vulcan 6 burner commercial gas stove with a 24" griddle. The gas was turned off during a remodel. Now the gas is back on and the gas burners work fine but I cannot get the oven pilot light to...
Hi- This should have a gas Safety Valve, this is the main valve to the oven (this probably has 2). If you remove the lower panel under the doors they are probably right there. Looks like a large gas valve with a button on it, sometimes the button is red. You need to hold in that button while lighting the pilot and keep holding it in for a few seconds until the thermocouple gets hot enough to tell the valve to keep the pilot on. You'll have to do this for both ovens if there are 2 valves. It's possible the valves are located somewhere else on the range so you may have to hunt a bit. If the pilots still won't stay lit you may need new thermocouples in which case I'd call a Tech out to look at it. Hope this helps. Good Luck.
Sep 24, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
I have a 6 burner Vulcan stove with a bad oven pilot light.
Hi! I have the same problem with one of my burners (I have a morice range). I changed the thermocouple, but it didn´t help. I contacted Morice in France and was told that the problem most sertainly was the coil inside the gasvalve. I don´t know if it possible to dismantle the ovengasvalve to check the coil. As for a burner valve, one should open the valve at the end were the gas goes out to the burner to locate this coil. Best of luck Lars?ui=2&ik=305879aaef&view=att&th=1244dff9c340942f&attid=0.1&disp=thd&zw
Oct 06, 2009 | Vulcan 36L Gas Kitchen Range
I have a vulcan60CL77R stove and the oven pilots keep going out. Also I need 6" pilot tubes for front burners. Can you help?
Yes we can help you. We service Vulcan and we love these units. May I begin to telling you that you have a great range?!! This is either your ignitors or the gas valves, but most probably the ignitors out if the pilots keep going out. I will check on the price and availability of all the parts that you need and respond to this request. Could you please send me your email address? We look forward to working with you on this issue.
Sep 29, 2009 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
I have a vulcan VG36-66. We turn off the oven and
if your oven is automatic check the clock is in manual.
Sep 28, 2009 | Stoves 36" VULCAN RANGES GAS(CLICK HERE):...
60" double oven gas Garland stove
We use a Garland from the 1960's and pilot lights ARE scary and should make you nervous. This is why they are no longer allowed in new gas ranges. I mounted an inline gas shut off to the stove where the gas enters (on mine this is right in front on the left side). It turns on and off like a burner and when we are done cooking we simply shut off the gas there. To light the burners or the stove I use one of those long reach lighters. I go to bed knowing that NO gas is coming in.
We love the stove, it makes cooking more fun.
Good Luck!
Oct 24, 2007 | Garland H283 Gas Kitchen Range
Vulcan 481FL Gas Kitchen Range Logo
49 people viewed this question
Top Vulcan Kitchen Ranges Experts
Oloyede Monsuru
Dan Webster
Dan Webster
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
